Bojcha
Cenjen
ByteCoin (BYC) -
Bytecent (BYC) - Removing Barriers with Innovation
Bytecent is not just another cryptocurrency in a sea of many, it is a philosophy born out of necessity. The goal of this project is to reinvent crypto from the manner that wallets are distributed and installed, to the method that coins are mined and utilized. Bytecent is the first user-friendly cryptocurrency designed from the ground up to be as easy as sending an email. If you can point and click a mouse, you can use Bytecent.
In addition to eliminating the complexities associated with cryptocurrencies, Bytecent aspires to be the first cryptocurrency to make use of old and new media to educate both merchants and consumers on the numerous benefits of using Bytecent.
Join the Bytecent revolution and be part of the future of crypto and financial transactions as we know it!
O developeru..
http://coinblab.com/forums/topic/29/introducing-christopher-bouzy-aka-iconic-expert
Oficijalni forum
http://coinblab.com/forums/12/bytecent
Specifikacija
Ticker: BYC
Total Coin Supply: 33,000,000
Crowdfund: 3,000,000 coins
Algorithm: Prime Six
Mining Duration: 57 years
Block Reward: 1 Bytecent
Block Time: 60 seconds
Difficulty Retarget: Every block
Confirmations: 3
Maturity: 200
Timestamping: POW/POM
Bittrex Menjačnica
https://bittrex.com/Market/Index?MarketName=BTC-BYC
Novčanik (Wallet)
http://bytecent.com/download/bytecent.exe
Preporuka - Novčanik startujte sa wallet.exe ("hiden") (C:\Program Files (x86)\Bytecent) ne preko originalne ikone. "Sticker" pri startovanju menja bytecent.conf file, pa je bolje da imate vaš. Evo i svežeg (redovno osvežavan) http://pastebin.com/F74MZCfD
Problemi sa konekcijom walleta.
Do sad sam probao razne stvari. Ono sto je najvise pomoglo je da na vašem ruteru ili modemu ili sta god korisite, ukljucite "UPnP" Opciju.
Takodje je potrebno da i u Windowsu bude ukljuceno. Za Windows7 je uglavnom vec podeseno za XP mora da se dodano podesi.
Link kako proveriti/podesiti http://www.computerhope.com/issues/ch001367.htm
Majning PoM
Ideja majnovanja Coina (PoM - Proof of Mining) je da je na svakih ~sat vremena potrebno kucati "captcha" kod i tako nastaviti majnovanje. Ideja je da se izbegnu farme, serveri, itd..
Ukoliko u novčaniku imate preko 600 coina, kod se kuca na 24 sata.
