ByteCent (BYC)
  • Začetnik teme Začetnik teme Bojcha
Bojcha
Cenjen
ByteCoin (BYC) -
Bytecent (BYC) - Removing Barriers with Innovation
Bytecent is not just another cryptocurrency in a sea of many, it is a philosophy born out of necessity. The goal of this project is to reinvent crypto from the manner that wallets are distributed and installed, to the method that coins are mined and utilized. Bytecent is the first user-friendly cryptocurrency designed from the ground up to be as easy as sending an email. If you can point and click a mouse, you can use Bytecent.
In addition to eliminating the complexities associated with cryptocurrencies, Bytecent aspires to be the first cryptocurrency to make use of old and new media to educate both merchants and consumers on the numerous benefits of using Bytecent.
Join the Bytecent revolution and be part of the future of crypto and financial transactions as we know it!
O developeru..
http://coinblab.com/forums/topic/29/introducing-christopher-bouzy-aka-iconic-expert
Oficijalni forum
http://coinblab.com/forums/12/bytecent
Specifikacija
Ticker: BYC
Total Coin Supply: 33,000,000
Crowdfund: 3,000,000 coins
Algorithm: Prime Six
Mining Duration: 57 years
Block Reward: 1 Bytecent
Block Time: 60 seconds
Difficulty Retarget: Every block
Confirmations: 3
Maturity: 200
Timestamping: POW/POM
Bittrex Menjačnica
https://bittrex.com/Market/Index?MarketName=BTC-BYC
Novčanik (Wallet)
http://bytecent.com/download/bytecent.exe
Preporuka - Novčanik startujte sa wallet.exe ("hiden") (C:\Program Files (x86)\Bytecent) ne preko originalne ikone. "Sticker" pri startovanju menja bytecent.conf file, pa je bolje da imate vaš. Evo i svežeg (redovno osvežavan) http://pastebin.com/F74MZCfD
Problemi sa konekcijom walleta.
Do sad sam probao razne stvari. Ono sto je najvise pomoglo je da na vašem ruteru ili modemu ili sta god korisite, ukljucite "UPnP" Opciju.
Takodje je potrebno da i u Windowsu bude ukljuceno. Za Windows7 je uglavnom vec podeseno za XP mora da se dodano podesi.
Link kako proveriti/podesiti http://www.computerhope.com/issues/ch001367.htm
Majning PoM
Ideja majnovanja Coina (PoM - Proof of Mining) je da je na svakih ~sat vremena potrebno kucati "captcha" kod i tako nastaviti majnovanje. Ideja je da se izbegnu farme, serveri, itd..
Ukoliko u novčaniku imate preko 600 coina, kod se kuca na 24 sata.
IE samo apeluje da se povuku pare sa menjacnice na novcanik.
Moguce da oce da navuce da svi povuku, jer ce i onako veceras da banuje stare wallete, a onda ce da izbaci novi wallet i moze da naprave pump,
ali zbog novog walleta nece biti moguce da se ekspresno reaguje i koini posalju na menjacnicu, jer nece niko imati konekciju.......
To mi pada na pamet....
kad ce da se izbaci novi novcanik, zakazano neko vreme?
Odlozeno za 5 dana dok se ne resi situacija sa nodovima. Pise u vesti.
O developeru se inace moze svasta procitati:
https://bitcointalk.org/index.php?topic=645899.0
https://bitcointalk.org/index.php?topic=855217.0
itd, itd, da ne kopiram sad na desetina slicnih linkova ...
Ne planiram i necu ni da ga branim ni da ga blatim. U svakoj prici postoji i druga strana koju je uvek pametno cuti/procitati. Nadam se da si procitao to sa tog linka.
U sustini, ne zanima me nijedna strana. I on kao i svi mi trazimo profit i ne bunimo se kad uzmemo "pare" i pritom zgazili bar 3 čoveka.
tacno svakoga interesuje lova i za kojntelekt isto pisu dok god mi zaradjujemo briga nas, treab iskoristit dok se moze sta nakopat, pa cemo traziti nafaku negdje drugo 😉
Da li bi trebao odmah u startu da hvata konekcije ili? Buduci da nemam konekciju.. (PS aktiviran UPnP)
jel ga zavaljujete ili cuvate
... otvori valet sacekaj 2-3 min, ako nema zatvori pa opet otvori
Ja sam juce zavalio nesto dok je bio pik. Ko zna sta sprema IE a ja nebi da se opecem kad vec mogu nesto da zaradim.
Sto se tice konekcija nekad mu puno treba da bi dobio jednu bar je tako prvi put.
na koliko si ga zavalio, ja imam 10 komada verovatno se ne isplati jos da prodajem, bar da imam 20-30 komada pa aj da prodam
Da li vredi kopati sa celeronima (G530, 1610 ...) .
ByteCoin (BYC)
Ne, diff je prevelik i za fx 8350 a kamoli za te celerone...
Edit: Ako moze da se napravi edit teme i jos nekih delova...u pitanju je Bytecent, a ne Bytecoin...koliko ja znam Bytecoin je drugi novcic, ne ovaj o kome pisemo ovde... 🙂
ok, moze da se proba, ali da li vredi....mislim da ne 🙂
Ma jok, nece da uhvati konekcije. Vidi ga u ruteru kao upnp konekciju, al nece...
Posteno i ja od danas opet imam problem. Ali sad vise nemam pojma sta je u pitanju.
jedan nod mozda pomogne malo addnode=178.62.93.243
Ja sam se kacio sat i evo opet se nakacio treba biti uporan 😀
Imam 26 konekcija aktivnih i od 12 sati danas 3770k nije napravio ni jedan jedini coin.
A pre toga cepao po 40 dnevno.
Nesto se smrdljivo trenutno desava...
bice da nemamo ''srece'', ali i kod mene taj period bio prazan...sada sam otvorio jedan...posle 6 sati
    6.3 KB · Pregleda: 93
Koji config fajl se edituje, u instalacionom folderu ili onaj u appdata/roaming?
Kako sam uspeo konekcije, za 10 sekundi dva komada izmajnovao 🙂
Edit: 3 😀 Ali opet izgubio konekcije...
Kod mene, neće da se poveže nikako.
Može li neko, ko ima konekciju, da zapakuje bytecent folder iz roaming-a?
Bez wallet.dat, dakakako. 😀
