GeForce TITAN X Thread
Utiske? Pa moracemo sacekati kolegu *******og posto je prilicno izvesno da ce taj jedan primerak koji stigne na ovo trziste kupiti on, pa ce jedini moci i podeliti utiske ;)
NVIDIA GeForce GTX TITAN X
Kralj je stigao :D:D:D
The GeForce Titan X is a processing powerhorse. The GM200 chip carries six graphics processing clusters, 24 streaming multiprocessors with 3072 CUDA cores (single precision).
As noted earlier, the Titan features a core configuration that consists of 3072 SPUs which take care of pixel/vertex/geometry shading duties, while texture filtering is performed by 192 texture units. With a base clock frequency of 1000MHz, texture filtering rate is 192 Gigatexels/sec, which is over 33% higher than the GTX 980. The Titan X also ships with 3MB of L2 cache and 96 ROPs.
The memory subsystem of GTX Titan X consists of six 64-bit memory controllers (384-bit) with 12GB of GDDR5 memory. This means that the 384-bit wide memory interface and 7GHz memory clock deliver a peak memory bandwidth that is 50% higher than GTX 980 at 336.5GB/sec.
And with its massive 12GB of GDDR5 memory, gamers can play the latest DX12 games on the Titan X at 4K resolutions without worrying about running short on graphics memory.
http://www.techspot.com/review/977-nvidia-geforce-gtx-titan-x/
Pros: Fast, efficient, overclocks well, runs quiet.
Evo i na ovoj temi Cena 999 USD! :)
Da budem iskren mislio sam da ce biti vise poput slicnih starijih modela.
Dobar proizvod sa bespotrebnih 12GB a samim tim i onakvom cenom.
Odlican proizvod, na 4k rezoluciji 22% sporiji od 295x2 i 300$ skuplji. Well played.
i single karta...
Edit,
da mislio sam na single gpu :)
Za tih 300$ razlike ima sledecih 5 god da imam za veci strujni racun :)
Pretpostavljam da mislis na single GPU, posto su obe single karte.
Sve je to cool sto je najjaci single GPU card trenutno, ali cemu 12gb memorije kad vec ne moze da iskoristi ni pola od toga.
Da su smanjili ram na 6gb i cena da je 799$ ovo bi bio dosta bolji proizvod.
e to se zove marketing, vecina kupaca ne zna to sto ti znas, pa cim cuju 12gb !!! oni kazu ****te kakva karta, kesiramo i cao :D
Jel se meni cini ili ova Titan karta nema poboljsane double precision performance?
Citao sam detaljno test na techpowerup interesovalo me sta moze full maxwel jer bilo je najava kad su prestavili maxwel arhitekturu da spremaju cudo u odnosu na kepler bili su oni slajdovi grafikoni ma duplo troduplo (vjerovatno ni ovaj put nisu se dobro usaglasili sa marketing timom).
Prvo sto sam pogledao performance/price odnos
http://www.techpowerup.com/reviews/NVIDIA/GeForce_GTX_Titan_X/31.html
Dovoljno je pogledat, ne treba nista komentarisati.
Kad sam to pogledao krenuo sam iz pocetka da vidim sta to na ovoj karti vredi 1000$:
Naletim na ovo "NVIDIA is using the same NCP8114 voltage controller as on the GTX 970 and GTX 980. The controller has no support for I2C, so there is no advanced monitoring. Its VID based voltages can be monitored and controlled through NVIDIA's driver".
pa idem dalje PCB nista spektakularno nista sto bi opravdalo, cjenu mozda memorija?
Pa ocito bespotrebno je ovakvom chipu 12GB ljudi su fino i to objasnili
http://www.techpowerup.com/reviews/NVIDIA/GeForce_GTX_Titan_X/33.html
Kontam valjda kad karta vredi 1000$ mora bar hladjenje da briljira kad vidim ovaj video pa tacno zaplakt
Fino se na video vidu da karta dok je temp u granicam normale (ispod 80c) drzi taktove visoko do 1150mhz, medjutim to jako kratko traje karta vrlo brzo prelazi 80c tacnije ide do 84c i tu obara takt koji varira izmedju 1025/1050mhz, to je znaci 100mhz manji takt od pocetnog.
Zasto je ovo bitno da karta ima bolje hladjenje imala bi znatno bolje rezultate jer 100mhz nije malo na ovakav chip.
Sto se tice buke koju proizvodi ovo hladjenje; ovo je sve samo ne tiho (subjektivni osjecaj na osnovu gledanja videa).
Za kraj OC ovde se definitivno karta nije proslavila, a kad se pregleda gore pomenuti video vidi se i zakljucak jednostavno i na def taktovima hladjenje nije doraslo zadatku, moze se odraditi neki OC ali tada su temp. i buka sigurno ogromni jer inace nema rasta radit OC ako se temp. target ne podigne ili odvrne fan. a ni jedno ni drugo nije dobro.
Kad se jos na to doda da u cjenu od 1000$ nisu mogli ubaciti backplate e to je stvarno pravi cirkus.
Na pitanje sta vrjedi 1000$
-performanse ispod ocekivanog
-hladjenje nije doraslo zadatku
-OC slabasan (opet uzrok hladjenje jer je maxwel sa GM 204 chipom pokazao da moze da dohvati visoke taktove)
-12Gb memorije bespotrebno
-ovo mi je zapalo za oko "Not fully double precision enabled"
700$ plafon za ovu kartu i to samo iz razloga sto je trenutno najbrzi singl gpu.
Ako Nv bude prodavala ovu kartu u velikim primjercima onda ce da se opare zestoko, ali cisto sumnjam izuzev pravi entuzijasta da ce neko uzet ovu kartu, nema nista apsolutno da opravdava ovu cjenu.
Ovaj referntni model je truba, ovo sigurno necu da kupim, nadamse da ce asus, gigabyte ili msi nesto da izbace sa boljim hladjenjem u tom slucaju kartu ce raditi radi na 1500mhz za svaki dana sto je okvirno brza za 50% od overklokovane Gtx980, tako nesto mogu da platim 1000e po komadu :D Ovu referntnu, tesko... 12gb memrije, totalna glupost, ale nema veze nece da se baci :p
EVGA radi samo standard blower edicije, ali ce imati i hydrocopper varijantu. Za ove ostale nisam cuo nista.
Taj blower pije vodu za kartice koje trose ~150w, sve preko je neefikasno.
Pitanje je hoce li biti nonreferentni modela TITANA-X za 1000$ morali su da odrade bolje hladjenje ovo je isto hladjenje kao kod GTX980 samo ga ofarbali u crno a ocito je da iz ovog gore videa sto sam okacio ovo hladjenje ne moze udrzati ovako velik chip, jos kad se upakuje u kuciste dodje ljeto ma ima da obara takt ispod 1GHZ a samim time odose i performanse, a onda od OC-a nema nista.
Ovo je mocan ogroman chip sa dosta potencijala samo mu treba obezbjedit bolje hladjenje, za 1000$ to su morali bolje odradit.
zaljebani,mislim da je konacno vreme da dve tri ove mrnje nabacis pod vodu. :)
bash to, 3 ove na vodu i 4K gaming moze da pochne :)
Onaj ko daje 1000$ za grafičku kartu, zna sve što je potrebno :) Pretpostavljam da hoće da je prodaju ljudima kojima je GPGPU bitniji od gaming-a
To bi nekako pilo vodu da je ova kartica odradjena kao prosla ali to ovde nije slucaj.
Nije mi jasno koja je ciljna grupa? Po meni ovo sluzi imamo najbrzu kartu sa 12gb memorije.
Sad ce redom svi da se pecaju, cena je sasvim prihvatljiva samo 1000$ :d
Jos ako se ispostavi da nova karta od amd bude brza to ce biti samo takva samarcina za envidiju :)
@Erik011
To hladjenje moze da iznese 250w i trebalo bi da se nosi bez problema sa ovom kartom.
imaju oni do maja i juna sasvim dosta vremena da je prodaju,ciljne grupe ima jer su i 2k i 4k monitori vec na trzistu.sto se tice hladjenja,ocigledno da situacija nije bas sjajna,zato ni nema backplate-a a i vec na launch-u ima price da trotluje.kao sto rekoh,idealna karta za zaljebanog,delevica i ekipu da nabacaju vodu i cede suvu drenovinu. ,)
Ako im je takva filozofija svaka im cast. Dok ima ovaca bice i sisanja ;)
Jedina ispravna logika bi bila verzija sa 6gb sa cenom od 650$ pa nek je i 700$ ali ni jedna karta ne treba da
kosta toliko.
P.S. Nisam zeleo da omalovazim buduce potencijalne kupce. Nek vam je sa srecom :)
Niko ovo ne kupuje zato sto je to dobra kupovina cena/performanse, vec zato sto ima cime da kupi a ne zeli da pravi kompromis, sto je skroz ok, onaj ko daje zadnje pare za ovo po meni je teska ******, jer stvarno je besmisleno dati zadnjih 1000e za ovakvu kartu, tu nema nikakvog zadovoljstva jer karta je krs u ovakvom izdanju, da je bar neka oc munja pa da bude neki merak dati zadnje pare...
Ja sam osudje na Nvidia karte zbog g-sync monitora. Mozda pazarim ovo sa vodenim hladjnjem u sli, to bi vec bila dobra kupovina :)
Sa aspekta prirode trzista ovo je promasen proizvod.
Za 2k i 4k rezolucije imas GTX 970 koju povezes u sli za dosta manje novca.
Eno lik na kp prodaje G1 overklokovani Gygabyte za 330 eur nov.
Bilo da imas novac za baciti opet bi bilo pogresno dati pare za ovu kartu pogotovu ako DX12 donese sabiranje memorije.
Tek tad je besmisleno ovih 12gb a jos vise obesmislena kupovina ove kartice po ovoj ceni.
Onaj kineski chiphell valjda je bacio chart koji je pokazao titan sa bas ovakvim performansama. Sad ako se vodimo logikom onda bi i 980ti, 960ti i 390x trebalo da imaju performanse kao tamo prikazane. Ako zaista bude tako bice veselo trziste. Bez obzira na stvarno dobre performanse nekako mi je utisak kao i posle testiranja 960. Ocekivano ali opet... mnjeh.
Ovo ne bi trebalo uzimati iz protesta. Eno neko u maxwel temi postavio link ka mon.... FB strani: očekivana cijena oko 2000e. Znači, 'iljadarka teško da će bude. A i AMD krenuo njihovim stopama, pa će i oni ići blizu' iljadarke.
