ZOPO C2 (Platinum, ZP980)
Dzekson
Banned
Banovan
Narucio sam preko kolege ovaj telefon, igrom slucaja dobio Premium verziju koja je "izlecila bolesti" prvobitnog modela, pakuje malo jaci chipset i pravo Gorilla 2 glass staklo.
Malo je reci da sam odusevljen uredjajem. MTK procesori su iz dana u dan sve bolji, a sama izrada telefona je preterano dobra, materijali veoma kvalitetni i apsolutni protivnik predrasudi da je "kinesko lose".
Telefon sam postavio u Android teme, radije nego korisnicki opisi, jer nas ima podosta sada sa C2 telefonom, a verujem da ce nas biti sve vise.
SPECIFIKACIJE:
Model ZOPO C2 Platinum
Band 2G: GSM 850/900/1800/1900MHz
3G: WCDMA 850/2100MHz
Sim Card Dual SIM Card(one Micro SIM card) Dual Standby
OS Android 4.2.1
CPU MTK6589T, Cortex A7 quad core, 1.5GHz;
GPU: PowerVR SGX 544
ROM 16GB
RAM 1GB
Screen
Display Size 5.0 Inch
Type LTPS screen, OGS technology, Corning Gorilla Glass
Resolution 1920 x 1080 pixels FHD screen, 440 PPI
Screen Color 16000K Colors
Card Extend Support TF card up to 64GB extended
Dual Cameras, front camera 5.0MP(interpolation 8.0MP), back camera 13.0MP with
flashlight and auto focus, up to 4096 x 3072 pixels resolution;
support full screen capturing
WIFI Yes, 802.11 b/g/n, support LDNA, WiFi direct and WiFi hotspot
Bluetooth Bluetooth 4.0 with A2DP
Gravity Sensor Yes
Multi-Touch Yes, 5 point touch
Dimensions 143.3 x 70.2 x 8.5mm/5.64 x 2.69 x 0.33 inch(2.47mm ultra narrow betel)
1 x 2000mAh Battery
1 x USB Cable
1 x Charger
1 x 3.5mm Earphone
1 x User Manual(English-Russian-Spanish-German)
1 x back cover with flip protection
PAKOVANJE:
U paketu se nalaze:
slusalice, USB kabl, punjac, dodatni back cover sa flip zastitom i uputstvo
DIZAJN I IZRADA:
Telefon zaista izgleda predivno, kada je screen-off pogotovo. Sto kaze moj drugar, "kao monolit" jer je Gorilla zatamljena i onda sve izgleda crno, homogeno
Sas zadnje strane telefona se moze primetiti veoma kvalitetna izrada u smislu kompaktnosti hardvera, kao i opcije u vidu Micro SIM, SIM, i MicroSD slot-a. Telefon dolazi sa internom memorijom od 16GB (nove porudzbine za C2 Platinum sada nose 32GB) Kao i baterija koja je deklarisana na 2000maph sto bi teoretski trebalo da je uzasno malo ali ne i na MTK 6589T chipsetu koji nije zasnovan na Cortex A9/A15 resenjima vec na A7 (Power save resenje) Tako da i pored 1080p ekrana na 5 Inca, telefon biva u stanju da pored ekstenzivnog maltretiranja progura i dan ipo. nesto sto nisam primetio ni na S4/Note2 telefonima jer im je procesor jednostavno jaci i vise trosi.
Uz telefon pored zadnjeg veoma tankog back cover-a dolazi i cover sa zastitom, koji kao i na S3/S4 Samsung telefonima stiti sve osim ivica. Kvalitet cover-a je u rangu sa najmodernijim telefonima.
ZOPO C2 od 5 inca, ZTE Blade3 od 4 inca, Samsung Galaxy S3 od 4.7 inca jedan pored drugog kao referent velicine. Zanemarite cinjenicu da je S3 slomljen
OPERATIVNI SISTEM I UPOTREBA:
Na telefonu se nalazi Android 4.2.1 od ZOPO kompanije, sa veoma malo bloatware-a, i sa vecinom AOSP programa u sistemu. Konkretno jedine aplikacije koje su ne-stock android su emotion pack, i nekoliko widget-a, kao i movie studio, i preinstalirana vecina social app-ova (tviter, fb, whatsapp, itd)
Zanimljivo je da ZOPO developeri izgleda znaju ko ce da koristi njihove uredjaje , tako da su fabricki podesne neke stvari koje napedni korisnici uvek sami moraju da menjaju, kao sto su:
USB debugging ON
Untrusted sources
Developer options
Connection type: USB Storage
Nakon jednostavnog Root-a sa MTK root tool-om (zanimljivo, na kineskom forumu pise da je ovo zvanicni root tool od samog MTK sto deluje krajnje nemoguce) koji se obavlja jednim jedinim klikom kroz PC aplikaciju, telefon vec postaje masina vredna paznje. To malo bloatware-a se moze skloniti, i onda jedino sto moze da bude problem je Kernel koji je napravio komunisticki kolega. Prve verzije C2 sa 4GB interne memorije i 1GB RAM-a su imale problem sa Ghost touch pojavom, neki Platinum korisnici su cak prijavljivali isto ponasanje ali na mom telefonu toga nema, nakon tri charge cycle-a. Navodno je wgreska u Kernel-u koja dozvoljava da se sistemski korisen RAM prerasporedi na nesto drugo pa onda TS pravi ghost touch, sto se otprilike i da resiti ako se pojavi (meni nije) kontrolom stvari u pozadini.
Brzina sistema je za apsolutno svaku pohvalu. Bez bloat-a odgovorno tvrdim da je ovaj telefon jacih preformansi nego S3 sa Touchwiz jer S3 ume da "secne" pogotovo u browser-ima prilikom vece kolicine podataka, dok se to ovde ne desava.
Beenchmarke i mrtvo slovo necu pisati, prenosim isksutva iz koriscenja:
Great little war game
FIFA 12
The Room
rade besprekorno na telefonu. Nisam probao neke jos zahtevnije 3D igre jer ih generalno ne volim ali znam da FIFA12 nisam mogao da poguram korisno ni na nekim Dual core telefonima. Nijedan lag ili bug nema na C2
Launcher sam zamenio sa Nova laucnher, i stavo Box effect scroll, response i pored tog efekta je da sve leti, momentalno.
Sve u svemu, ja sam prezadovoljan. Ne treba biti skeptican prema MTK procesorima iz koreje i njihovim telefonskim izradama iz kine, i potrebno je samo malo rizika, koji se u mom slucaju isplatio. Telefon je 5inch zver, bas kakvu sam hteo i malo je reci da sam odusevljen. nakon 3 punjenja nijedan problem nisam susreo, i nadam se da ce tako ostati.
Svima zainteresovanima preporucujem da razmotre kupovinu C2 platinum ili ekvivalentnog 6589T modela po vasem izboru velicine ekrana.
Lici na iPhone Galaxy Nexus :)
Ko na koga lici, danas kada telefon nema druge opcije nego da bude rectangle, rounded rectangle ili rectagnled circle je besmislena rasprava. Jedino da neki proizvodjac napravi trouglasti telefon, tek tada ne bi bilo komentara: "jao prekopirali su samsung/apple/HTC/ovog onog
Nisi razumeo sta htedoh da kazem.
Kao da je lose to sto lici na iPhone Galaxy Nexus, mnogo mi je gotivan ovaj stealth dizajn :)
A sto se ostalog tice ne sumnjam da je odlican samo da je malo veca baterija al' dobro.
attachment.php
Za zainteresovane za belu verziju, dobijaju se beli usb kabl i bele slusalice :D eto, samo da pomenem taj detalj.
270 USD, ako zamolite kineza da vam posalje kao privatno lice i potpise se kao western (John Johnson) ili jos bolje srpsko ime, carina ce da ga pusti ako je na komad. u 270 se uracunava i Free shipping.
http://www.zopomobileshop.com/126-z...d-smartphone-international-version-white.html
na linku imate sve accessories kao dodatnu narudzbinu, kao i shipping insurance (5 dolara) mada vam ne treba , samo tracking number koji cete dobiti je dovoljan.
Konkretno moj je narucen za TAOBAO i to za mnogo manje novaca i kako spomenuh u kineski telefoni thread-u, bilo bi dobro da imamo nekog kineza-srbina da nam narucuje sa Taobao. Ja sam em manje platio, em dobio crnu verziju koju zvanicni zopo mobile shop ni ne nudi a ima je.
@hsv - izvini mislio sam da karikiras :) Meni je ovaj stealth look sto ti kazes, najlepsa stvar u dizajnu.
Upravo htedoh da pitam...
I koja je na kraju "neto" cena?
1.500 juana jer je mu je kolega kupio kod Taobao prodavca.
Vidi Igoritza, Taobao (C2C) i Tmall (B2C) su namenjeni stanovnicima CN, HK, MO i TW i to dobro znaš :). Za nas van zato postoji Aliexpress.
Jeste jeftinije, to stoji, ali šta ćeš sa garancijom ako nešto ode po zlu?
Ljudi šalju telefone nazad u NRK (iole pošteniji prodavac neće praviti problem), a ko je manji kvar, Kinezi pošalju deo pa da ti ovde odrade (nema o tome na hrvatskim forumima, ali i drugde).
Crna Platinum verzija od avgusta ima Gorilla staklo kao i bela. Verovatno znaš, jedino je dobra protiv grebanja.
Zopo mobile shop prodaje crnu verziju ;):
http://www.zopomobileshop.com/134-z...d-smartphone-international-version-black.html
I pazi na telefon jer je fleksibilan tj. lako se uvija pa da ti ne pukne ekran.
Od 2.41:
[YOUTUBE]6v49n33p69g[/YOUTUBE]
Holding the phone like a hamburger with your thumbs along the bottom, you can easily flex the Zopo C2 with very little effort! In normal use this is never really going to be an issue, however we can see that placing it in the back pocket of a pair of tight jeans might crack the display or even break the phone in two when sitting down!
http://www.gizchina.com/2013/07/08/zopo-c2-platinum-review/
I potvrda na njihovom forumu:
http://forum.zopomobileshop.com/thread-814-1-1.html
Ovo je worst case scenario jer ne znam stvarno ko jos u realnom zivotu seda na stolicu sa touchscreen telefonom u zadnjem dzepu od (uskih) farmerki :D
ko nosi telefon u zadnjem džepu ***? :)
Duke - nisam video ovu crnu verziju na zopo sajtu omaklo mi se.
Sto se flexing-a tice, ja evo pokusavam moj malo da "zafleksujem" i nece, bar ne kao na ovom klipu. Ovaj car je pritiso sve snage prstima izgleda. Ne branim telefon, nego ovaj flex jednostavno ne moze da se savije ko na klipu. Mislim da je ovo provalio neko random, mogu da se zakunem da se Galaksije isto tako mogu fleksovati, one su od Polikarbonata u slojevima, a ne od ABS + PC sto znaci da su jos podloznije savijanju. bas cu da probam sa nekim Galaksijem.
Na kraju krajeva ja nikad ne bi TS telefon stavio u farmericama da bude u zadnjem dzepu. Zadnji dzep je em losa ideja, em mamac za cigane.
Sto se same garancije tice, ja sam od dodicne odustao kad sam telefon platio, jer je ima kolega - a meni ne treba. Toliko zvrndanja za popravku koja ce se cekati potom, i rizik da ti carina naplati popravljan telefon su mi stvari koje su me odvikle od garancije u startu, svestan sam da je nemam.
Poenta je da imam telefon koji izvodi 90% preformace funkcija jednog One-a ili S4ke, a platio sam ga manje od 200 evra i prezadovoljan sam izradom i dizajnom, mozda i vise od brendirane braće. Brat ima S3 i pod ugovorom je sa Telenorom da moze da uzima sta mu se prohte na ime firme, i planira zapravo S4 da uzme uz doplatu (interne telenor seme), i kad mi je on rekao da je odusevljen sa C2, direktor jedne domace institucije koji ne vadi S3 iz ruku kaze da mu je C2 vau efekat. Ovo je definitivno jedan od onih uredjaja koji uzivo izaziva daleko poziutivniji efekat nego na klipovima i slikama.
Slazem se,koliko danas kinesko-srpski recnik u ruke,torbu u sake i pravac Kina.Da te mi lepo prizetimo tamo.Kad se vec nisi snasao kada si isao prvi put.
Salu na stranu,kakva je situacija sto se tice gps-a,konkrektno kako radi sport tracker aplikacija.
Kako radi Skype video (da li se brzo pokreće i da li ima "štucanja")?
Kakva je brzina učitavanja kompleksnih web stranica (i da li "zabada" pri skrolovanju istih)?
Ja ne videh na sajtu, da li postoji neka verzija sa 2 gb rama? I ima li custom romova?
Nisam se jos igrao sa GPS-om. Postoji neki GPS booster za generalno MTK telefone koji je neophodno primeniti na android ali cu naknadno da se igram sa time. sve cekam da se jave ova dvojica sto su pre mene uzeli C2 .. :)
Exodusbgd - ne zabada apsolutno nigde, kako rekoh sve aplikacije skoro su AOSP, te je telefon podosta "slobodan" da se razradi kad se pokrene nesto. Preko Dolphin-a sa nekoliko tabova ukljucujuci i Facebook u desktop mode, sve ferca i nema kocenja. Skajp jos nisam koristio.
Tetsuo - Ne znam za 2GB, konkretno ovaj C2 Platinum ima neki Marsapa ROM od nekog italijana, kojim su svi zadovoljni manje vise, a decko se onako bas trudi i svakih malo malo pa izbacuje update sa uglavnom fix-evima prethodne verzije:
http://www.androidiani.com/forum/zo...3-980-gizchina-rom-4-2-1-aroma-installer.html
najbitnije je da je ROM primenjiv na Platinum verziji, odnosno onoj koju salju u srbiju i koju ja imam.
Ekran
Ekran puca ko od šale, to je opštepoznato za C2, nema veze da li je običan ili platinum. O tome ima koliko hoćete i po kineskim forumima uključujući i zvanični kineski ZOPO forum. Ne znam zašto ste svi "navalili" na Endrjua i scenario sa zadnjim džepom, nije on to provalio već mu je rečeno u komentarima. Ljudima je telefon ispadao sa male visine i ekran pukne bez problema. O tome se radi, a to ne bi smelo da se dešava.
Koliko sam čitao, problem je u internom dizajnu telefona jer nema metalno ojačanje. ZOPO je išao na eksterni dizajn u čemu su uspeli (telefon je meni lično prelep, a i tržište je pokazalo), ali je cenu platila laka lomljivost ekrana (podsećaju me na iPhone).
Cena ekrana je 500-550 juana.
Zanimljivo je da 卓普 tvrdi da Platinum verzija ima Gorilla staklo, ali to nigde ne tvrdi u Kini. Pregledao sam sve jednu reklamu za C2 Platinum i to nigde ne stoji. Zvanična prodavnica.
http://detail.tmall.com/item.htm?spm=a1z10.4.w4004-3311965972.4.hPvsvv&id=18600698781&tbpm=3
I ne samo to, na zvaničnom sajtu isto nigde ne piše.
http://www.zopomobile.com/xiaohei.php?id=148
http://www.zopomobile.com/xiaohei.php?id=149
Nema ni na promo fotografiji:
A nema ni u specifikacijama:
尺寸 5.0英寸
分辨率 FHD全高清级别1920×1080像素,441 PPI
发色数 1600万色
对比度 1000:1
屏幕材质 TFT
屏幕技术 LTPS低温多晶硅工艺,2.47mm超窄边框
触摸屏 电容屏,多点触控
To što piše na njihovim sajtovima za izvoz je prazna priča. Po meni su to objavili da smire talasanje oko lakog pucanja ekrana i to su priču prvo pustili po kineskim forumima. Da ima, reklamirali bi kao što Lenovo reklamira Gorilla 2 staklo za P780 (jasno stoji u reklami i u specifikacijama). Isto važi i za Mlais MX58. Aliexpress prodavci isto ne stavljaju da C2 ima Gorilla staklo, a nema ni na prodajnom pakovanju.
Takođe, ni sami ne znaju koliko im je težak telefon jer se specifikacije razlikuju na domaćem (kineskom) i izvoznom sajtu :S:.
Zanimljiva mi je zvanična autonomija baterije (Google prevodilac):
2000mAh lithium polymer battery
Talk time: 3G talk up to 15 hours, 2G talk up to 18 hours
Standby time: 3G standby up to 450 hours, 2G standby up to 470 hours
Internet time: 3G Internet access for up to 10 hours, WIFI Internet access for up to 11 hours
Video playback: Up to 4 hours
Audio playback: Up to 27 hours
Za razgovor neću ništa reći. Verovatno je moguće jer je GSMArena izvukla na Oppo R819 čak 19 sati razgovora u 3G modu.
Ono što ne pije vodu su vreme mirovanja, a pogotovo surfovanje interneta preko 3G i WiFi.
Zamolio bih vlasnike C2 da izmere jer nema šanse da može više izgurati od mog sve sa turbo verzijom čipa, 500 Mah manjom baterijom i FHD ekranom.
@Igoritza
Vidi za garanciju, ljudi preko PayPala dobijaju novac nazad za poluispravan, a pogotovo neispravan telefon. Najvažnije je snimiti otpakivanje, onda se lagano dobije spor preko PayPala, a i mislim preko Aliexpressa. Šta misliš zašto Rusi masovno snimaju otpakivanje :)?
I nemoj misliti da "ocrnjujem" telefon, znaš da imam ZTE V987, imaju isti "DNA" (čip). Ovo u vezi ekrana je prijateljski savet. I sam sam naveo sve potencijalne probleme i negativno u vezi V987. Telefon (C2) ima nesporno pogođen odličan dizajn i to ga prodaje.
Testiraj brzinu downloada preko Speedtest.net. Interesuje me zato što po ZOPO-u, C2 ima modem koji podržava brzinu preuzimanja do 42 Mb/s.
ZOPO mobile jedan od sponzora trke u Španiji :d:
http://www.avwc.org/fotos/TOSSA/tossaangles.htm
P. S.
Ti si četvrti na forumu koji je kupio C2 (owin, valeksandar i subtractor).
Žaba OS 5
Ovo sam stavio kod mene u temu, pa ću i ovde uz male izmene.
Juče je izašao 乐蛙OS5 tj. LeWa OS 5 (žaba).
Ko zna, to je drugi najpopularniji Android OS u Kini iza neprikosnovenog MIUI-a.
Prva dva podržana telefona su ZTE V987 :) i TCL Idol X S950.
Danas su počeli izlaziti ROM-ovi i za druge modele: ZTE V967s, Huawei G510s, Huawei G700, Lenovo S920, AMOI N828, ZOPO C2, Jiayu G4, Neken N6, Xiaocai X9 i G'FIVE G9.
ZOPO C2 ima razvojnu verziju. Ima uputstvo za flešovanje, ne može se promašiti. Prethodna stabilna 4.1/4.2 verzija je nedostupna.
Promo video:
[YOUTUBE]91g8SsVc3Ig[/YOUTUBE]
LeWa OS 4.1 promo video:
[YOUTUBE]q_36MhVl_-0[/YOUTUBE]
Duke - ti si kralj :d
citajuci tvoje kriticke tekstove, ispada da je telefon uzasno los, a vidim da ne mislis tako jer znam na sta ciljas sa komentarima, al ne znaju oni koji ga nemaju :)
Dizajn telefona jeste pun pogodak i meni glavni selling point a sve ostalo su kompromisi.
Mene recimo najvise odusevljava sam rad uredjaja. Nigde do sad nisam naleteo ni na jedan lag ili bug, u radu koje inace obicno srecem sa A5 single, ili cak i A9 dual core resenjima. C2 se pokazao za sad (4 charge cycle) kao hardverski jaka zver. uz napomenu da sam na ZOPO 4.2 Android verziji sa root-om. Sto se baterije tice, ja sam sad sve vise ubedjen da je bez obzira na prozivodjaca, rad Ly-polimer/Li-ion baterije lutrija jer ja ne vidim losu stranu 2000maph baterije, odnosno "slabog kapacitetta za fullHD" jer mi drzi uz maltretiranje par procenata preko 24h.
Ekran evo sad kad razmislim, logicno je da puca. Ovde je staklo (koje god da je) "naslonjeno" adhezivom i verovatno nekim tackastim ili linijskim resenjem da ne kliza, ali okvir i obod nema. 10+ za dizajn, 5- za safety.
sto se tice download-a, provericu brzine samo mi ovo objasni:
sinoc, preko VIP smart paketa (najbrze sto vip nudi), u jednom trenutku u centru grada mi se pojavio umesto H oznake, H+ oznaka, i primetno brzi protok, sto nisam imao na Blade3 nikada ... ?
generalni moj zakljucak je da su prednosti:
1080p @ 5 inch
1GB RAM, 16GB ROM
Quad core MTK CPU
battery save zbog A7 arhitekture
pretrerano lep dizajn
mnogo veci plusevi nego sto su navedene mane:
opasnost od pucanja TS-a
ghost touch (ja nemam, nemaju ni vecina Marsapa rom korisnika)
bend flex
24h može svaki tel da izdrži. koliko ti h ekrana imaš, to je pitanje :) radi li net stalno ili se pali po potrebi, osvetljenje itd...
Nikad ja ni na jednom android telefonu nemam auto brightness, iskljucivo 100% dok ga koristim. Je*o ekran na telefonu od XXX evra ako ce da bude dimmed sve vreme.
Ocu da kazem da izdrzava 24h+ u trenutcima kad mu dusu vadim jer je nov i stalno ga cackam. :)
znači zopo c2 sa 5" ekranom i baterijom 2000mah drži 24+ h sa jedno 6-7h ekrana (stalno ga čačkaš i dušu mu vadiš) na 100% osvetljenju? i net i sync su pretpostavljam uključeni uvek?
jok, data palim samo po potrebi jer me izludjuju reklame i notifikacije svega i svacega, a Wifi po istom rezimu. Brightness full 100%
juce:
oko pola sata Buttons & Scissors
browsing od oko sat vremena preko data
u par navrata WiFi i skidanje sa marketa nekih apova
total 16 min razgovora
probavanje neke igre sa OBB fajl instalacijom (ne verujem da se preko USB kabla napunio nesto za 5 min)
Browsing po telefonu od oko sat ipo-dva
uvece je ostalo 23%, ujutru je skinut sa punjaca.
Treba skapirati da je A7 procesor BAS energetski efikasan, i da je najveci potrosac upravo ekran zbog velicine i rezolucije.
Na konto toga a voleo bi da Duke potvrdi, telefon se puni bar 30% brze od ostalih telefona ovih gabarita. verovatno zbog manjeg kapaciteta baterije, ali meni se za pola sata sa >15% podigne na 100%
ne znam da l si upoznat ali ne moraš da zapisuješ upotrebu na papir, odeš u battery usage i klikneš na ekran :)
Ta brzina punjenja nije ni teoretski moguća tj. moguća je ako koristiš punjač od 1A, a baterija je od 500mAh. Pre bih rekao da je u pitanju neki bag sa battery stats.
Inače, čestitam na kupovini. I ja sam pre par meseci bio blizu kupovini ovog modela.
Moguce, telefon inace ne punim sa ZOPO punjacem vec sto mi ostao od Nexus 4, al kapiram da je identican proces punjenja.
Ako telefon ne moze da povuce, dzaba ti jaci punjac.
Sa punjacem od n4 bi ti teoretski trebalo 1h30min da napunis sa 15% do 100%.
