Samsung Galaxy S5 Active
hsv.stoned
- Audio Guru -
CPU & Cooler
AMD RYZEN 7 2700/LC-CC-120
Matična ploča
MSI B450 Tomahawk Max
RAM
Kingston HyperX Fury 32GB (2x16GB) DDR4 3200MHz (CL16)
GPU
Sapphire RX 580 Pulse 8GB @1440/2200 MHz
Storage
Kingston A2000 M.2 NVMe 500GB, Toshiba P300 3TB, WD Black 750GB, 2 x WD Blue 10EALX 1TB
Zvuk
FiiO K5 Pro + Beyerdynamic DT 900 Pro X/Fostex TR-90/Sennheiser HD650/AKG K240 Sextett/PreSonus HD7/ATH-CKX9/SFR DT6 | 2.1 50W + FiiO E10k
PSU
Cooler Master G550M
Kućište
Cooler Master Mystique 632s Black & Silver
Monitor
GIGABYTE G27Q & AOC i2481FXH
Miš & tastatura
Asus ROG Chakram wireless & ROG Strix Scope RX, Logitech MK320 wireless
Ostale periferije
Cube Reaction Pro
Mobilni telefon
Xiaomi 14 Ultra 16/512GB Black & Sony Xperia™ XZ2 Liquid Black
Pristup internetu
  1. Kablovski internet
  2. Mobilni internet
http://www.gsmarena.com/samsung_galaxy_s5_active-6356.php
http://www.gsmarena.com/samsung_announces_galaxy_s5_active_for_at_t-news-8653.php
http://www.phonearena.com/news/Samsung-Galaxy-S5-Active-now-available-from-AT-T_id56659#2-
[YOUTUBE]TBJQejh11dw[/YOUTUBE]
Despite rumors that the phone would be IP68 certified, it turns out that the Samsung Galaxy S5 Active has the same IP67 certification that the regular Samsung Galaxy S5 has.
Sto se izgleda tice nemam komentar, kao da je iza i sa strane samo slepljeno nesto na njega. A coskovi... :S:
S4 Active:
Da ali je ovaj je jos vise ojacan, nema dzabe ovakvo kuciste 😉
The body is water, dust and shockproof with its IP67 and MIL-spec 810G certification. The standard Galaxy S5 was already two of those things but some people will definitely appreciate the extra peace of mind that comes from a ruggedized phone.
Znaci pravi outdoor telefon koji ima sve isto kao S5 osim senzora za otisak prsta koji je apsolutna glupost. Meni je ovo do jaja, bukvalno idealan telefon, sve osim dizajna ali meni je i ovo bolje od nakaze aka S5 🙂
A sigurno je otporniji na padove od Z2.
Znaci IP67 (2) zastita, steta sto nije IP58 sto bi znacilo da je jos bolje zasticen od vode ali i ovo je dovoljno.
[YOUTUBE]U4t-YI_IGOU[/YOUTUBE]
[YOUTUBE]GpQry0Zrm8A[/YOUTUBE]
[YOUTUBE]3aOJoqgUXmA[/YOUTUBE]
Za ovakav dizajn mogu da kazem da je tuga sto ima samo IP67 sertifikat... Morao bi da ima IP68 sa ovakvim dizajnom. Pa S4 Active je pravi lepotan za ovaj S5 Active...
Pa S4A izgleda manje nabudzeno jer je i manje zasticen (na dimenzije sigurno utice i veci ekran/senzor kamere).
Pogledaj sta sam sve postavio (shock resist. i IP67 2). To je pametna odluka kad su vec hteli da izbace Active verziju jer da nema te bolje zastite koja bi razlika onda bila u odnosu na S5?
Ali slazem se da su trebali da idu na IP68, cini mi se da je zastita od vode bukvalno ista kao na S5, IP je isti ali ne mislim na to nego na detalje koji stite od vode, zastita na poklopcu baterije sa unutrasnje strane a sam taj poklopac je izgleda imitacija tj izgleda ima ove imitacije srafova, to je bezveze. Cak je i zvucnik isti a na S5 tu prolazi voda..
Ali bez obzira ovaj fon je za sada najpriblizniji onome sto bih kupio, steta za dizajn ali ne izgleda bas toliko lose, moze da prodje. Zato su specifikacije odlicne pa cak nema ni tupavi senzor za otisak prsta sto je + za mene.
Nije ovo telefon za neku epsku prodaju i veliki broj ljudi ali ovako nesto definitivno treba da postoji kao i ostali sa IP zastitom.
Ovo pise za zastitu
- IP67 certified - dust and water resistant up to 1 meter and 30 minutes
- MIL-STD-810G certified - salt, dust, humidity, rain, vibration, solar radiation, transport and thermal shock resistant
Dobar video.
[YOUTUBE]c6dz0e90RbU[/YOUTUBE]
Sem hardvera, koji je dosta bolji nego na S4 Active, koga inače ja imam od prošlog septembra, drugo ništa nije toliko poboljšano.
Zaista je morao da dodje sa IP68 sertifikatom.
Meni ovaj Active S5 mnogo bolje izgleda nego standardni.
Pa da, bolji dizajn koji odgovara jednom outdoor telefonu a i deluje da je kvalitetnije izradjen (a i jeste jer je otporniji na padove i slicno). Cak i nije mnogo unakazen koliko je zasticen, definitivno ima prepoznatljiv izgled za razliku od S5 stroke.
Koliko je odvratno ''stvorenje'' ovaj iz PA.. :smash:
[YOUTUBE]4VZ_mjqxQGE[/YOUTUBE]
Vrh fon.. sivi i onaj camo zeleni deluju najbolje. Sto se mene tice kao jedinu vecu manu vidim to sto je stabilizacija videa dosta losa, po YT kazu i da je fon dosta klizav (mogli su da gumiraju ovaj poklopac) i ove razne imitacije po kucistu smetaju.. previse laznih detalja. Morao je da bude ili bolje zasticen (IP68) ili bez tih detalja. Sve ostalo je odlicno.
Danas sam u nekoj ''dzungli'' bukvalno zamisljao da imam ovaj fon. S4A je posle godinu dana po oglasima nov oko 340e.. nadam se da ce i ovaj brzo spasti do te cifre.
[YOUTUBE]JBB7IYx7GWc[/YOUTUBE]
[YOUTUBE]z3B5xyXY4tA[/YOUTUBE]
[YOUTUBE]xTT6g0u6DUE[/YOUTUBE]
merkaš ga opasno 😀
oćeš uzimati?
Nemam pojma, krajem decembra (tek) mi istice ugovor pa cu videti sta i kako.. verovatno cu ponovo na mts ali sa 50% na racune a fon iz divljine.. ne zurim nigde, ocu da nadjem neko najbolje all-round resenje za naredne 2-3 godine.. Z2/S5Act su najrealnije opcije samo moraju da padnu cene jer nikada nisam dao preko 350e za telefon a i nemam nameru 🙂 (jedino sam dobio x600 koji je u tom trenutku na par mesta u BG bio 550/580e, kao zamenu za pokvaren siemens od 300e :d) ajd i 400e je stvarno plafon za moj standard (kupujem samo ono sto mogu i sto mi treba) a i svi ti telefoni i ne vrede vise od 350e.
Pogledaj cenu S4A, a ovaj se još nije ni pojavio, teško na 350e pre sledeće godine. A ovaj je bolji od predhodnika, i meni se sviđa.
S4A sada kosta oko 350e, u divljini 🙂 A imam od koga da kupim ovde u Va po tim ''divljim'' cenama, tako sam i kupovao jos od dveiljadite uz mozda samo 3 telefona kupljena kod operatera (Z400, WI i XP). Ne zurim nigde, meni ce telefoni kao Z2/S5A biti vrh i za godinu dana.
Kod ovog S5A me nervira samo sto nema stabilizaciju kamkordera kao Z2 i sto nema stereo zvucnike.. ostale mane mi ne smetaju toliko. Mislim da su ''uspeli'' da Active verzija bolje izgleda od obicne, cak ni bezeli nisu mnogo veci.. a sve ostalo je isto, amoled koji se vidi u svim uslovima, odlicna kamera, cipset, zvuk.. i kao bonus kuciste koje je bar delimicno otporno na padove (prema tom IP67 2 standardu).
A sta si mislio da ce izdrzati test? One zabice sto drze poklopac baterije su jadne.
Trebali su ici na IP68 i non removable back cover ako su hteli da urade nesto kako valja.
Bolje je izdrzao S5 ovakve testove realno.
Ja pored S5 stvarno ne vidim svrhu S5 Active.
Za taj poklopac znam, i na obicnom S5 se cesto desi da udje voda ali sam ipak mislio da je ova verzija malo bolje zasticena. Dobro i jeste malo otpornija na udarce, manje padove, ekstremne temperature i to je dobro ali ovo sa vodom mnogo mraci, ko zna koliko primera sam do sada video da i posle malog kvasenja voda udje u S4A/S5 i S5A (sitne kapi, od par do desetak npr ispod poklopca i oko baterije) i to me nekako nervira, morao bih cesto da proveravam i da brisem. Ocigledno je sony tu odradio bolji posao sa Z2 i monoblok kucistem. Ali opet mislim da je S5A otporniji na padove zbog materijala mada je Z2 na AA drop testu dobro prosao a S5A u ovom pocket crko. Mada je to nekako moglo da se desi i sa Z2 ali ovi kazu da samsung nije bas dobro prosao ni pri manjim padovima.. a u deklaraciji pise da je otporan na manje padove (4 feet). Definitivno su trebali da idu na IP68. Mada i ovo je dovoljna zastita, ne treba samo preterivati sa ''testiranjem''.
Totally protected against dust
Protected against immersion between 15cm and 1m of fresh water for up to 30 minutes
Protected against impact/shock from drop onto flat surface of less than 4 feet
Protected against vibration, temperature extremes, humidity, and high altitude
Nema veze, i dalje ovaj fon uz Z2 ostaje favorit za sledecu kupovinu, nemam nameru da ga kuvam u kljucalom ulju i bacam sa terase za YT testove nego hocu da znam da imam telefon koji moze da prezivi slucajne padove i namerna/slucajna kvasenja tj upotrebu u svim vremenskim uslovima.
HW je vrh, ekran odlican i na najjacem suncu (prikaz bele konacno odlican a boje mogu malo da se umire promenom moda ako hocu), o kameri se sve zna (najbolja uz Z2 od androida), kamkorder isto samo me nervira to sto prakticno nema stabilizaciju videa, to mi najvise smeta, kamera u low light uslovima je prosek i to sto (kao vecina androida) nema rucna podesavanja (SS i sl.), zvucnik je dobar ali mogli su da idu na stereo.. i da, ima mnogo nepotrebnih laznih detalja na kucistu, imitacija svega i svacega ali dobro..
Delimicno je tako mada ja ipak vidim svrhu, S5A je ipak bolje zasticen (ko garantuje da S5 ne bi crko u nekom testu, desava se), meni izgleda mnogo bolje od one nakaze alcatel ming hyuwai S5, ima tastere ispod ekrana i jos neke koje olaksavaju upotrebu u teskim uslovima, nema smaracki senzor za otisak prsta a cena je prakticno ista.. pa ko sta voli od tih S5, ja sam ubedljivo za Active verziju.
Prvi put kad sam video sliku zadnje strane ovog phona mislio sam da su oni ukrasi u ćoškovima zapravo šrafovi, kad su već hteli da idu na removable cover. Staviš karticu zavrnes strafove i ne brineš da li je svaka zabica sela. Ja se više i ne sećam kad sam otvarao poklopac baterije na mom Notu. Ali ne *****i idu na zabice da možeš da skineš prstima i da svaki pad otvara taj ebeni poklopac. Meni je jednom moj phone pao sa oko pola metra na beton i ogulila se lajsna i naravno ispao poklopac i baterija.
Inače mislim da sam u Xperia Z temi napisao šta očekujem od vodootpornog i kako očekujem da je napravljen.
I ja sam isto mislio, reko do jaja, zatvori se i nema problema. Slican sistem postoji na epskom m35i koji jos imam, zavrnes sraf i ne razmisljas. Mislio sam da je to deo te pojacane otpornosti na udarce (jer su srafovi sigurno pouzdaniji od plasticnih zabica). Ali eto.. ova verzija ima dosta tih laznih detalja..
Ni ja, jer mi je fon blindiran, alu unibody :smoke: Mada nisam imao ni potrebu da otvaram, ako zakuca restartuje se kombinacijom 3 tastera..
