Malo download-a
Ovo poslednje se doima zanimljivim.. Jel je funkcionalan kao u w8 ili je neki drugi fazon?
Da li je neko koristio ovaj Virtual CD-ROM Control Panel from Microsoft?
Nekak oima mnogo kontradikcija:
Readme for Virtual CD-ROM Control Panel v2.0.1.1
THIS TOOL IS UNSUPPORT BY MICROSOFT PRODUCT SUPPORT SERVICES
System Requirements
- Windows XP Home or Windows XP Professional
Installation instructions
1. Copy VCdRom.sys to your %systemroot%\system32\drivers folder.
2. Execute VCdControlTool.exe
3. Click "Driver control"
4. If the "Install Driver" button is available, click it. Navigate to the %systemroot%\system32\drivers folder, select VCdRom.sys, and click Open.
5. Click "Start"
6. Click OK
7. Click "Add Drive" to add a drive to the drive list. Ensure that the drive added is not a local drive. If it is, continue to click "Add Drive" until an unused drive letter is available.
8. Select an unused drive letter from the drive list and click "Mount".
9. Navigate to the image file, select it, and click "OK". UNC naming conventions should not be used, however mapped network drives should be OK.
You may now use the drive letter as if it were a local CD-ROM device. When you are finished you may unmount, stop, and remove the driver from memory using the driver control.
(info kad se raspakuje)
a info na sajtu :
The Virtual CD-ROM Control Panel utility enables users of Windows XP, Vista, and 7 to mount ISO disk image files as virtual CD-ROM drives. This can be highly useful for reading disk images to install software or recover backup files. Notes: This tool is not supported by Microsoft; use at your own risk.
Šta će ti to pored Alcohola ? Anyway, 8mica to radi automatski i to dobro pretpostavljam da je na isti način namešteno čak dobije i slovo i može sve da se radi kao pravi CD/DVD. Ima properties zajedno sa drajverima, sharing i sve ostalo.
Alcohol a posebno 120% ima daleko više funkcija nego samo običan virtual CD, može i da pravi puno formata a bogami i da napiše po koji CD/DVD. Ne pravi probleme kao neki drugi emulatori.
Coowon Browser
Coowon game browser is a Google Chrome based browser. It can help you perform automated tasks ( botting ), Record & Play mouse clicks, login multiple accounts in special tabs, control game speed ( web page time ) while playing games. Besides, it also supports some popular features like Mouse Gesture, Drag to Go, Double Click to Close Tab, etc. It's the best choice for web gamers.
http://coowon.com
Open Subtitles MKV Player
What's new in Open Subtitles MKV Player 4.7 version
MKV Player uses its built-in codecs when there is no better in the system
A new video - VMR9 output
Rotation of the screen: 90, 180 and 270 degrees
New playback file formats as "webm" and "bik"
Get and give support
Share your thoughts at our forum and spread the banners. If you are interested to translate this DivX
player to your language, just look at ini files in installation directory or download english ini
Subtitles Player
Special efforts to effective subtitles handling and manipulation
www.OpenSubtitles.org site API integration
Intelligent subtitles handling, displayed according of user reading abilities
Speech synthesizer for subtitle reading in subtitles player
search and download subtitles, vote, report, upload subtitles
MKV Player
Play DivX, mkv, wmv, avi, Xvid, DVD, MP3, MP4, VOB, 3GP, FLAC, Flash, QuickTime and others
Supports new media formats in MKV PLayer
Detection of missing codecs
Live Update to the latest version of codecs, so every format is playable
Fullscreen on 1-4 monior playback, you can view the video in fullscreen mode on TV connected to one
of the four outputs, and work on a standard windows desktop at the same time
DivX player
Ability to play videos directly from RAR files
Playlists support
Password protection of media files
Menu creator in DivX player
Fully skinnable windows (Media list, Play list, Equalizer)
Sound Equalizer
Bookmarks support (add, edit)
AVI player supports Drag-and-Drop
Localized to many languages
Free media converter included
Available in many languages
Download and convert youtube videos in YouTube player
http://www.opensubtitles.us/opensubtitles-player
VirtualDVD
Features of product
* All supported CD/DVD/Blu-ray image formats
CloneCD (*.ccd), CDRWin (*.bin), Cue Sheets (*.cue), CDImage (*.img), ISO (*.iso),
BlindRead (*.bwt), BlindWrite (*.b5t; *.b6t), Alcohol 120% Image (*.mds;*.mdf),
Disc Juggler (*.cdi), Instant CD/DVD (*.pdi), Compressed ISO (*.isz), Nero (*.nrg),
CloneDVD (*.dvd), CDSpace6 (*.LCD)
* Emulate up to 24 SCSI devices in all
* Perform image mounting to local NTFS folders
* Customize virtual drives: change a drive letter, DVD region
* Support Encrypted isz(Compressed ISO) file
http://ohsoft.net/product_virtualdvd.php
Meni je ova tema skroz besmislena na ovakvom forumu.
Pa potpuno je nasumicna tema, evo na ovoj strani virtualni drajv - browser - backup - browser - antivirus - video plejer - virtualni drajv...
Kome treba browser, on pogleda odgovarajuci podforum i temu, ko trazi antivirus - opet ima zasebnu temu...nelogicna tema skroz.
Tema je stara 8 godina i jos uvek izdvojena, ali nije jedina zaboravljena. XP je vec proslost, a i programi su se promenili.
A ako ti zatreba da postavis temu o ciscenju virusa/malware, za to nije predvidjen podforum.
One teme o freeware i portable softverima su takodje bez veze. Ako vec preporucujes neki softver, preporuci neki koji koristis i ako si sa njim zadovoljan, a sajtova za download besplatnih softvera na google ima da ne mozes da ih pregledas.
Comodo Internet Security 7 Final
New:
Viruscope
Viruscope monitors the activities of processes running on your computer and alerts you if they attempt to take suspicious actions. Apart from forming yet another layer of malware detection and prevention, the sub-system represents a valuable addition to the core process-monitoring functionality of the Behavior Blocker by introducing the ability to reverse potentially undesirable actions of software without necessarily blocking the software entirely. This provides more granular control over otherwise legitimate software which requires certain actions to be taken in order to run correctly. Viruscope works using a constantly expanded list of activity ‘recognizers’, which allow the software to detect, block and undo many potentially unwanted actions.
Website Filtering
The new website filtering section gives CIS users a powerful and easy way to allow or block access to specific websites. Website access rules can be created for particular users of your computer, which makes this feature very useful for both home and work environments. For example, parents can block juvenile users from visiting inappropriate websites while companies can prevent employees from visiting leisure sites during working hours. You also have the option to create a log event whenever a user tries to visit a website which is in conflict with a rule. CIS ships with several preset lists (or ‘categories’) of URLs which can be added to rules that you create - including the 'Malicious sites category', the 'Comodo Safe category', the 'Comodo Phishing category' and the 'Comodo Malware category'.
UI Update
The CIS user interface features several design and UX enhancements which allow you to accomplish tasks faster while keeping you better informed than ever before. New themes include the bold new ‘Metro’ theme.
Process Activity Dialog is added.
Added 'Please call a live expert' balloon message in main GUI when running into 'At Risk' status.
Virtual Kiosk is renamed to Virtual Desktop
Protected Data Folder
New data security feature which makes important files completely invisible to programs running in the sandbox. Files placed inside a ‘Protected Data Folder’ cannot be read, accessed or modified by any sandboxed application.
Improved
~700% Faster Sandbox.
All CIS Advanced Settings components are now accessible via CisTray menu.
Windows in 'grid view': Improved file search operation and added 'search completed' notification; added 'Jump to Folder' option; columns now retain their widths as last changed by the user.
AV Scan results and Rating scan results windows can be viewed in full screen mode.
CIS UI tooltips now correspond to Windows style.
Fixed
More than 300 bugs are fixed
Kako kome...
Meni je baš trebalo ovako nešto, pošto me defaultni windows tool često zeza na nekim mašinama.
Često mi za neke diskove prijavljuje da se koriste i da ne mogu da se vade, a ne koriste se, a isto tako ne može da pobije neki servis ili program koji koči dati disk, pa ipak mora restart mašine da bi ga iščupao.
Valjda ću s ovim moći da rešim te probleme.
Hvala, kritika. cheers
