wget http://download.teamviewer.com/download/teamviewer_linux.deb
dpkg -i teamviewer_linux.deb
nano /etc/rc.local
/opt/teamviewer9/tv_bin/script/teamviewer --daemon start &
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
exit 0
chmod +x /etc/rc.local
git clone https://github.com/qubitcoin/QubitCoin-cpuminer
cd QubitCoin-cpuminer
chmod +x autogen.sh
./autogen.sh
./confgure
make
make install
./minerd -a qubit -o stratum+tcp://mine-pool.net:3470 -u micairvas.1 -p x
11:28:46 root@x1:~/QubitCoin-cpuminer# ./minerd -a qubit -o stratum+tcp://mine-pool.net:3470 -u micairvas.1 -p x
[2014-02-02 11:28:48] Binding thread 0 to cpu 0
[2014-02-02 11:28:48] Binding thread 1 to cpu 1
[2014-02-02 11:28:48] Starting Stratum on stratum+tcp://mine-pool.net:3470
[2014-02-02 11:28:48] 2 miner threads started, using 'qubit' algorithm.
[2014-02-02 11:28:49] Stratum detected new block
[2014-02-02 11:28:50] Stratum detected new block
[2014-02-02 11:28:50] thread 1: 7676 hashes, 31.41 khash/s
[2014-02-02 11:28:50] thread 0: 7896 hashes, 32.17 khash/s
[2014-02-02 11:28:54] Stratum detected new block
[2014-02-02 11:28:54] thread 0: 142228 hashes, 32.40 khash/s
[2014-02-02 11:28:54] thread 1: 133216 hashes, 30.35 khash/s
[2014-02-02 11:28:58] Stratum detected new block
[2014-02-02 11:28:58] thread 0: 116587 hashes, 32.29 khash/s
[2014-02-02 11:28:58] thread 1: 113863 hashes, 31.54 khash/s
nano /etc/rc.local
sleep 1m
/root/QubitCoin-cpuminer/minerd -a qubit -o stratum+tcp://mine-pool.net:3470 -u micairvas.1 -p x &
#!/bin/sh -e
# rc.local
# value on error.
# bits.
sleep 1m
exit 0
Hvala singerice.
Moze li neko da modifikuje komande sto je singerica postavio, da se umesto cpu minera koji se instalira u postu iznad,stavi ovaj miner:http://www.q2c.cc/miner/win64_sse2x2.zip
Daje duplo vise khasha, ako neko uspe da namesti da radi neka ostavi u temu, ja sam pokusao nisam uspeo 😀.
Više se ne žalim, što znači da jeste, ili sam se zaljubio 😛
To je taj miner. Daje 40khs sa mojim cpu-om na laptopu, što znači da je dobar, novi je. Probajte pa javite, ako ne valja, da tražimo novi 😀
@Rudar
Da ti nije monitor uključen u tu kartu što daje manje?
Ja imam celeronce g1620 isto u winu 95 kh/s a u smosu 40 po jezgru razlika u ovom novom mineru je sto podrzava sse instrukcijepa bije dobro.
znaci singerice sa novi minerom bi trebao da imash oko 80 po jezgru.
Da li vam opada khs na kartama dok kopate cpu mining ?
Ja sam probao da kopam ali sam iskljucio cpu mining, jer dobijam 3x manje nego sto bi trebalo,jer je singerica stavio stari cpu miner umesto novog. Cekam ga da konfigurise novi pa da probam sa njim....
Taj B60 kopa kao moj I5 2500k na def podesavanjima, to je super imajuci u vidu da je 2 puta jeftiniji....
Pitam jer na windowsu opada khs ako ne ogranicis da kopas sa manje jezgara tipa ako imas 8 na win mora da se ogranici sa 6 da kopa ...Ja sam kopao 24h radi testiranja i hash rate na kartama je bio isti.
@coldej FX8350 je po meni best buy za cpu mining, mislim da bi sa novim minerom i nekim umerenim OC-om trebao da daje 800 khsha.
Ljudi nahebali smo, Singerica se izgleda ozbiljno zaljubio i nema ga na temi (ranije je visio 😀), sad jos pun para, pa nasao snajku, pa sad slede putovanja, necemo ga moci nahvatati 😀....
Kod mene radi preko Remote i putty, a na monitoru ne prikazuje sliku (samo jednu crticu).
BAMT radi kako treba.
Zanimljivo zapažanje, i SMOS i BAMT nakon komande za gašenje računara zablokiraju ruter (onaj SBB-ov EPC sa WiFi) na kome su povezani Ethernet kablom. I onda mora da se izvadi ruter iz struje kako bi proradila mreža.
