Ikonica, ikonica. Konacno dobih ikonicu, koliko se ceka od rezervacije? Nadam se da e-banking radi.
Ја сам скоро инсталирао Седмицу и то два пута и после полудневног апдејтовања се одмах појавила иконица. Чекао неколико дана и кренуло је да довлачи али после тога ништа. После сваког рестарта сам видео да безуспешно покушава да крене са 10, онда сам ја покренуо неки setup .... и све се обрисало. И даље је покушавао да покрене 10 ... на крају ми је досадило па сам обрисао садржај оног downloads фолдера и одмах је кренула инсталација.
Dodatak u EULA:
Kod:
. Updates to the Services or Software, and Changes to These Terms.
a. We may change these Terms at any time, and we’ll tell you when we do. Using the Services after the changes become effective means you agree to the new terms. If you don’t agree to the new terms, you must stop using the Services, close your Microsoft account and/or Skype account and, if you are a parent or guardian, help your minor child close his or her Microsoft account or Skype account.
b. Sometimes you’ll need software updates to keep using the Services. We may automatically check your version of the software and download software updates or configuration changes, including those that prevent you from accessing the Services, playing counterfeit games, or using unauthorized hardware peripheral devices. You may also be required to update the software to continue using the Services. Such updates are subject to these Terms unless other terms accompany the updates, in which case, those other terms apply. Microsoft isn’t obligated to make any updates available and we don’t guarantee that we will support the version of the system for which you licensed the software.
c. Additionally, there may be times when we need to remove or change features or functionality of the Service or stop providing a Service or access to Third-Party Apps and Services altogether. Except to the extent required by applicable law, we have no obligation to provide a re-download or replacement of any material, Digital Goods (defined in section 14(b)(v)), or applications previously purchased. We may release the Services or their features in a beta version, which may not work correctly or in the same way the final version may work.
d. So that you can use material protected with digital rights management (DRM), like some music, games, movies and more, DRM software may automatically contact an online rights server and download and install DRM updates.
Kod:
https://www.microsoft.com/en-us/servicesagreement/
Sto znaci da piratski sadrzaj moze biti blokiran od strane MS, takodje isto vazi za modifikovan hardware, ili eventualno piratski hardware. Takodje iskljucivanje windows update i ostalih predvidjenih servisa vas obavezuje da prestanete da koristite MS usluge, pa ako vam kasnije zafali neki update, moze se desiti da vam MS iskljuci licencu zbog krsenja uslova koriscenja.... E za sada je to samo u teoriji, ali videcemo kako ce se to sprovoditi u praksi.
Хм, када сам инсталирао windows 7, он је направио ону системску партицију од 100MB. Апгрејд на windows 10 наравно није то променио па је и даље та величина. Да ли ће то да нешто смета, зашто уопште ту има разлике па 7 прави од 100, 8 од 350 а мислим да 10 прави од 500MB? Толико је потребно или оно, има се може се па нека буде веће?
Није ми никакав проблем да променим величину али може да потраје а што да радим нешто ако не мора?
Dodatak u EULA:
Kod:
Kod:
Pa cim prvi put krenu da primenjuju to u praksi cao,zdravo windows! Selim se na ubuntu.Mada ja mislim kako negde procitah da ce to da se desi sa sledecim windowsom,tj. da smo pristali sa instalacijom win10 da predjemo na sledeci windows kad bude gotov naravno i taj nece biti besplatan i svasta jos nesto,ali ima do tad fore.Da ne selimo ovde temu o spijunazi.:)
Mozda ne podlezemo tim pravilima ako ne koristimo ove servise.
The list of services covered by the agreement doesn't explicitly include Windows 10. However, it does include your Microsoft account, which is an extensive part of the Windows 10 experience, as well as core features like Cortana – and that implies Redmond can disable any games you’ve pirated or devices you’ve "unlawfully" hacked. Enable Cortana (which pretty-much everyone using Windows 10 is going to do) and you're subject to the Services agreement.
Ne koristim Cortanu, jedino MS nalog da skinem i eve im ga :)
Samo prvu igru da blokiraju i sebi su zapisali sudbinu. Jer ce ih gejmeri prvi napljuvati jer ih ima najvise i samim time ce se jos vise protiviti toj politici da ce jos upornije hteti da piratizuju win 10 da bi igrali namerno na njemu igre.
Mogu oni da pisu u microsoftu sta hocu ali vrlo dobro znaju da sa tim potezom ako krenu da seku granu na kojoj sede i da ce na kraju jedino oni da izvuku deblji kraj a gejmeri ce se masovno vrate na sedmicu i na 8.1 i onda onaj majkrosoftov plan od milijardu korisnika ce ostvari kada pi*ka kaze kuku.
Kada se upgrade na Win10, da li se gube fajlovi sa particije na kojoj se bio pedhodni windows? Gde se nalazi skinuti winodows 10?
Meni ne smeta, nek spijuniraju kolko oce, sve dok nemam neki udar na performanse zbog toga :D
Ne gubi se nista, bukvalno dobijes Win 10 sa starim podesavanjima i fajlovima, ostaju instalirani programi, startup aplikacije, sve kao na prethodnom,a stari sistem se nalazi na C: u folderu "Windows.old".
A samo jedna stvar koliko tezi taj windows.old?
Da li je svima isto ili zavisi od toga sta i koliko si imao na starom windowsu?
Ja sam preko clean up-a te stare fajlove obrisao oko 25-30 GB-a.
jel neko zna kako da resim problem sa sleepom, naime kad stavim pc na sleep posle nekog vremena on se probudi sam iz sleep moda, ovo su moja podesavanja..
Питање за оне који то знају, а везано за чисту инсталацију. На главном компу је била инсталирана инсајдер верзија, пар пута реинсталиране новије верзије и на крају пре месец дана редовно активирана по инсајдер правилима. Пре десетак дана сам на исти хард уместо инсајдера набацио Windows 7 Ultimate, апдејтовао, дошла је иконица и на крају је све прешло на 10.
Е сад питање, ако бих сутра одрадио чисту инсталацију, шта је ту запамтио Microsoft? Ако памти према хардверу, обе верзије су могуће. Пошто не могу да искористим кључ од седмице, мора нормална инсталација и нисам сигуран шта ће да се деси. Како уопште да бирам да ли нека следећа чиста инсталација да буде инсајдерска или она редовна? Можда има приоритет или чак пита, зна ли неко?
Кад се уради упдате са W7 на W10, како после вратити на W7 без губитка фајлова програма...?
Da, slazem se, ne koriste svi ove servise, ali recimo MS account, skype i MS office su standard na prosecnom racunaru u Srbiji, e sada uvek ima besplatnih alternativa, informacija je tu cisto da ljudi znaju sta mogu da ocekuju. Mislim da vecina onih koji znaju ce pogasiti nepotrebne stvari, ali veliki broj koristi sve sa default podesavanjima, koristi app store, pa ima i onih koji koriste neke servise za kupovinu muzike(koja recimo bi mogla da se izmesa sa piratskom), pa tako mogu da izgube sadrzaj koji su platili. Isto vazi i ukoliko ste recimo kupili jedan film preko neke aplikacije i slicno. Pretpostavljam da ce Edge i Bing blokirati recimo sajtove sa piratskim sadrzajem, ali naravno trebalo bi sacekati i videti kako ce se to sprovoditi u praksi, moje misljenje je da ce se to sprovoditi samo za MS software i sadrzaj njihovih partnera, jer kao sto neko rece presekli bi granu na kojoj sede da urade drugacije. Ipak napomenuo bih da se ipak daju previse odresene ruke MS-u prihvatanjem ovih uslova. Uslovi koriscenja nisu jasno definisani, posto se ova EULA odnosi na servise kao sto su MS account, skype, app store, Kortanu, Bing i sadrzaj koji je dobavljen preko njih, moze se po potrebi tumaciti dosta siroko, jer ovi servisi su duboko integrisani u sam Windows 10, pa tako da se ostavlja mogucnost da se protumaci i tako da koriscenjem windows 10 za ilegalne aktivnosti krsite pravila koriscenja tih integrisanih servisa...
Имаш фору месец дана, све се враћа како је било, мада пише да ту и тамо понешто мора да се поново инсталира. Вероватно програми који нису компатибилни па су скраћени на 10 и сад мораш да поновиш. Углавном све остаје.
Idi u Device Manager i iskljuci opciju "allow this device to wake up..." za svaki sumnjivi uredjaj - misa, mreznu kartu... ali ostavi tastaturu, ipak treba nekako probuditi komp :D
