SMOS Linux Plug-In & Mine - The simplest mining OS based on Linux
Danas sam nešto raspoložen, pa ispunjavam želje :p
Teamveawer skida na sledeći način:
Kod:
wget http://download.teamviewer.com/download/teamviewer_linux.deb
Onda ga instlirate sa
Kod:
dpkg -i teamviewer_linux.deb
Pokrenite terminal i kucajte
Kod:
nano /etc/rc.local
Iznad linije exit dodajte
Kod:
/opt/teamviewer9/tv_bin/script/teamviewer --daemon start &
Ovako treba da izgleda:
Kod:
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
exit 0
Sačuvajte i kucajte sledeće u terminal:
Kod:
chmod +x /etc/rc.local
I teamveawer se automatski statrtuje nakon start rig-a
CPU MINING za qubit
Uđite u terminal i kucajte:
Kod:
git clone https://github.com/qubitcoin/QubitCoin-cpuminer
cd QubitCoin-cpuminer
chmod +x autogen.sh
./autogen.sh
./confgure
make
make install
Startujete sa:
Kod:
./minerd -a qubit -o stratum+tcp://mine-pool.net:3470 -u micairvas.1 -p x
Primer da radi! Nemojte da ne radi :D
Kod:
11:28:46 root@x1:~/QubitCoin-cpuminer# ./minerd -a qubit -o stratum+tcp://mine-pool.net:3470 -u micairvas.1 -p x
[2014-02-02 11:28:48] Binding thread 0 to cpu 0
[2014-02-02 11:28:48] Binding thread 1 to cpu 1
[2014-02-02 11:28:48] Starting Stratum on stratum+tcp://mine-pool.net:3470
[2014-02-02 11:28:48] 2 miner threads started, using 'qubit' algorithm.
[2014-02-02 11:28:49] Stratum detected new block
[2014-02-02 11:28:50] Stratum detected new block
[2014-02-02 11:28:50] thread 1: 7676 hashes, 31.41 khash/s
[2014-02-02 11:28:50] thread 0: 7896 hashes, 32.17 khash/s
[2014-02-02 11:28:54] Stratum detected new block
[2014-02-02 11:28:54] thread 0: 142228 hashes, 32.40 khash/s
[2014-02-02 11:28:54] thread 1: 133216 hashes, 30.35 khash/s
[2014-02-02 11:28:58] Stratum detected new block
[2014-02-02 11:28:58] thread 0: 116587 hashes, 32.29 khash/s
[2014-02-02 11:28:58] thread 1: 113863 hashes, 31.54 khash/s
Ako hoćete da se samo startuje:
Kod:
nano /etc/rc.local
I dodate iznad exit 0
Kod:
sleep 1m
/root/QubitCoin-cpuminer/minerd -a qubit -o stratum+tcp://mine-pool.net:3470 -u micairvas.1 -p x &
Primer kako izgleda
Kod:
#!/bin/sh -e
# rc.local
# value on error.
# bits.
sleep 1m
exit 0
Samo promenite pool i username :D
Kod:
Nakon toga se miner automatski startuje nakon restarta
Hvala singerice.
Moze li neko da modifikuje komande sto je singerica postavio, da se umesto cpu minera koji se instalira u postu iznad,stavi ovaj miner:http://www.q2c.cc/miner/win64_sse2x2.zip
Daje duplo vise khasha, ako neko uspe da namesti da radi neka ostavi u temu, ja sam pokusao nisam uspeo :D.
evo da podjeli moj problem sa vama mozda neko zna odgovor
u pitanju je graficka SAPPHIRE DUAL-X R9 280X 3GB GDDR5 OC
sto god da uradim u podesavanju jedna uvek kopa slabije od druge pa neznam kako da ovaj problem resim ??
"api-listen" : true,
"intensity" : "20",
"vectors" : "1",
"worksize" : "256",
"kernel" : "scrypt",
"auto-fan" : true,
"temp-cutoff" : "85",
"temp-overheat" : "75",
"temp-target" : "70",
"expiry" : "30",
"gpu-dyninterval" : "7",
"log" : "5",
"queue" : "1",
"retry-pause" : "5",
"scan-time" : "30",
"scrypt" : true,
"temp-hysteresis" : "3",
"shares" : "0",
"shaders" : "2048",
"thread-concurrency" : "24768",
"gpu-thread" : "1",
"gpu-engine" : "1050",
"sharethreads" : "32",
"lookup-gap" : "2",
"gpu-powertune" : "20",
"gpu-memclock" : "1250"
Evo to je ceo moj problem pa ako neko zna kako da ovo resim sa ovom neposlusnom grafickom neka pomogne :smash:
Singerica stvarno te krenulo, vidim da se trudiš, jel konačno problem sa donacijama rešen, u smislu da imaš dovoljno za osnovne troškove i život?
Bilo bi lepo kada bu ubacio podršku za wireless usb i PCI adaptere :)
Više se ne žalim, što znači da jeste, ili sam se zaljubio :p
To je taj miner. Daje 40khs sa mojim cpu-om na laptopu, što znači da je dobar, novi je. Probajte pa javite, ako ne valja, da tražimo novi :D
@Rudar
Da ti nije monitor uključen u tu kartu što daje manje?
LJubav je čudo, pošto imaš perspektivan poso možeš da se ženiš...
@Rudar
nije ukljucen posto koristim teamviewer kad mi treba
Dva nova videa:
http://www.smos-linux.org/video/
SMOS Linux 1.3 - How to install teamviewer and make it to autostart (using shell/putty)
SMOS Linux 1.3 - How to make autostart script (using shell/putty)
@Rudar ne znam šta da ti kažem, čekaj da neko sa tim kartama odgovori :)
Singerice ne valja miner, to nije ovaj:http://www.q2c.cc/miner/win64_sse2x2.zip
U windowsu sa ovim novim minerom dobijam sa G1620 oko 95khsaha po jezgru, dakle ukupno skoro 200 khsha. Preko linuxa dobijam oko 35 khsha po jezgru, sto je ultra malo. Nesto izgleda nisi namestio kako treba.Kazi mi koji procesor imas na laptopu, reci cu ti koliko bi trbao khasha da dobijas.
Ja imam celeronce g1620 isto u winu 95 kh/s a u smosu 40 po jezgru razlika u ovom novom mineru je sto podrzava sse instrukcijepa bije dobro.
znaci singerice sa novi minerom bi trebao da imash oko 80 po jezgru.
Jel kopas sa novim minerom u smosu i dobijas 40khsha po jezgru?
Ja kopam u smosu sa ovim minerom sto je singerica postavio.
micairvas sa kojim ti kopas ?
phrnom II b60 na 3.6 sa starim minerom u winu sam imao 200 a sa novim 410 stvarno brze temp iste 47 hladjen hyper 212.
evo to je novi miner source
https://github.com/ig0tik3d/QubitCoin-cpuminer-v.1.1
pitanje za singericu da li moze da se iskompajlira za smos ?
ja probah da ga kompajliram i sve ide glatko ali nemoze da uradi make prijavljuje gresku mozda fali neki dep.
Singerica help sta drugo :(
Ja sam probao da kopam ali sam iskljucio cpu mining, jer dobijam 3x manje nego sto bi trebalo,jer je singerica stavio stari cpu miner umesto novog. Cekam ga da konfigurise novi pa da probam sa njim....
Taj B60 kopa kao moj I5 2500k na def podesavanjima, to je super imajuci u vidu da je 2 puta jeftiniji....
Da li vam opada khs na kartama dok kopate cpu mining ?
inace ovaj b60 je otkljucan phenom x2 560 i radi na default voltazi stvarno sam ubo ok primerak evo 3 godine ce u novembru, a pazarih i jedan fx 8350 posto ga moja ploca podrzava kako on cpu majnuje i koliko po jezgru ?
Ja sam kopao 24h radi testiranja i hash rate na kartama je bio isti.
@coldej FX8350 je po meni best buy za cpu mining, mislim da bi sa novim minerom i nekim umerenim OC-om trebao da daje 800 khsha.
tako sam i ja gledao a nije mi se uzimala ploca za neki intel kad vec imam plocu i napajanjanje mi je ocz 600w tako da je on bio logican izbor.
Ljudi nahebali smo, Singerica se izgleda ozbiljno zaljubio i nema ga na temi (ranije je visio :D), sad jos pun para, pa nasao snajku, pa sad slede putovanja, necemo ga moci nahvatati :D....
ahahah :d lepo je sve to shta ces.
Pitam jer na windowsu opada khs ako ne ogranicis da kopas sa manje jezgara tipa ako imas 8 na win mora da se ogranici sa 6 da kopa ...
Hahahhaha oplako sam :D
Ono je cpu miner koji kopa onaj algoritam, je li još neko dobija manje osim micairvas-a? :D
edit
Sad ću da probam ovaj novi :D
Ovo što se poslali da ne radi, nije oficijalna verzija, neće da obradi bibloteke neke...
Stavite broj procesora vi što imate jače, možda ne prepozna po defaultu :)
-t, --threads=N number of miner threads (default: number of processors)
Kad se mozes nacrtati na irc-u za pomoc? ;) Stigle su mi kartice, razgovarao sam sa gaf_om ali malo malo pa nestane covek :)
Edit:
Smos nece da se podigne kada je kartica prikljucena.
U cemu moze da bude problem?
Probao sam oba pci-ex slota.
U ploci
Po stoti put je ponovljeno da smos nece da radi sansvakom plocom
Sve je u redu. Smos vidi kartu samo ja ne poznajem smos pa sam mislio da ne radi...
Kod mene radi preko Remote i putty, a na monitoru ne prikazuje sliku (samo jednu crticu).
BAMT radi kako treba.
Zanimljivo zapažanje, i SMOS i BAMT nakon komande za gašenje računara zablokiraju ruter (onaj SBB-ov EPC sa WiFi) na kome su povezani Ethernet kablom. I onda mora da se izvadi ruter iz struje kako bi proradila mreža.
U kako los trip sa ruterom!
