Sony Xperia Z2
  • Začetnik teme Začetnik teme Emix
pa ko radi na svoju štetu(npr. Sony i Nokia) znači da je proizvod dobar i povoljan, ko profitira kao Samsung i Apple znači da te dere... 🙂 čista matematika 😀
As a photographer, this is a trick... every shitty camera will take a good low light photo if you leave the the shutter open long enough. No one uses a phone with a tripod so phone cameras don´t usually take picture with long exposures, because it will be blurry all the time.
In this test Z2 did that (in Night Mode), which make the test unfair, and this scene settings is completely unrealistic since no one will take a picture with the phone not moving at all.
pocket-lint http://www.pocket-lint.com/review/128493-sony-xperia-z2-review
Overall the Sony Xperia Z2 is a definite step forward for the series. It might be an incremental upgrade rather than a device overhaul, but it delivers in the areas that matter, making for a package that's highly desirable and ultra powerful.
Inace oni su samo M8 ocenili sa 5/5 a S5/Z2 4,5/5.
Jos neki testovi
http://www.ibtimes.co.uk/sony-xperia-z2-review-bigger-better-1445256
http://www.brighthand.com/default.asp?newsID=20664&review=sony+xperia+z2+android+smartphone
http://www.theguardian.com/technology/2014/apr/17/sony-xperia-z2-review-phone-android
[YOUTUBE]4ZjKsV-CgGI[/YOUTUBE]
The only real caveat is the handset's huge, monolithic construction (a far cry from puny, 126-gram Neo). As you'll see, if you can get past its size, the Z2 addresses some of the most serious gripes we had with its predecessors,
Let's deal with the size thing right away. It's not merely a question of weight, because the Z2 is only 18 grams heavier than the Galaxy S5, which is about as light as phones in this category come nowadays. Sony has actually done an excellent job of keeping the Z2's weight down:
No, the problem here is with the weightdistribution. The Z2 feels wider and taller than it needs to be, and its center of gravity just doesn't feel very... centered. By contrast, the similarly heavy HTC One (M8) feels like its density is gathered around the spine of the device, so that it rests solidly in the hand. None of these handsets are especially conducive to one-handed use, but the Xperia Z2 is the worst of the bunch in this respect; I dropped it four times in the space of a week, which is a record even for me, and I found it unwieldy for reading in bed, too.
The other issue with the Z2's design is its blockiness. Visually, I find this attractive -- it's part of Sony's metal-and-glass design statement, which is further aided by the thinness (just 8.2mm, or one-third of an inch). In daily use, however, the absence of curvature and shaved-off corners can be annoying -- even for someone who's used to carrying something enormous like the Galaxy Note 3.
Ствар коју сам ја покушао да објасним иако га никада нисам држао. Просто је цигла од мобилног,иако је све остало врх
[YOUTUBE]ezvq6DLn3ho[/YOUTUBE]
530e za Z2 u Singapuru, kako vam deluje ta cena?
Деловаће и боље ако успе да скине ПДВ када буде излазила из земље 🙂
Procedura ista za povracaj kao da se uzima u npr Madjarskoj ili ?
[YOUTUBE]vVoNr4HTVU4&app[/YOUTUBE]
Za USA trziste me i ne cudi jer je i Z1s tamo stigao tek pre oko 2 meseca..
Na kraju će još preko pozivnica da ga prodaju, kao Oneplus One :S:
A sad realno: šta im je trebalo da ulaze u čitavu tu priču sa izbacivanjem flagship telefona svakih 6 meseci, kad očigledno nemaju infrastrukturu i/ili sredstva da to urade?
Utisci novinara su odlični, ali njihov telefon nema gde da se kupi, dok se S5 i M8 prodaju... dok njihov telefon dođe do kupaca, neke nove tehnologije i uređaji će biti aktuelni...
Ocigledno Sony nije potkupio prave ljude 😀
Inace, po oglasima 610e. Sve se saplicem od trcanja 😀
[YOUTUBE]6kZkdisZggE[/YOUTUBE]
kakav je nocni video na Z2 , meni se low light video na G2 uopste ne svidja.... cak i sto su odradili stabilan fps preko onih fix zayebancija opet je slabo osvetljeno.... blenda ga yebe....
razmisljam da kupim Z2! Sta mislite ima li logike prelaziti sa G2 na Z2, treba mi dobar bolji video...
Смем ли да знам због чега је толико битан ноћни видео ? Увек ми је правило проблема то да схватим.
Бавиш се неким послом у коме је круцијално снимати клипове када је слабо осветљење или.. ? Ништа лично,али ме баш интересује
Изласци, клубови, ор*ије, кућни снимци 🙂))
Potrazi na YT 1080p/4k semplove sa Z2.. bilo je par i u low light uslovima. U odnosu na G2 ima 4k kamkorder i 30 fps u svim svetlosnim uslovima i 120 fps 720p (slow motion), zvuk je malo bolji a stabilizacija je primetno bolja od G2. I to su najvece razlike, znaci u odnosu na G2 u low light uslovima bi dobio stabilnih 4k (ako ti treba) 30 fps i stabilizaciju videa koja radi bolje od prakticno svih aktuelnih ois-a na telefonima.
Posto si fotograf, procitaj ovo, razumeces nacin testiranja i prednosti/mane Z2. Npr, u odnosu na Z1 novi Z ima agresivniji af kamkordera. Inace sam z1/2 kamkorder ''kupi'' vise svetla od android konkurencije mada je i htc one m7 tu dosta dobar.
E sad, sigurno se ne isplati preci sa G2, ne na Z2 nego na bilo koji novi flagship, razlika u ceni je prilicno velika, bar prema ovim cenama u svetu a Z2 jos nije zvanicno stigao kod nas mada mozda su se pojavili divljaci. Naravno kome pare nisu problem onda se isplati preci na Z2/S5 i slicne.
Logicno, najvecu razliku u kameri/kamkorderu bi primetio kada bi sa G2 presao na Lumiu 1020 ali onda gubis neke druge stvari.
