TWRP
SuperStarr
Moderator
CPU & Cooler
Xeon 5670 (6c/12t) @ 4.3Ghz
Matična ploča
ASUS P6T Deluxe v2
RAM
48Gb HyperX DDR3 @ 1666Mhz
GPU
Gigabyte 1060 6Gb
Storage
Kodak 512Gb + 16Tb RAID
Zvuk
Creative Audigy2 ZS
PSU
Zalman ZM600-HP (Heat-Pipe :) )
Kućište
Alexander Weiss (glass front + glass side)
Monitor
AOC 32" IPS
Miš & tastatura
G602 & Drevo 87 key (Red Switch)
Ostale periferije
MX Master 2 & K380
Mobilni telefon
Moto G9 Plus
Pristup internetu
  1. Kablovski internet
TWRP 2.8.7.0 & Android 5.x (i noviji), dobija se ova poruka:
TWRP has detected an unmodified partition. TWRP can leave your partition unmodified to make it easier for you to take official updates. TWRP will be unable to prevent the stock ROM from replacing from replacing TWRP and will not offer to root your device. installing zips or performing adb operations may still modify the system partition.
Postoji mogućnost da TWRP, nakon što je uflešovan, "obradi" particiju i obezbedi da Android ne zameni TWRP recovery sa oficijalnom prilikom prvog podizanja sistema ali ima začkoljica:
System read only option:
Devices that ship with 5.0 and higher as their initial OS are using block level OTA updates. With this style of OTA update, the update script checks to see if the system partition has ever been mounted read/write. Further, the script also usually runs an SHA sum of the entire system partition to detect if any changes have been made. If any changes have been made, the OTA update will refuse to install. Since not all OEMs and devices have factory images available, we have created a new feature in TWRP that detects if the system partition has ever been mounted read/write. If not, you will be prompted asking if you want TWRP to mount system as read/write. If you choose not to allow TWRP to mount as read/write, TWRP won’t prompt to install SuperSU and TWRP won’t try to patch the stock ROM to prevent TWRP from being replaced by stock recovery. The goal of this option is to hopefully allow the user to make a raw system image backup that they can use to get back to a state where they can take OTA updates again.​
Mene zanima kako da se igram sa sistemom (Root, custom rom i sl.) a da posle vratim sve u "prvobitno stanje"?
Da li je dovoljno da samo napravim backup sistema (nandroid backup) i šta sve da izaberem za backup?
:wave:
Uradiš bekap boot i system particija, pa onda možeš da radiš root i čačkaš po sistemskoj particiji. Ukoliko se ukaže potreba, možeš da odradiš restore tih particija. Možeš ds uradiš i bekap data particija, ukoliko smatraš da je to potrebno. Na toj particiji se nalaze korisničke aplikacije i podaci.
Samo nemoj da okines KNOX, ako ti je zbog garancija bitno. Obozavaju da zbog toga ne uvazavaju reklamacije.
https://twrp.me/faq/whattobackup.html
Konkretno, čega bi ti uradio backup?
system, data & boot ili još nešto? cache & userdata?
Gledam da mi backup slika bude što manja. 🙂
Noob quest: KNOX - to je nešto što samo Samsung ima ili svaki Android 5.x pa na više?
Koliko znam, on nema Samsung telefon. Nije da to "vole", već je to znak da je nad telefonom vršena "modifikacija izvan proizvođačevih specifikacija". Naravno, to dovodi do gubitka garancije. 🙂
Uradio bih bekap svega, u zavisnosti od toga šta planiram da radim. Ali ako želiš da ti bekap bude što manji, uradi bekap Boot i System particija. Inače, ako budeš želeo da instaliraš OTA update nakon modifikacije, moraćeš da vratiš bekap sistemske particije, pa tek onda prihvatiš instalaciju OTA.
Knox ima samo samsung i to kazano strucno je efuse ili osigurac koji gori nakon rutiranja i nema povratka nazad zato i devolopere nemogu da najdu reset kao binary count na s3 kao sto je tringle away
KNOX je security feature. A pošto je root eksploatacija sigurnosnog propusta, treba da ostane kako bi upozorilo korisnika, pa bi bio dodatni propust da možeš da ga resetuješ.
Naravno to ništa ne znači ljudima, koji namerno hoće root i samo ih smara.
Iskreno root pristup treba da bude u developer meniju on/off.
Ako je već otvoren sistem.
^Slazem se. Tu politiku za sada ima samo meizu. Dokle ce je gurati videcemo..
Sa rutom imas identicne mogucnosti kao sto imas na svom pc.. Ne vidim da odbijaju garancije za pc zbog toga sto imas pristup njegovim sistemskim fajlovima.
a da neko otvori temu kako se i sta se radi sa TWRP-om
Da, bilo bi lepo, s obzirom da TWRP ume opasno da soft brikuje fon pri boot to recovery - neće pa neće da digne sistem ponovo i ništa ne pomaže. Video sam na XDA gde su ljudi to rešavali ukrcavanje nekih kodova u konzoli u TWRP, meni nije uspelo, morao sam tako dva puta da rešenjem fon bez veze. S6 je u pitanju, Marshmallow.
Sent from my SM-G920F using Tapatalk
