znaci da nemoze - jel mogu da uzmem punjač od s3 neo?Q1: Can I disable Galaxy S6 fast charging on Galaxy S6 or S6 edge?
A1: No, you cannot disable Galaxy S6 fast charging in the phone settings. This is different from the fast charging in Galaxy Note 4.
However, Galaxy S6 fast charging will be disabled automatically when:
* you are not using a normal wall charger, not the adaptive charger.
* or you are using the phone with screen on.
* or battery level is more than 50%.
