BigBoy
Bila su u ovoj temi već dva ista slučaja i oba su uspešno rešena skidanjem tog sloja koji smeta...
*** zalomio ti se tako jer je u 99% sve ok 😉
Važno da su mene napali kad sam napisao da se drugaru isto ogulio onaj sloj. Neznam tacno ko ali je napisao da za takve osobe nije ovakav telefon. Kao sivonja uspeo i dva puta polomiti usb port. :wall: A drugar ga je samo dve nedelje nosio bez futrole i folije na ekranu. A stvarno ga cuva.
Ja sam ispolirao taj sloj magicnom krpom i sa malo alkohola.
Imaš li status bar gore i dugmiće dolje?
Možeš li poslati dvoj sys.txt
[device]
devtype_fallback_to_model=1
[android]
;fullscreen=1
;tablet=0
has_physical_home_button=0
check_for_dead_links=1
check_folders_after_rebuild=0
getdeviceid_trycount=0
upside_down_bug=1
;navigation_audio_stream=4
[rawdisplay]
force_renderer="RENDER_MOYA"
;driver=engine
;screen_xy="auto"
;driver="gdi"
;highres=1
[interface]
;vga=1
show_glonass=1
extra_settings=1
save_checksum=0
minzoom2d=25
[debug]
imei="android.os.Build.SERIAL"
skip_eula=1
screenshotsavecameraini=0
experimental_features=1
show_networkservices=1
show_lane_info=1
show_junction_view=1
[navigation]
junction_view_blink_time=500
junction_view_blink_time_no_lane=500
junction_view_at_maneuver=1
junction_view_type="mixed"
junction_view_needs_signpost=0
;junction_view_content_resolution_override="auto"
strict_ejv_resolution=0
[gps]
location_net=1
location_gps=1
;this should be in android igo9 config:
background_navigation=1
location_log=0
location_log_filename="gpslog/LocationManager"
[folders]
linked_root_list="/storage/extSDCard/iGO /storage/sdcard2/iGO /sdcard2/iGO /sdcard/external_sd/iGO /ext_card/iGO /mnt/_ExternalSD/iGO /mnt/emmc/iGO /mnt/extern_sd/iGO /mnt/external_sd/iGO /mnt/exsdcard/iGO /mnt/ext_card/iGO /mnt/ext_sd/iGO /mnt/extsd/iGO /mnt/extSdCard/iGO /mnt/sdcard/_ExternalSD/iGO /mnt/sdcard/external_sd/iGO /mnt/sdcard/ExtStorages/iGO /mnt/sdcard/extStorages/SdCard/iGO /mnt/sdcard2/iGO /storage/sdcard1/iGO /storage/sdcard0/iGO /storage/iGO /sdcard/sd/iGO /mnt/sdcard-ext/iGO /mnt/sdcard/sd/iGO /mnt/sd/iGO /mnt/sdcard/iGO /mnt/iGO /sdcard/iGO /storage/sdcard1/iGO /mnt/sdcard1/iGO /mnt/ext/SdCard/iGO /storage/ext/SdCard/iGO /storage/emulated/0/iGO"
;has_secondary_root=1
;android_secondary_root_path="/mnt/sdcard/addons"
[feature]
back_exit=1
back_button=1
contact_poi=1
tmc_event_coloring=1
signpost_coloring=1
[other]
demo_enabled=0
[poi]
provider_filtering=1
featured_provider="netlocalsearch.naviextras.nokia"
[poi.netlocalsearch.naviextras]
services="nokia,google"
[2d]
traffic_lights=1
[3d]
usepolyfarroads=0
[hnr]
ignored_missing_country_ids=*
[route]
hnr_ignored_missing_country_ids=*
[camera.roundabout]
enabled=0
centery=20
[map_update_checker]
enabled=0
[sound]
csv_voice_enabled=1
ding_muted=1
[network]
available=1
[http]
enabled=1
[tmc.src.http]
enabled=1
[tmc-http]
enabled=1
start=1
servers.size=3
servers[0].url="http://zippy.naviextras.com/services/tmclite/data/nng-igo-tmc-iphone/0/"
servers[1].url="http://zippy.naviextras.com/services/tmclite/data/nng-igo-tmc-russia/0/"
servers[2].url="http://tmchttp0.naviextras.com/nng-igo-tmc-primo/0/"
[naviextras]
boot_service_address="http://zippy.naviextras.com/services/index/rest/2/boot"
[services]
software_download_location="http://www.igomaps.co.il/Jquery_Report.html"
server_addr="https://android.naviextras.com/"
[warning]
speedcam_enabled=1
speedcam_warning=1
is_spoken=1
Šta je cp2.1? Nisam se nikada bavio flešovanjem,apdejtom i sličnim stvarima.Vidim da mnogi klipovi postoje,ali treba i znati,kad,na koju verziju i čime.Instalirao sam TWRP,jer sam video da fleš može da se radi sa njim,a može i da se odradi backup.Onda mi stiže update preko fona(to je valjda OTA) i šta sad.Mogu da ga ignorišem,ali ne znam kako da isključim iz taska štiklirano.I zanima me,dalji apdejti koji budu vremenom bili,jel ih skinem sa neta,nalepim u fon i onda pokrenem instalaciju preko TWRP?Jel se radi još nešto drugo(osim naravno prethodnog backup?
Pa skupe su navigacije. Pogledaj koliko je Navigon, 50-60€ mislim...
Što je najgore za slične pare kupiš poseban uređaj koji mnogo bolje završava posao
CP2.1 ili CloudyPro II 2.1 je portovan rom sa LG G Pro 2 telefona za naš model. Pri instalaciji imaš da izabereš verziju telefona (D802, D803...). U njemu imaš sve što i na zvaničnoj verziji KitKat-a koju si nadogradio, plus još neke korisne funkcije sa G Pro 2 roma. Kamera ti radi bolje u noćnim uslovima, imaš 4K snimanje, slow motion... Kada ga instaliraš nemaš cimanje sa tim OTA dopunama. Možda je "mana" što ako hoćeš da staviš noviju verziju, moraš sve ponovo instalirati. Uglavnom, skineš fajl od 1,7GB na fleš i instaliraš preko TWRP. Pre instalacije odradiš full wipe. Imaš sve na linku ispod. Verzija 2.1 je skroz ok. Neki su komentarisali da jede bateriju, a meni, eto, radi bez problema. Isteram 2-3 dana kao i ranije na stock romu.
http://forum.xda-developers.com/showthread.php?t=2680745
@danilov,ako sam dobro shvatio,skinem taj rom,nalepim ga na memoriju telefona i instaliram ga preko TWRP koji sam skinuo.Šta je full wipe?@Nikola 1994,verovatno si mislio da odradim sve kako je napisao danilov,prijavim se na isti mail,pa onda restore(misliš factory restore i posle toga ću opet moći preko OTA)?Možda glupa pitanja,samo što nikada nisam radio sve ovo.I nikako ne mogu da sa programom G2 tweak box izmenim boju ikonica gore u tasku.Pročitao sam da je potreban xposed framework,što sam i odradi😵pet mi izbacuje neku poruku da nešto fali?
sta kazete na to da se dopuni prvi post ove teme i da se ubace najosnovnije stvari vezane za telefon. tips and tricks, how to, tutorijali, linkovi ka romovima.... u 526 strana se covek lako pogubi a mnogi razvodnjavaju temu postovima tipa "ej meni danas stigo update"
... kako da podesim da mi na Nova laucheru radi knock knock za zakljucavanje, za otkljucavanje radi ali za zakljucavanje ne.
Inace sve poshvale za SOKP.
sta kazete na to da se dopuni prvi post ove teme i da se ubace najosnovnije stvari vezane za telefon"
Ti se sada nasao posle ovoliko strana naseg postovanja da kazes da mnogi razvodnjavaju temu?
CItam u drugoj temi da je bender zatrazio preko PM da bude banovan. Da li neko mozda zna o cemu je rec,clan je bas bio koristan ovoj temi u poslednje vreme
Kad pokrenem Wipe u TWRP,piše da će biti obrisani Data,Cache i Dalvik a ne i internal storage.Pretpostavljam da na to i treba da idem.U napredne funkcije imam posebno Dalvik Cache,System,Data,Internal storage i Cache.Pretpostavljam da tu ne treba da idem i ručno da obeležavam(sve osim Internal Storage)?Kad odradim Wipe,onda se vraćam na instalaciju i instaliram zip file koji sam skinuo sa neta i to je sve?Pitam ovako detaljno da ne zeznem nešto.Skines rom, ubacis na telefon, odradis wipe data, wipe cache, wipe dalvik cache i onda flesujes rom 🙂
Već sam ranije odradio backup preko TWRP,samo ne znam šta je i efs?Tako je,sve sem internal storage pa nakon toga flesujes rom.
Pre svega uradi backup i obelezi da se bekapuje i efs.
Jasno.Hvala.Jel sa instalacijom CloudyProII_2.1,ne gubim dupli klik na ekranu?It is a place that stores your Android smartphone important data like Wi-Fi, Bluetooth MAC address and IMEI (nv_data.bin).
