Znači da očekujem isto na btn-u, dobio je skoro od mene pozivnicu za btn... Samo da mene ne banuju, neka mi i oduzmu pozivnice. Uz to goxxxy dobio pozivnicu pre 8 dana i do sada 0kB traffic. A pitaju me ljudi što ne dajem pozivnice, posle ovoga nikome neću ni davati.
Cekam seedbox necu kvarim ratio odmah. a moze se videti da ne varam niti sam ista snatchovao...
Downloaded: 0.00 B
Snatched: 0 [View] [Download]
Leeching: 0 [View] [Download]
On BTN we do not enforce a ratio requirement on our members. We do however require that you Seed torrents back to at least the minimum time requirements for that torrent type; OR to a ratio of 1:1 within 2 weeks. Seed time starts from when you have fully downloaded all files in a torrent. Failure to do so will result in a Hit & Run (H&R). A H&R Reference document has been created to explain both the Seeding Requirement rules, H&Rs and what happens if you attract a H&R in more detail; its available here.
Seeding Rules:
1) Seed all individual Episodes for 24 hours or 1:1 ratio.
2) Seed all Season Packs for 120 hours or 1:1 ratio.
3) You must meet the minimum seed time OR ratio requirements within 2 weeks from commencing your download.
4) Until you meet the Seeding Requirements, you must seed at least a little every 12 hours.
5) Seeding torrents will not show as a H&R.
6) Torrents will not be considered a H&R if you download less than 10% of the total torrent (As registered by the site)
7) As long as you keep a torrent that you have snatched active, a bonus based on size, length of seed-time, and number of seeders will be applied for you to purchase items from the bonus point store.
8) You must meet ALL the Seeding Rules otherwise you will attract a H&R, the consequences of which are:
8.1) If you attract ANY H&Rs you will cease earning ANY Bonus Points while you have one or more H&Rs.
8.2) If you attract ANY H&Rs you will be ineligible for a promotion or participating in any competitions.
8.3) If you attract more than 15 H&Rs your account will be banned.
8.4) If you consistently attract or retain H&Rs your account may be warned or banned.
8.5) If you have been warned for H&Rs, and you attract additional H&Rs your account will be banned.
Please refer to the EYN2K: HnRs and Seedtimes Knowledge Base article for a more detailed description of the seeding rules, H&R rules, and the consequences of violating them.
haha ja udelio 100ak hd-bits.ro pozivnica a mene obrisase izgleda zbog neaktivnosti ne mogu se ulogujem, a ima osam zverski ratio sa hiljadam pozivnica, jel su menjali nesto u zadnjih mesec dana od pravila?
U početku skidaj samo iz Archive i Foreign jer je tamo sve freeleech.
Freeleech važi za cele sezone serija i pakovanja filmova, nije neophodan box za opstanak.
Ako ce skidati ono sto je na freelech onda mu uopste nije potreban box ali za pojedinacne filmove i serije, xxx i ostalo bogami hoce mu trebatii...
KOMPLETNA muzika (od 500-750gb mesecno - FLAC nisam racunao u to) [I jos muziku mozes skidati po zanrovima, cak i po onim koji nisu izlistani (ako nekom treba tip neka mi posalje PM za to)], FLAC, 0day/APPS, MVID (video spotovi) i kompletna ARHIVA kao i FOREIGN sekcija. Mp3 svaki album je seedovan prosecno sa 30 seedova od kojih su 70% seedbox. ARHIVA tj pakovi su podeljeni na Movies/Packs, TV/Packs , Games/Packs, XXX/Packs i Music/Packs. Evo kako izgledaju packovi za filmove:
koliko sam skapirao te bonus pozivnice se drugacije gledaju iz one novosti pa se klikne nisu valjda standardne...ispravite me ako gresim...
2) Bonus invites for everyone. You will be receiving 1-4 bonus invites to invite your friends and family. The invites will expire on November 1st. Click here to use your bonus invites.
RasaNS ti si car, nema sjajna je ova zajednica![]()
Za hdb cu odgovoriti samo onima koje mozda planiram da invite-ujem3xhdbits.org
2xscc
5xipt
3xthr
3xbalkanelite
2xgormogon
7xtd
5xbithdtv
3xhdt
4xbrokenstones
4xmma trackeru principu ne verujem da cu ih podeliti,ali ima ih 4 za sad,s tim da jednu cuvam za svaki slucaj,a ostale tri su tu.
Mali? Možda "nano IPT" pošto je od "velikog" udaljen svetlosnu godinu.Nemam opciju da promenim gornji post...
Scenetime is open for signups for the next 24 hours. They're a general tracker, with TV, movies, games, etc. Approx 65,000 members.
http://www.scenetime.com/
Mozda nije los generalni da se proba, ima seed bonus...
Evo sad sam nasao da ga zovu i "mali IPT" i da je owner isti...
Kada će biti otovren HDBits.org za slanje pozivnica?? Ako može i meni jedna pozivnica za HDBits.org bio bih zahvalan. Mogu "podastrijet" mnogo torent tacker-a i buffer.
Svidja mi se sto vise vrednuju seedtime nego ratio. Stajem I ja u red za hdbits I obecavam da cu za 3-4 meseca steci uslove za deljenje pozivnica I u znak zahvalnosti po tvojoj preporuci podeliti ovde najmanje jednu. Nemam box Ali htpc je 24/7 online na 24/24 Mbs.
Proof pored ostalog Sa SCC, PTP,KG,ILC...
