Dear Goran Mihajlovic,
Sorry if there is any inconvenience. Please understand that this is the hardware design and since there is nothing wrong with the hardware, there is no refund offer on it. Below is the official statement from NVIDIA for your reference.
The GeForce GTX 970 is equipped with 4GB of dedicated graphics memory. However the 970 has a different configuration of SMs than the 980, and fewer crossbar resources to the memory system. To optimally manage memory traffic in this configuration, we segment graphics memory into a 3.5GB section and a 0.5GB section. The GPU has higher priority access to the 3.5GB section. When a game needs less than 3.5GB of video memory per draw command then it will only access the first partition, and 3rd party applications that measure memory usage will report 3.5GB of memory in use on GTX 970, but may report more for GTX 980 if there is more memory used by other commands. When a game requires more than 3.5GB of memory then we use both segments.
Regards,
GIGABYTE
Sto bi rekli, ne zanima me ni njihovo ni misljenje NVidije. Isti papci ako mene pitate.![]()
Moram da ih lozim, sve redom, jace je od mene. Cak ne verujem da inzenjeri u Gigabyte, MSI, ASUS itd nisu primetili da nesto nije OK, ma da... kako da ne, pa sve su dobili na papiru, sve sto novinari NIKADA ne dobiju, a sto im je potrebno za projektovanje same kartice. Svi su se tu grbavili, svi su cutali, sve je to ista bagra.
Znas kako sa prevarantima samo ostro, kvariti im svaki dan, zezati ih do iznemoglosti, a u medjuvremenu se kvalitetno igrati na pomenutoj GTX 970.![]()
GoranM. brate kad vec teras cimaj da ti salju neke kodove za dve igrice, neki vaucher pi*ke mate*ine pa to prodaj posle, i ispada da imas karituc za 250-ak eur. npr.
sutra mi stize Maxwell - msi 970gtxmogao sam uzeti GV-R929XOC-4GD koja je 400din skuplja ali sam negde nasao podatak da je 290x vruc chip i da gpu zbog toba obara takt, dal je istina ne znam ?
Nego koje igre idu uz gtx970 ?
Tolko o drajverima.@DeadSanto123 We are always improving performance through drivers but there are no plans for an update specifically for the GTX 970.
amd mora da spusti 290x i to lep komad para ispod 970gtx ako misli sa tim cipom da navuce ove sto su vratili 970gtx,ne bi me cudilo da nvidia spusti 980gtx opasno dole da bi odobrovoljila partnere.idealno bi bilo kad bi sutra crveni izbacili nove radeone u fulu,ali ocigledno nista od toga dok majkrosoft ne izbaci dx12 do kraja.
Ali u dubini duše, znaš da je feler.![]()
http://www.techpowerup.com/209412/amd-cashes-in-on-gtx-970-drama-cuts-r9-290x-price.html
Samo jos majka Serbija da cuje za ovo. :d
Is there a specific game that I can help you with? Unfortunately we made an error in the reviewer guide but the GTX 970 is one of the best GPU's we've ever built.
http://www.hardwarecanucks.com/foru...68595-gtx-970s-memory-explained-tested-2.html
Let me know how I can help.
jos su glluplji kupci koji su to tek sada primetili..... sve sami strucnjaci! takodje asus, evga, gigabyte, gainward, msi i ostalih par.....mogli su prvi da im skrenu paznju i da odmah isprave specifikaciju.....
kupci primetili, ha ha!
jasta, svaki dan se vrte testovi! graficke se za to i kupuju inace.
meni ovo sve vise pocinje da lici na spinovanje ATIja koji ni u najavi nema proizvod koji bi mogao da parira nvidia.
