AMD Radeon Rx serija
Zaključak sa HardOCP test sumira sve lepo:
R9 290X vs. TITAN
The R9 290X is performance comparable to the GeForce GTX TITAN at 2560x1600 (1600p) and lower (1080p.) In every game we played we were able to match the same gameplay experience as the GeForce GTX TITAN. That means that every game played the same between both video cards, the same performance, same in-game settings, and same smoothness. Performance in terms of frames per second was either right under, or right at TITAN FPS performance. The performance differences were so insignificant that those did not translate to any noticeable gameplay differences at all.
Interesantno je da je R9 290X daleko nadmoćniji u 4K rezolucijama:
The situation changes when the Radeon R9 290X is pushed up to Ultra HD 4K display resolutions. Whatever magic AMD is doing at 4K, it is working. We found that the Radeon R9 290X was faster in every game compared to the GeForce GTX TITAN at 3840x2160. It wasn't just a little bit faster either, it was anywhere from 10-23% faster. This is a significant difference. At 4K resolutions, you need every bit of performance you can get to achieve playable performance at high in-game settings on a single video card. The Radeon R9 290X is clearly the card for Ultra HD 4K.
290x - $550
780 - $650
Titan - $1000
Malo hladniji R9 290 za 400€ bi definitivno postao bestbuy.... saznacemo detalje oko toga za nedelju dana.
kartica VAPI za dobrim hladjenjem a ovo djubre od referentnog ne da nije doraslo zadatku 🙂
Jedva cekam neki Ares 3 ili DC2 da vidimo kako ce se ponasati...
CENA = LEPOTA 🙂 460 evra ili 53000 dinara prema benchmarkovim navodima L o L...
sace cena 780 da padne nekih 100e tamo gde i pripada 🙂
u Em**u 51.999 - AMD Radeon R9 290 Sapphire
Eh kada bi je imao to sto je bucna i greje noge ne bi mi smetalo.😛
Ovo su odlicni rezultati + veoma konkurentne cijene, svaka cast za AMD! (bitCoinu trebaju spomenik dici :d )
nVidia gospodo, spustanje cijena OR ELSE! :smack:
P.S. Ova referentna R9 290X mi izgleda UZASNO jeftino
Izašlo je u domaćoj radinosti 🙂
Da, mnogo dobra kupovina, manje od 500 evra...Mislim da sve one poredbe sa Titanima postaju potpuno deplasirane.
Svak cast AMD!!! svaka Cast!!!
Performance/price - ovo nije TITAN kiler, ovo obesmisljava kupovinu bilo koje karte iz High segmenta.
Kartica vapi za vodednim hladjenjem performanse bi bilo jos za 5% bolje jer ne bi obarala takt drzala bi konstantni 1000mhz, nadam se da ce partneri napraviti bolje hladjenje.
E da smo ovo imali prosle godine gde bi ssada bili 🙂 Prijatno sam iznenadjen cenom, stvarno sam mislio da ce da zacene. Bravo AMD, odlican posao...
Kao sto sam i pretpostavio pre mesec dana - patkometrija. Gaming cip koji je nateran do granica tehnologije (ne moze vise da se izvuce iz 28nm), compute kako gde - negde je brza od Tahitija zbog sirove snage (vise SP), negde podosta sporija. Sacekajmo partnerske verzije, koje ce sigurno biti dosta bolje po pitanju buke (ne znam koliko vas je sedelo pored karte koja radi na 50dB, ali to je neizdrzivo).
Generalno gledano, Titan i 780 definitivno jesu bolje karte, ali postaju neisplative za one koji gledaju samo price/performance jer su jednostavno preskupe.
da sad moram da uzmem i 4k monitor da bi izvukao maksimum iz karte 🙂
A sad kad se sjetimo oni linkova od oni svedjana sto su kacili kao cjena 1200€:guitar:...
savrsenstvo u pogledu performance/price
Razlika izmedju ove karte i TITANA je 450$ za razliku u cjeni moze se uzeti vodeno hladjenje, pa imati neuporedivo hladniju/brzu kartu.
Stvarno sam impresioniran performansama i cjenom cheers
A sto se tice Overclock-a i tu jako lepo skalira. Rekli su da BIOS ima jos bagove i da ocekuju da se to ispravi jer memorija nije mogla vise od ~1540 mhz. Za custom modele ocekujem 2x8 pin i oc barem 1200/1600Mhz. 😉
Nisam tacno siguran u kom to pogledu je 780 bolja karta (ne gledajuci samo price/perf ratio)?
OC ce ici sigurno preko 1200mhz sprecava ga temperatura samo memorija je deklarisana na 1500mhz tako da ce bez problema gurati te taktove.
Bitno je samo ohladiti kartu, pred AMD partnerima je pravi domaci zadatak, trebaju se svi zestoko potruditi da ohlade ovu azdahu ili je ovo AMD hladjenje stvarno lose.
Treba imati u obzir da su ovo jos beta driveri i da ce performanse skociti ako nista bar 5% peglanjem drivera.
Bitno je samo kartu odrzati na taktu od 1000mhz uz nove dirvere to je cisti dobitak od 10% na ovo performanse + Mantle...
Nije ni HD7990 daleko 😀
Bandwidth preko 400 Gb/s
Jao, sto su dobre ove domace cene.... jos malo pa su uboli moju ranije zeljenu cenu od 450€ za 290X. 😀 😀 😀 Heh, ako se obistini 53-54k din cena za 290X, moci cemo kupiti 2 komada za cenu jednog domaceg Titana.
Obican 290 sa custom hladnjakom ce defintivino biti ultimativni best buy.
Prilicno manja potrosnja, prilicno niza buka, malo nize performanse. Da je ista cena, ne bih se uopste dvoumio 😉 Sitiacija ce se verovatno promeniti custom modelima 290X, ali njih necemo videti neko vreme.
DusanKa obicno lepo pise, ali sta mu sad bi, mozda je kupio 780ku za 580e 😀
Pazi, nema sanse da bih dao toliki novac za graficku kartu, za ono sto je meni potrebno 7870 je puna kapa. Sto se tice lepog pisanja, hvala 😉, ali je poenta da nikada nisam menjao misljenje sta mi je bitno od karakteristika kod graficke karte - nekada su me napadali zeleni, sada ocigledno crveni, ali dobro.
racunajte 50e+ kad se pojavi asus dc2 verzija xD
Veoma dobra karta, naravno da ova AMD varijanta nije ni dovoljno hladna ni tiha, i tu se i slažem da je možda i 780 bolja, ali skuplja tako da. Kada stignu karte sa "pravim" hladnjacima biće bolje naravno.
Btw- svaka čas AMD inženjerima što se tiče mem kontrolera, 20% manje mesta zauzima od onog u Tahitiju a moćniji je dosta 😉..
edit-jedino sam razočaran rezultatima za kopanje, ali nisam mnogo bolje ni očekivao..
Konacno je doslo sve na svoje.
Ono sto sam govorio je isplivalo na videlo.
Da bi izvukli maksimalne performanse nisu ispostovali green zonu !
Za single GPU karta mnogo trosi i mnogo se greje dok je OC prakticno neupotrebljiv jer karta obara klokove
zbog prevelike disipacije!
Pogledah testove na brzinu ( a detaljnije cu uz kaficu kasnije 😀 ) i ono sto se da primetiti jeste da posle 2 godine od predstavljanja Tahiti
jedva da su uspeli da se izjednace sa Titan dok je u odredjenim igrama ta karta blize GTX780!
Od svega ovde jedino sto je ok je cena ostalo je meh - ukupan rezultat samog proizvoda!
Ma nije meh, nemoj da umanjujes postignuto. Mislim da je ovo dobra grafa za te pare pogotovo kad izadju nereferentni modeli. Ispeglace se grejanje kartica i podici OC margina u to budi siguran.
Bitno je da je brza od TAHITIJA 😛
Sto se tice Titana skinut je sa trona u najvecem broju igri pogotovo kako rezolucija raste tako Titan gubi - u stvarnosti Titan je bitku izgubio kako u pogledu performansi tako i u pogledu cjene.
Ja sam uporno tvrdio da ce biti titan kiler dok su mnogi govorili da nece biti brza od tahitija sve je isplivalo na povrsinu, konacno se vidi ko je bio u pravu.
Nema mi kolege @DAS-a vjerovatno je podnio ostavku :d😀:d
Za single GPU karta mnogo trosi i mnogo se greje...
A sada prekopaj postove od pre 3 godine i vidi da li ti je ovo bilo imalo bitno za GTX 480 😉 Ili hoces da ja to uradim za tebe 😀
Novi drajveri ce dovesti do toga da karta izvesno bude brza od Titana, tu nema sumnje, kao sto je vec sada primetno brza u Ultra HD rezolucijama, i to sa prilicno manjom povrsinom cipa. I to nije neocekivano, vise puta sam pisao o tome (gejming cip vs. GPGPU optimizacije), sto gomila uopste nije prihvatala kao argument u slucaju GK104 i Tahitija, a pisale su se ode Kepler arhitekturi (koja se prakticno ne razlikuje po efikasnosti u odnosu na GCN).
U goldi druze al' dizes vatru to nije normalno. Vidimo svi kakva je grafa, nema potrebe za "ujedanjem"... Svi znamo sta nude jedni a sta drugi, uzece ljudi ono sto im vise odgovara... logicno 🙂
Brate sad zvucis kao neki laik.Tahiti je predstavljen skoro pre 2 godine.
Za to vreme izbacuju kartu koja jedva da se izjednacuje sa Titanom koji i nije full GK110 !
Ogromna potrosnja i temperature.Vec sad karta trotluje a jos su ovo testovi u nekim najidealnijim uslovima .
Pitanje je koliko ovakav chip moze da traje na duze staze jer AMD nije bas poznat po izdrzljivosti na visoke temperature proteklih godina.
Ono sto ja zelim jeste da se neko zrtvuje i da konacno krenu user review-i , tu ce isplivati rezultat svega onog sto cini ova karta.
Ne znam kako ce da se ispegla ovolika disipacija zaista , mozda nesto malo umanje sa biosima ali fizicki grejanje moze samo da se
savlada aftermarket coolerima i vodom u ovom slucaju najbolja opcija ..
http://www.ekwb.com/shop/blocks/vga...adeon-rx-200-series/ek-fc-r9-290x-acetal.html
@goldi
Apsolutno nije bila ista situacija sa GTX480 😉
Ostalo necu ni da komentarisem :S:
DAS ti je vec istakao cinjenice i svoje misljenje..Imas sve na linku u mom piotpisu 😉
Toliko si zapenio da ne znaš gde udaraš... citiraš pogrešnog čoveka. Eh, što bi ova diskusija bila kul kada bi vas dvojica umeli normalno da se ponašate.
Što se karte tiče, super cena i fenomenalan čip ali referentna izvedba nula. Valjda će biti bolje kada stignu nereferentne.
Edit: Gde nestade post ispod mog?
