Samsung Galaxy S5 Neo
blue moon
Banned
Banovan
Meni veoma zanimljiv model
Also known as Samsung Galaxy S5 Neo SM-G903F
Network Technology
GSM / HSPA / LTE
Launch Announced 2015, August
Status Available. Released 2015, August
Body Dimensions 142 x 72.5 x 8.1 mm (5.59 x 2.85 x 0.32 in)
Weight 145 g (5.11 oz)
SIM Micro-SIM
- IP67 certified - dust and water resistant
- Water resistant up to 1 meter and 30 minutes
Display Type Super AMOLED capacitive touchscreen, 16M colors
Size 5.1 inches (~69.6% screen-to-body ratio)
Resolution 1080 x 1920 pixels (~432 ppi pixel density)
Multitouch Yes
Platform OS Android OS, v5.1.1 (Lollipop)
Chipset Exynos 7580 Octa
CPU Octa-core 1.6 GHz Cortex-A53
GPU Mali-T720MP2
Memory Card slot microSD, up to 128 GB
Internal 16 GB, 2 GB RAM
Camera Primary 16 MP, 5312 x 2988 pixels, autofocus, LED flash
Features Geo-tagging, touch focus, face/smile detection, panorama, HDR
Video 1080p@30fps
Secondary 5 MP
Sound Alert types Vibration; MP3, WAV ringtones
Loudspeaker Yes
3.5mm jack Yes
Comms WLAN Wi-Fi 802.11 a/b/g/n/ac, dual-band, Wi-Fi Direct, hotspot
Bluetooth v4.1, A2DP, EDR, LE
GPS Yes, with A-GPS, GLONASS
NFC Yes
Radio FM radio
USB microUSB v2.0, USB On-The-Go
Features Sensors Accelerometer, gyro, proximity, compass
Messaging SMS(threaded view), MMS, Email, Push Mail, IM
Browser HTML5
Java No
- Active noise cancellation with dedicated mic
- MP4/H.264 player
- MP3/WAV/eAAC+/FLAC player
- Photo/video editor
- Document viewer
Battery Li-Ion 2800 mAh battery
Stand-by
Talk time Up to 15 h (3G)
Misc Colors Black
SAR EU 0.46 W/kg (head) 0.58 W/kg (body)
Ono sto se zna da je novo u odnosu na obican S5 je
1. drugaciji(bolji) materijal poklopca baterije
2.otvoren usb port a zadrzana vodootpornost i otpornost na prasinu -IP67 sertifikat
3.FM radio
4.Drugaciji chpipset,slabiji malo po nekim bencmark testovima(e sad u realnom radu ne znam ima li razlike)
5.Softver ima kao S6 sa mogucnoscu menjanja tema za TouchWiz
6.Poboljsana kamera(narocito u uslovima slabije osvetljenosti,bolja manual podesavanja)
7.Bolja prednja kamera navodno,5mpx vs 2mpx
Ako ga ima neko neka pise 🙂
Brat je uzeo s5 neo...posto nisam koristio s5 ne mogu da ga uporedim sa njim...mogu reci da je dobra izdrada i da lepo izgleda...brzo radi,android je 5.1.1.. novi touch wiz...kamere su odlicne...ko voli samsung preporuka za kupovinu...moje zapazanje je da htc sense nekako lepse radi u odnosu na tw...
Mene zanima ta njegova kamera.Nigde ne mogu da nadjem na netu semplove sa njega u full rezoluciji.
Pa kvalitet je slican regularnoj S5ici.A rezoluciju su promenili sa 16 mpx wide na 16 mpx 4:3,sto mi se ne svidja.
Ma ja sam se nadao da su i dnevne fotke bolje,jer se tako pricalo(doduse pominjalo se vise za nocne).Doduse,tek je izasao,mozda je softverski malo ispeglaju.
Gledao sam review na yt,radi lepo ovako sa basic funkcijama,ali kod igrica nije bas smooth kao G900,primeti se da je taj Exynos slabiji od SD801.Pitam se kakav mu je multitasking u realnom koriscenju...
Oduševljen sam sa baterijom, zaista nisam očekivao ovakav rezultat za prvo punjenje, znan da će SoT padati, ali opet...:
@Djurkas cestitam. Ge si uzeo fon,da nisi u Vipu?
Jel mozes da okines kad stignes neku landscape fotku u full rezoluciji i neku nocnu u manual modu?
Zanima me dosta ovaj telefon,mozda bih ga uzeo u Vipu.
Da, Vip, danas ću okinuti par fotki, pa kačim, ali ne očekuj previše 🙂
Video sam par primera fotki na netu i deluje sasvim dobra kamera pa zato se i interesujem. 🙂
U kojoj boji si ga uzeo?
OK,nema veze,hvala ti.Vidim da je ova napolju malo mutna,moguce da ti nije bila mirna ruka bas ili fon nema neku stabilizaciju slike pa ni softversku.
Edit-ova druga je bolja ipak.
Jel to i ova lajsna sa strane nesto drugacija u odnosu na obican S5 ili mi se cini?
Jeste,cini mi se kao da je manje podlozna ogrebotinama,ali u svakom slucaju je drugacija od S5.Djurkas ce potvrditi.
Da li neko stavljao neki custom rom? Ja sam na lolipop 5.1 1. Desava se da malo koci tel po nekad. I ne radi mi micro sd...radi dan, dva pa prestane. On je vidi ali ne mogu da brisem nista sa nje ili da slike idu na nju kad slikam. Imam 2 sd kartice. Na drugim tel rade. Tel je nov kupljen u svajcarskoj.
Nisam imao običan S5 da bih znao, za sada je sve ok, ali je u futroli, ako dođe do promena javljam 🙂
Mislim da je do bangavog TWa, i meni je posle Z ultre, S5 deluje sporije...
Za Neo ja mislim jos ne postoji ni root, a custom rom pogotovo.
Uzeh mašinu. Bolja je od S5 po većini stvari. Posebno po kvalitetu izrade. Autonomija baterija bi trebalo za nijansu da bude veća, ali ću to proveriti.
Software radi bolje i tečnije nego na S5.
Nadam se da će u bliskoj budućnosti biti neki recovery i custom rom. 🙂
Jesi pratio na XDA,jel izasao Root uopste za njega?Ja kad sam gledao zadnji put jos nije bilo.
Izašao je pre par dana root by Chainfire za 903F.
Vidim da je stigao i eksperimentalni TWRP.
Biće sigurno uskoro sve stabilno i neki custom MM. Jedva čekam 😀
Instalirao sam novi TWRP 3.0 (oficijalna podrška za S5 neo), autoroot Chainfire i custom rom sa xda. Ovaj custom rom je prečišćen oficijalni 5.1.1., verzija što je izašala sad, početkom februara.
Radi odlično sve, bez ikakvih problema. 🙂
Ja pisem upravo u S5 temi tebi da napises ovde utiske o Neu 😀
Reci mi kako si zadovoljan kamerom,imas li koju fotku da okacisda vidimo?Zvuk na sluskama kakav je po tvom ukusu?
Zvuk na sluškama je odličan. Nije neko ludilo, kao Harman Kardon, ali je odličan. Jasno se čuje ceo spektar zvuka. Bas je odličan. Nemam nikakvih zamerki. A za kameru, daje lepe slike. Boje su verne i slike su generalno oštre. Preporučujem korišćenje pro moda na kameri. Staviću sad koju sliku iz kuće što imam...
Prve tri su na pro modu uz podešavanja, a ova poslednja je auto mod (nisam imao vremena da podešavam bilo šta [emoji12] )
E hvala ti 😉
Aj kad budes u prilici okini neku dnevnu fotku,landscape neki ili nesto tako pa okaci ovde u temi.Bas me zanima kakvi su detalji na cropu.
Kako ste ubacili taj pro mode? Nema ga za download na S5 starom.
Ili je to opcija samo za Neo?
