cija ovo IP adresa? Telkom ADSL? 79.101.87.15 ajde javi se...
drcni stranci, mige mu upao u oko, da me izvrse atenrar na njega
Jel vi ovo idalje kopate? Koliko nakopate za 24h?
Od sinoc iskopano dva o o, da kompletiramo onaj .l. sto smo juce iskopali.
mislim da smo dovatili 1440 rezim u zadnja 24h
To je i jedan od problema, sto nije 1440, a trebalo bi. Diff je uzasno podesen. Ovog momenta se majnuje 1900 coina na dan, a bilo je i po 2100.jel to projektovani broj novcica koji treba da se iskopa u toku 24h???
ako jeste ili ce cena debelo da skoci ili ce ova prica polako da potone....
Hello All!
After taking the community vote and listening to feedback from the community, tomorrow we will be release Bytecent v1.2 with the features discussed in the previous thread. Tomorrow we will be hard forking to ensure all previous versions of Bytecent no longer work.
Here is what you should do to prepare yourself for tomorrow:
1. Move your coins from the exchange to your local wallets and backup your wallet.
2. DO NOT send coins to anyone after 11 AM EST.
3. When we release the new version make sure you update immediately or you will be on the wrong fork.
Anyone that is not on the correct fork will not be able to send or receive coins from users of the new version.
After we release the new version, we will be releasing Bytecent v1.2 to the general public within 48 hours if no major bugs are found.
Note: If you have been mining to one wallet or using older versions to mine without Captcha, I strongly suggest you buy coins now while you can. After tomorrow, everyone will need to have coins to mine without captcha, no exceptions.
IE
Da, danas oko 17h po nasem vremenu. Znaci dovidjenja kopanje bez coini u wallet.
