Sony Xperia Z3
blue moon
Banned
Banovan
Najvljen je na Gsmareni
Also known as Sony Xperia Z3 D6653
General 2G Network GSM 850 / 900 / 1800 / 1900
3G Network HSDPA 850 / 900 / 1700 / 1900 / 2100
4G Network LTE 700/800/850/900/1700/1800/1900/2100/2600
LTE 850 / 900 / 1700 / 1800 / 1900 / 2100 / 2600
SIM Nano-SIM
Announced Exp. announcement 2014, September
Status Rumored. Exp. release 2014, Q4
Body Dimensions 146.5 x 72.4 x 7.4 mm (5.77 x 2.85 x 0.29 in)
Weight 158 g (5.57 oz)
- IP58 certified - dust proof and water resistant over 1 meter and 30 minutes
Display Type IPS LCD capacitive touchscreen, 16M colors
Size 1080 x 1920 pixels, 5.2 inches (~424 ppi pixel density)
Multitouch Yes, up to 10 fingers
Protection Shatter proof glass
- Triluminos display
- X-Reality Engine
Sound Alert types Vibration; MP3 ringtones
Loudspeaker Yes, with stereo speakers
3.5mm jack Yes
Memory Card slot microSD, up to 128 GB
Internal 16 GB, 3 GB RAM
Data GPRS Up to 107 kbps
EDGE Up to 296 kbps
Speed HSDPA, 42 Mbps; HSUPA, 5.8 Mbps; LTE, Cat4, 50 Mbps UL, 150 Mbps DL
WLAN Wi-Fi 802.11 a/b/g/n/ac, dual-band, Wi-Fi Direct, DLNA, Wi-Fi hotspot
Bluetooth v4.0, A2DP
NFC Yes
USB microUSB v2.0 (MHL 3), USB On-the-go, USB Host
Camera Primary 20.7 MP, 5248 х 3936 pixels, autofocus, LED flash
Features 1/2.3'' sensor size, geo-tagging, touch focus, face detection, image stabilization, HDR, panorama
Video 2160p@30fps, 1080p@60fps, 720p@120fps, HDR
Secondary 2.2 MP, 1080p@30fps
Features OS Android OS, v4.4.4 (KitKat)
Chipset Qualcomm MSM8974AC Snapdragon 801
CPU Quad-core 2.5 GHz Krait 400
GPU Adreno 330
Sensors Accelerometer, gyro, proximity, compass, barometer
Messaging SMS (threaded view), MMS, Email, IM, Push Email
Browser HTML5
Radio FM radio with RDS
GPS Yes, with A-GPS, GLONASS
Java Yes, via Java MIDP emulator
Colors Black, White, Amber
- ANT+ support
- SNS integration
- TV-out (via MHL 3 A/V link)
- Active noise cancellation with dedicated mic
- Xvid/MP4/H.263/H.264 player
- MP3/eAAC+/WAV/Flac player
- Document viewer
- Photo viewer/editor
- Voice memo/dial
- Predictive text input
Ne pise kolika je baterija,ali ovo je maltene Z2 kopija.
S preda dosta lici na iPhone a sa strane je isti Lumia 925.
Iskreno ne vidim svrhu postojanja ako se uzme u obzir kad je izasao Z2, kako izgleda Z2 i to da su specifikacije gotovo identicne. Sony mi nije jasan, jer i pored price da ce proizvodjaci na pola godine da izbacuju flagship modele to za sad samo i jedino Sony radi.
Ako postoji stvar koja me izuzetno nervira kada je fizički dizajn telefona u pitanju, to je kada iznad i ispod ekrana ima isti ram kada je simetričan u odnosu na istok zapad presek. Ne zna se gde mu je dupe a gde glava. Zato mi se G3 sviđa neviđeno, kao i gpro2 ili ovi novi sharp aquos.
Makar ce oboriti malo cenu Z2 kad se pojavi...ili su mozda kameru jos popravili pa sad daje slike bolje i od Z2.Ne znam koji im je glavni adut ovog modela...
inace ne vidim neku ovog modela kada je gotovo isti kao i Z2 samo su dimenzije "nesto manje" i malo kloknuli cpu... Jedino ako su resili problem sa pregrejavanjem i onim problemom sa punjenjem preko magnetnog porta na koji su se neki korisnici zalili...
Z3 - 146.46 x 72.09 x 7.3 mm
Od nekih novina Z3 bi mogao da ima - novi, zakrivljeni senzor 1/2.3'' koji moze da omoguci tanje kuciste telefona (mozda je bas zato debljina smanjena na samo 7,3mm), malo bolje zvucnike, svetliji ekran (pominjalo se i novo dragont. staklo koje smanjuje refleksije i pruza bolju vidljivost na jakom suncu) i jos neka mala poboljsanja Z2 uz malo manje dimenzije. Ako vec ostavljaju S801 bitno je da ne idu na nebuloznu 2k rezoluciju, to bi bio promasaj za ovaj telefon (slicno kao kod G3). Z2 je jedan od retkih telefona sa 3Gb rama i umerenom kolicinom bloat-a tako da istu kolicinu na Z3 ne vidim kao problem.
Ali ako nista drugo bar ce dodatno da obori cenu Z2.
Z3c (realnije Z2c :d) bi mogao da bude pun pogodak.
prelazak sa g2 na g3 i nekako moze da se proguta (ali nepotrebno)...
Z2 na Z3 nikako, bukvalno se dobija isti telefonon, samo malo "doteran", ali i to sto su doterali cini mi se bar dok ne izadje na videlo, ne opravdava izbacivanje Z3- sem eventualno ako nisu odlucili da peglaju hardverske brljotine kod Z2 (mada pregrevanje kamere u 4k moze da se ispegla softverski)....
ne vidim cemu ovo stancovanje "flagshipa" na 6 meseci ako ce izbacivati isti telefon samo "malo poboljsan" ili pak alpha/beta uredjaj poput G3 koji ce tek sledecom verzijom (ili pak 3. iteracijom) da bude na mestu...
U svakom slucaju u pravu si HSV, compact varijanta je bolje resenje, mada mislim da ce biti cak i skuplja od Z2 kojoj ce sigurno pasti cena (z1 je vec oko 350e i osim losijeg ekrana i mozda cipseta u odnosu na z2 uopste nije los telefon)...
Z2 za oko ~380e krajem godine uopste ne zvuci lose, cak ce mozda biti i bolja kupovina od Neksus 6 i IP6 (za taj novac), naravno minus brzi apdejti... Pitanje je samo hoce li se Sony pridrzavati 18meseci apdejt podrske za Z2...
Blago ''osvezena'' verzija Z2.. nista vise od toga.
Mada realno u ovom trenutku od tih kvazi-inovacija bi mogao da ima S805 i 2k displej koji bi to ugusio pa bi performanse manje-vise bile iste kao S801 i 1080p ekran a uz 805/2k bi morao da ima i bar 3600 mAh bateriju da bi imao autonomiju kao Z2.
Mnogo bolji potez bi bio S805, jos bolji IPS 1080p, 3Gb rama i ako moze jos bar 200 mAh veca baterija. To je u praksi bolje resenje od trpanja 2k uz s805.
Ali sve to vezano za revizije cipseta, rezoluciju ekrana su kvazi-inovacije na koje mogu da se loze xda deca, indijci, pakistanci koji ne znaju engleski ali znaju da pisu po netu (na njihovoj verziji engleskog) kako G3 ima najbolji ekran na svetu samo zbog 2k :d
Za mene bi bile prave inovacije kada bi se neko konacno potrudio da napravi/ugradi nesto korisno - npr jos otpornije staklo sa ''anti-glare'' osobinama pa bi vidljivost na suncu bili sjajna cak i sa niskim osvetljenjem ekrana, pa onda neke jos bolje tehnologije vezane za kameru-kamkorder (mada tu sony nesto i radi), zatim kvalitetni mikrofoni kao haac na nokiama a zato ne i jos bolji (i dovodjenje audio kvaliteta pri razgovoru na jos visi nivo mada to zavisi i od kvaliteta mreze), poseban audio cip/dac/amp koji bi mogao da napravi primetnu razliku u odnosu na sve do sada pa onda neka nova tehnologija baterije i jos veci kapaciteti.. zasto ne i xenon+dual led kombinacija, bolji OIS, IP68..
I naravno ono najbitnije - softver, dzaba sva jezgra, sinteticke brojke ako je softver krs.
To je mnogo korisnije u praksi od pumpanja nebuloznih antutu rezultata i druge sintetike i forsiranja samo snapdragon cipseta koji na svakih 6 meseci dobija novu, malo brzu verziju. Ali situacija je takva da se ljudi vise lepe na te sintetike i brojke, 2k rezolucija je sada pojam ''inovacije'' a koja hiljada vise u smesnom sintetickom testu statusni simbol xda decice :d
Z4 ce verovatno odmah ici na S810, 4Gb rama, 2k ekran i slicno ali opet se sve to vrti oko nebitnih brojki, ne znam sta ko moze da ima od toga.
Sony za početak nek ugradi sočivo koje ne muti fotke, za ostalo ćemo lako 🙂
^ a ne smeta ti to na K Zoom koji muti jos vise :d
A pitanje je da li je to do sociva na oba telefona.. pogledaj u dprev. testu, S4 manje muti po ivicama cak i od 1020/808 ali je i fov dosta manji.
Apsolutno potpisujem...
Pre svega poboljsanje samog Androida nije na odmet, bas u tom pravcu dodatne optimizovanosti i manje potrosnje, od strane Sonija a i drugih kompanija (Samsung, LG, Htc...) ali i pre svega vanilla verzije...
Realno sa 1080p ekranima i S800/S801 cipsetom Android bi mogao da radi i podrzava nove verzije Androida naredne 3 godine, hardver je i onako vec dovoljno mocan i dalje budzenje na 2,5ghz+ je apsolutno izivljavanje...
No to se radi kako bi se "average Joe" nalozio i kako bi imalo svake godine da se proda kontigent "novih, poboljsanih" flagship modela... Voleo bih da prsne taj baloncic ali tesko da ce do toga doci...
Kako se odvija situacija na trzistu cak mi onaj sistem koji je praktivao LG pre par godina deluje sve realnije... Apdejt "podrska" od 6 meseci ili pak bez iste, tako da cemo morati da kupujemo/menjamo telefone na svakih godinu dana kako bi mogli da imamo novu verziju androida (ne racunajuci resenja xda zajednice)... Cak sta vise cini mi se da bi nekim "potrosacima" to bilo kao dobar da...
Zar Sony nema problema softverske prirode sto se toga tice? 🙂 Cak i njihov DSLR segment pati od te boljke, imaju najbolje senzore (koje koriste Nikon i Canon ako se ne varam) ali je implenetacija istih mnogo losija od konkurencije (dok je video zapis bolji)... Ili se pak varam? 😀
Pa do čega može da bude? I oni u testu kažu da je do sočiva, samo se ograđuju da je možda do test primerka, ali svima su takve slike tako da nije do samplea... Z1c ista priča
Tesko da ce do toga doci, dovoljno je odvojis pola sata za citanje stavova/misljenja/komentara po netu, raznim forumima (bogami i na ovom) i bice ti jasno da od toga nema nista.
Inace se slazem sa tim sto si napisao.
Bas me zanima koji izgovor ce biti za prestanak apdejtovanja telefona sa s800/s801 i 2/3Gb rama, sta kao nece moci da podrze novu verziju androida? :d aj to je ranije i prolazilo jer je logicno da raspad single core 512Mb telefon nece moci da radi krsteno na ics/jb ali sada takvi izgovori samo mogu da budu smesni.
Pocela je malo da me nervira ova prica oko snapdragona, kao da samo taj cipset postoji. Jeste dobar ali kao da je sve pocelo da zavisi od toga kada ce oni da izbace 6 meseci noviju i malo brzu verziju. Licno mi je Exynos mnogo gotivniji ali sta vredi kad se nalazi samo u nekoliko telefona, sa intelom i ostalim nemam pojma sta se desava.
Zar Sony nema problema softverske prirode sto se toga tice? Cak i njihov DSLR segment pati od te boljke, imaju najbolje senzore (koje koriste Nikon i Canon ako se ne varam) ali je implenetacija istih mnogo losija od konkurencije (dok je video zapis bolji)... Ili se pak varam?
Mislim da Nikon koristi njihove senzore, moguce da su ranije imali te probleme ali koliko vidim u poslednjih par godina su broj 2, iza Canona generalno (kada se sve klase uzmu u obzir) mada Nikon i dalje ima bolje dslr (sisteme).
Mislim da su u poslednje 2-3 godine sony kamere su pokidale, od RX10/100 do alpha mirrorless/dslr 🙂 Sto uostalom govore i prakticno svi ozbiljni testovi.
@ Vojkan, nemam pojma, wide angle, softver.. mozda i socivo, ko zna. Stvarno u njihovom testu a i u jos nekim S4 i slicni imaju manje zamucenja po ovicama od svih wide angle kamera sa telefona pa cak i od 1020/808.
Ista ona prica koju je servirao OPPO pre neki dan vezano za prestanak podrske za svoj FIND 5 model (HW isti kao N4 i XZ), ili pak one price o HTC One S-u ako se ne varam...
"as the company confirmed it will not push an update to Android 4.4 KitKat. Qualcomm hasn't provided the hardware binaries for the Snapdragon APQ8064 chipset to run Android 4.4."
http://www.gsmarena.com/oppo_find_5_wont_see_android_44_kitkat_update-news-9432.php
^ show, to je pre neki dan napisao razbojnick:
Dobio je. Isti čipset kao što ga ima Oppo Find 5, a koji neće dobiti KK zato što Oppo tvrdi da Qualcomm nije objavio drajvere.
Znaci Xperia ZR ima 4.4 apdejt a Oppo stav je da qualcomm nije objavio drajvere pa ne mogu da zbudze apdejt :d
offtopic ali eto... Primer Lumie 1020, bacih pogled jutros, u AT-u (geizhals.at) se doticni flagship model moze naci nov za 320-350e, nov... 925 za 235e... Bruka... Z1 kao sto rekoh ~320e.. najezio sam se.. Zamisli da si dao 500+ evrica za te telefone kada su se pojavili i za manje od godinu vrede 1/3 cene...
Takvom politikom kojom se vode je veliki plus za nas (razumne) kupce jer mozemo posle 8 meseci da kupimo odlican telefon po drasticnoj, manjoj ceni. Telefon(e) koji je realno i dalje zverka i koji moze biti "aktuelan" 3 godine, ali koji je vestackim putem stavljen u "obsolete" kategoriju zbog ukidanja podrske od strane OEM-a posle odredjenog vremena...
U svakom slucaju ne vredi vise kupovati telefone cim se pojave, niti davati vise od 300-350e... Sacekati 6-8 meseci i onda kupiti nov za skoro upola cene je mnogo razumnije na ovom nenormalnom trzistu telefona, vodjeno nenormalnom politikom alavih kupaca koji jure spec-ove a ne telefon...
Sony je uspeo da znacaj flagshipa dovede na nivo konfekcijskih telefona koji se stancaju svaka tri meseca i svi isto izgledaju a cesto imaju i isti softver. Nije ni cudo sto retko ko bira Sony flagship, niko ne voli da bude ovca. LG je posle njih najgori ali oni bar promene izgled telefona, povecaju ekran, stave bolji hardver toliko da se moze reci da ima razlike. Ovde neke razlike i nema u odnosu na Z2.
LG promeni izgled telefona ali u odnosu na prosli flagship degradira autonomiju za jedno 40% i ugradi ekran sa najlosijim kontrastom u klasi koji u isto vreme ima slabije osvetljenje od svog prethodnika G2. A da ne pricam o kombinaciji s801/2Gb rama sa 2k rezolucijom. Z3 ako nista drugo bar nece imati tako drasticno nazadovanje autonomije i losiji panel kao sto je to slucaj kod G3. Da je nepotreban kao model - jeste ali bar nece otici korak u nazad sto se tice dve veoma bitne stvari (autonomije i ekrana).
Meni ipak to deluje da izbacivanjem Z3 peglaju neke harverske propuste Z2 (kao sto rekoh, "mozda" kamera i onaj falicni magnetni prikljucak za bezicno punjenje) ... mozda se i varam..
Ovo! Jedini zakljucak je da je ovaj telefon NEPOTREBAN! Dakle apsolutno nema nikakvu svrhu, nije mi jasno ovo izbacivanje naslednika svakih 5-6m, ko ce da kupi njihov flagship ako zna da ce za pola godine da izadje "pobolsana" tj. verzija koja ispravlja sve probleme iz proslog flagshipa? Ali samim tim donosi i nove koji ce gle cuda da isprave za pola godine.
Sony sto se telefona tice ne zna gde udara.
@Emix
Realno nije li situacija sa tim peglanjem flagship modela ista i kod drugih proizvodjaca telefona-samo se "poboljsane" verzije izbacuju na ~12 meseci, ali isto se javljaju/imaju "falinke"...
S'tim sto Sony celu tu pricu podize na jedan drugi nivo... A ni LG nije bolje prosao sa G3-ojkom...
Cela prica ka cemu trebaju da se okrenu OEM-ovi stoji u hsv-evom postu, jednu stranu unazad... Ali takav sistem ne bi donosio profit... Guraj masi ono sto trazi,moto "uzmi pare i bezi"-HTC/LG pre neku godinu, jesmo li vec zaboravili?
Naravno da je nepotreban.
Neminovno je da će i ostali proizvodjači izdavati "nove" modele na svakih pola godine, Soni je samo odlučio da prvi krene u tu glupost.
Nisam u njihovom upravnom odboru 🙂)) ali rekao bih da tako stoje stvari i da su im to motivi.
Odgovor na crveni quote je da ovaca uvek ima i ljudi su uvek kupovali nešto zato što je "novo" i "najnoviji model".
uze mi reci iz usta, taman sam hteo da dodam da li zaista misli da i drugi nece da se vode istom politikom...
Bez uvrede Emix, ali imam osecaj da ti se posebno nesto "kruti" kada se spomene Sony... 😀 realno sve su to ista g***, profit na prvom mestu, hebe se njima za nas korisnike... Sve je cist marketing danas...
Samsung je recimo odmah posle S5 izbacio verziju sa S805 i 2k ekranom za domace trziste. Pa nesto nisam primetio da su ljudi kukali :d ali to je telefon koji nema nijednu vecu manu u odnosu na obican S5 (koji nikako nije savrsen), cak je i autonomija slicna sto nije slucaj sa G2 vs G3, znaci Samsung je odradio dobar posao. Isto kao sto je sony konacno odradio dobar posao sa Z2 pa ce i Z3 biti jos za malo bolji i bez vecih mana kao ni Z2 (sto ne znaci da ce biti bez mana).
Ko kad izbacuje telefone.. u sustini me boli uvo, to sto ce Z4/c poceti da se prodaju na prolece samo moze da znaci da ce Z2/Z3(compact) i slicni brze doci do cifre koju mogu i hocu da platim za jedan telefon (350e plafon) a za patkometrije u sintetikama, 2k, ko kad izbacuje telefone itd me zabole 🙂
2 posta iznad mushmular je lepo ''citirao'' sta sam napisao na prethodnoj strani, sta su prave inovacije a sta sviranje ..... u sta se pretvara ceo android segment a bogami i wp8/ios idu ka tome polako.
Samsung je recimo odmah posle S5 izbacio verziju sa S805 i 2k ekranom za domace trziste. Pa nesto nisam primetio da su ljudi kukali :d ali to je telefon koji nema nijednu manu u odnosu na obican S5 (koji nikako nije savrsen), cak je i autonomija slicna sto nije slucaj sa G2 vs G3, znaci Samsung je odradio dobar posao. Isto kao sto je sony konacno odradio dobar posao sa Z2 pa ce i Z3 biti jos za malo bolji ali bez vecih mana kao ni Z2.
2 posta iznad mushmular je lepo ''citirao'' sta sam napisao na prethodnoj strani, sta su prave inovacije a sta sviranje k... u sta se pretvara ceo android segment a bogami i wp8/ios idu ka tome polako.
cek cek... Bese to ono i9500 pa onda i9505? i sada ovo sto su uradili sa ovom s5-icom na "doradjenju" sa 2k ekranom i malo brzim procesorom? 🙂 ili pak note 3 i njegove 2-3 "lite" verzije?
Ni ja se nesto ne secam kako je to krenulo...Ali izgleda da kada Sony krene takvim modelom onda drvlje i kamenje... 😀
Ne razumite me pogresno, nikog od proizvodjaca ne mirisem posebno, sve su to ista... Uvek gledam da uzmem/izvucem najvise sto mogu za odredjenu svotu MOG novca...
I na kraju me pak i zabole, mozemo posle 6-8 meseci da kupimo flagship po mnogo manjoj ceni... Bitno mi je da sam telefon nema neke probleme u startu i da moram da se cimam za reklamaciju jer ocekujem da cu neki uredjaj koristiti barem ~2 godine...
I bolje da se okrenu boljoj sofverskoj podrsci i optimizaciji nego da gruvaju specifikacije do besvesti a da je pritom OS i dalje kanta... Jedino razlog zasto skidam kapu iOS-u i WP, iako su limitirani rade glatko i na low end a i high end segmentu (kod IP podrazumevam "low end" starije generacije uredjaja)
Ovi su prsli totalno, pa 3 skoro identična telefona u godinu ipo izbacili.
@ mushmular ^ e al tad se ne racuna :d
Koristim Samsung telefone vise od 10 godina i potpisujem da je to proizvodjac koji je imao/koji ima najvise verzija prakticno jednog istog telefona i najveci broj telefona ikada. Bez premca. U stvari i LG je tu negde. Neki su (bili) samo za Aziju, neki se prodaju globalno. Koliko su izbacili istih telefona ''na preklop''/slajder sa bukvalno istim karakeristikama uz male razlike u ekranima i dizajnu. Sve to su nastavili bombardovanjem sa galaxy androidima kojih ima mali milion, pa cak i phableti imaju vise verzija (note).
Ali kao sto rekoh, kao i uvek prosto me ne doticu takve stvari, pokusacu kao i uvek da nadjem najbolji uredjaj za 350e i to je to samo je problem sto se kao i do sada izbor svodi na najvise 3-4 proizvodjaca (mislim na sve sisteme).
A stvarno mi je najjace kad se na hiperprodukciju, ispravljanje sitnih mana, cene, nedostatak unapredjenja itd zale ljudi koji u svemu tome ucestvuju tako sto na svakih 6 meseci kupuju telefone po full cenama koji su mizerno unapredjeni u odnosu na prethodne verzije :d
