@ singerica evo ga sajt za cgwatcher,ima tu neki fajlovi sto se kompajliraju,ne razumem se,pogledaj
smos 1.3 mi izbacuje gresku: xauth: (argv):1: merge: unable to open file /home/user/.Xauthority Sta je u pitanju?Novosklopljena masina,mada se desava i na starim ponekad.
Ne vidim link?
Je li ti priključen monitor?
@singerica
Moze li se u postojecoj verziji smos-a ubaciti karloth cgminer?
5. Change cgminer 3.7.2 to cgminer 3.7.2-kalroth
wget http://www.smos-linux.org/upgrade/kal.sh
chmod +x kal.sh
./kal.sh
Cgminer-3.7.2-kalroth and sgminer 4.0.0@singerica
cgmon tool - cgminer monitor - auto fix GPUs DEAD and SICK status.
Cgmon is a simple startup init-script for SMOS that runs cgmon in virtual screen without using cron.
In this tip, we will show you how to corectly install and setup cgmon tool:
1. Install all dependecies.
type in terminal:
"apt-get install php5 php5-cli tcl screen"
2. copy cgmon_wrapper.sh (using wget) from http://yadi.sk/d/34zlbFhWHx4ua to any directory you want. I recomended to keep it in "/opt/cgmon/"
to do this, type in terminal:
"cd /opt"
when you in opt catalog:
"mkdir cgmon"
then:
"cd cgmon"
Download this file http://yadi.sk/d/34zlbFhWHx4ua using wget #gaf please reupload this file on your server
to do this, type in terminal (make sure that you are in the cgmon catalog):
wget http://yadi.sk/d/34zlbFhWHx4ua
3. Copy cgmon_daemon (using once again wget) from http://yadi.sk/d/aKU8Zr6nHx4ug to "/etc/init.d/" directory on your SMOS. #gaf please reupload this file on your server
cd /etc/init.d/
then:
wget http://yadi.sk/d/aKU8Zr6nHx4ug ##please reupload this file on your server gaf
4. Make the scripts executable:
type in terminal:
"chmod 755 /etc/init.d/cgmon_daemon"
and
"chmod 755 /opt/cgmon/cgmon_wrapper.sh"
5. Download and Edit cgminer_path in cgmon.tcl
to download cgmon type:
"cd home/user" #FINAL FIX! or cd /opt/cgmon ##??
and
"wget http://www.forked.net/~apex/cgmon/cgmon.tcl" #please reupload this file on your server _gaf
type in terminal:
"nano cgmon.tcl"
then in line 80 change:
set conf(cgminer_path) ""
change to:
set conf(cgminer_path) "/opt/miners/cgminer/"
and:
"chmod +x cgmon.tcl"
6. Enable script cgmon into autostart:
type in terminal:
update-rc.d cgmon_daemon defaults
and
update-rc.d cgmon_daemon enable
7. You may start it by hands, just type in terminal:
/etc/init.d/cgmon_daemon start
if you whant to stop or restart daemon:
/etc/init.d/cgmon_daemon stop
or
/etc/init.d/cgmon_daemon restart
8. To start the cgmon:
screen -r cgmon_daemon
