39.95€
Ja tipujem na neki preorder od ~27 j€vropljana.
ja malopre odigrao jedan run, sve je bilo ok, bez laga.
Nadam se da je problem resen konacno, poslednjih 4-5 dana je bilo neigrivo.
preorder na Battle.net?
Hex Editor (recommended to use Hex Fiend if you are using Mac)
Steps on using Diablo 3 Exploit RMAH Bid Cheat
Note that the steps in here are only an educated guess on how Diablo 3 hackers perform the Diablo 3 RMAH bid cheat. We will not spoon feed you on how to use some of the tool involved in this. We will just quickly brief you on how the process is done.
Look for an item using the RMAH.
Dump the memory. (memory editor can also be used)
Scan for the item memory address (E.g. 0x1b450c60)
Find the “real” reference for the item.
Find the hex values for the bid confirmation and buyout confirmation.
Switch the bid confirmation with the buyout confirmation.
Find the hex values for the bid button and buyout button.
Switch the bid button with the buyout button.
Click the bid button.
Tada!
4 Pasivna skila:*Life Steal is less effective when you are higher level.
*At level 60, Life Steal gains a 0.10x multiplier.
*At level 70, Life Steal no longer functions.
dobri i losi serveri
https://docs.google.com/spreadsheet...S1JhU0xjUmVnaFRXVGxhVW44dUE&usp=sharing#gid=0
red = lag
green = lag free
nesto sto sam sinoc primetio, kad god sam igrao act1 bez decaying crypt igra nije lagovala uopste, cim je krenuo lag tu je bila i crypta
Sta radi ovaj sugavi Blizzard?Ovo lagovanje traje vec 2 nedelje,jer imaju oni uopste neke tehnicare da to rese?Oni su multimilionerska kompanija i ne mogu da rese problem?!Ovako nije bilo ni kada je izasla igra!
