- Xeon 5650 (6c/12t) @ 3,7Ghz
- MSI X58
- 48Gb HyperX DDR3 @ 1666Mhz
- Gigabyte 1060 6Gb
- 256Gb 850Pro + couple of AliExpress SSD's
- Zvuk
- Creative
- Zalman ZM600-HP (Heat-Pipe :) )
- Alexander Weiss (glass front + glass side)
- Monitor
- AOC 32" IPS
- Miš & tastatura
- G602 & Drevo 87 key (Red Switch)
- Ostale periferije
- MX Master 2 & K380
- Mobilni telefon
- Moto G9 Plus
- Kablovski internet
TWRP 2.8.7.0 & Android 5.x (i noviji), dobija se ova poruka:
Postoji mogućnost da TWRP, nakon što je uflešovan, "obradi" particiju i obezbedi da Android ne zameni TWRP recovery sa oficijalnom prilikom prvog podizanja sistema ali ima začkoljica:
Mene zanima kako da se igram sa sistemom (Root, custom rom i sl.) a da posle vratim sve u "prvobitno stanje"?
Da li je dovoljno da samo napravim backup sistema (nandroid backup) i šta sve da izaberem za backup?
:wave:
TWRP has detected an unmodified partition. TWRP can leave your partition unmodified to make it easier for you to take official updates. TWRP will be unable to prevent the stock ROM from replacing from replacing TWRP and will not offer to root your device. installing zips or performing adb operations may still modify the system partition.
System read only option:
Devices that ship with 5.0 and higher as their initial OS are using block level OTA updates. With this style of OTA update, the update script checks to see if the system partition has ever been mounted read/write. Further, the script also usually runs an SHA sum of the entire system partition to detect if any changes have been made. If any changes have been made, the OTA update will refuse to install. Since not all OEMs and devices have factory images available, we have created a new feature in TWRP that detects if the system partition has ever been mounted read/write. If not, you will be prompted asking if you want TWRP to mount system as read/write. If you choose not to allow TWRP to mount as read/write, TWRP won’t prompt to install SuperSU and TWRP won’t try to patch the stock ROM to prevent TWRP from being replaced by stock recovery. The goal of this option is to hopefully allow the user to make a raw system image backup that they can use to get back to a state where they can take OTA updates again.
:wave:
