Bitcoin [BTC] (SHA-256)
Ti ništa lepo nemaš da kažeš već nedeljama, samo ti nadgrobni spomenici :d. :wave:
Jel moze neka analiza o korelaciji TORa i BTCa?
Ocigledno je ima cim ih svi dovode u vezu danas/juce...
A što su to bila lepa vremena kad smo počeli, da smo znali šta će biti sad pevali ,)
Izgleda kinezi aktivirali nove mašine kad diff ovako skače, sad će ići preko 30% garant :)
pa ima tolko da se ukake da ce na kraju da rade sa manjom zaradom nego sto je bilo ranije sa GPU-ovima
Ja verujem da ce cena BTC polako krenuti da skace, jer ko je ulozio u asic nije lud da dumpuje... a i verovatno je duze u igri da ne naseda na dumpove velikih manipulatora
"But, You ask: "What does anonymity have to do with virtual currency, and why is drug trade and TOR being mentioned in the same sentence?"
TOR is a simplistic mechanism by which your web traffic can be masked (ala Pirate Bay or Torrents) through networked proxies. People use it with encryption to effectively hide the online footprint (or at least obscure it) for a variety of reasons. Unfortunately, so do criminals and individuals who have strong motive to hide their actions online.
This gave rise to a need for a non-audit-able means to exchange services or goods without the use of regular banking systems. Enter bitcoin."
http://www.brianmulford.com/digital_root/2013/08/tor-bitcoin-grey-markets-and-anonymity.html
"But another big reason for the currency’s success is its role in dodgy online markets. Although tracing Bitcoin transactions to real people is not impossible, the currency’s relative anonymity and ease of use makes it a natural conduit for criminal funds. On the website Silk Road, a sort of eBay for drugs hidden in a dark corner of the web known as Tor, Bitcoins are the only means of transaction. ...Bitcoin transactions on Silk Road are now worth $1.9m per month..." (pre godinu dana!)
http://www.economist.com/node/21563...aggregation&fb_aggregation_id=246965925417366
Kad krene LTC da se prodaje na gox-u krenuce i btc zesce da se kupuje ;)
bas tako, najbolje je u pocetku prodati ltc ako se uhvati peak, zatim kupi btc saceka se da dostigne peak, proda se za kesh, sacekas malo da se strasti smire i dodje sve na svoje kupis btc prebacis na stamp i podignes
Ja ne razumem kako nasedate na taj trip o LTC-u na Gox-u. Iskreno mislim da Gox nema namere da ulaze ni centa trenutno u bilo sta. Argument protiv te moje tvrdnje je sto gube udeo na BTC trzistu svakog dana. A ja tvrdim da su za dva-tri dana trgovine u bilo kom mesecu od marta do maja, pravili profit kao sto svi marketi zajedno danas prave za mesec dana. Proverite samo koliki su bili dnevni obimi trgovine nekad a koliki su danas. I ta njihova prica o razvoju novog trading enginea je toliko retardirana da prosto nemam reci. Kompaniji koja vec ima engine (sa svim prednostima i manama), pogotovo ako ga je sama razvila, tj. tim koji su oni finansirali, sigurno ne trebaju meseci da implementira trgovinu sa vise valuta. Samo im jos trebaju retardi sa BTC-e koji ce da trpaju po 0.01LTC sa svojim botovima. Nema skoka cene bez neke globalne lagarije, kao sto je bila bajka o jadnim Kipranima, koji uplaseni za svoje pare kupuju BTC. Kako da ne. Sigurnije bi im bilo cak i ulaganje u Srbiju nego u BTC...
@student
Cekaj jer ti mislis da je MtGox objavio laz, ne budi smesan.........
Gox-u jeste u interesu da ima što bolji tradeing engine jer to utiče na stabilnost, a to dugoročno na posao. Što se tiče implementacije LTC, ako pogledaš Crypto-Currency Market Capitalizations jasno je gde se novac još može uzeti u menjačkom poslu. Dakle tu nema nikakve mistifikacije, cifre ne lažu. Meni lično je dovoljno da difficulty za GPU mining ne raste brže od vrednosti valute sve ostalo je čist entertainment.
@student
Hajde procitaj jos jednom sta je tacno objavio Gox. I sagledaj to realno a ne kroz prizmu svojih zelja i ocekivanja. To je jedan cist diplomatski odgovor, kao i svi do sada. Nisu rekli ni ne ni da, samo da ne mogu sada i da mora jos malo da se tu nesto testira i dotera. I tako pricaju vec par meseci. Predpostavljam da si bio 100% siguran da ce se to desiti u julu, a ja sam bio 100% siguran da nece. I ko je bio u pravu? Hajde da odredimo rok, npr do kraja godine? Ostace ova poruka ovde pa cemo moci da je pogledamo tada. Tvrdim da nema nista od LTC-a na Gox-u, i sve mi deluje kao da se Gox polako izvlaci iz ovog posla. Naravno, ukoliko ne dodje do neke drasticne promene u potraznji. I imaj na umu da Gox ima akumulirane desetine miliona dolara, ako ne i stotine. I vrlo lako ce upumpati te pare ako procene da im se isplati. A do tada nece mnogo toga menjati jer nema ni potrebe. Cak i ako izgube dobar deo trzista, to ce povratiti zacas gorepomenutim parama, boljom cenom, laksom isplatom... Kao sto svi skacu sa valute na valutu, tako ce i sa marketa na market, cim neki bude bio povoljniji. Zar ti ne deluje da Gox iz meseca u mesec tera namerno svoje korisnike? Te engine lag (sto mi je prosto necerovatno, npr Forex nikad nema taj problem a imaju znatno vece obime), te teze isplate, pa ogranicenja u obimu isplate, te kasnjenja...Sve mi to ne deluje nimalo slucajno...Niko nece napustiti biznis koji je isplativ i profitabilan, samo je pitanje apetita i procene. Ako je ekipa navikla da dnevno pravi milion ili vise, pa to padne na 20-30K, pitanje je kako gledaju na taj biznis.
Nisam ja nikad sporio da se moze uzeti novac, samo postavljam pitanje cene razvoja nekog softwarea, hardverske podrske za njega itd. iz danasnjeg ugla, odnosno postavljam pitanje da li vlasnik Gox-a tj. njegovi savetnici procenjuju da je taj biznis u usponu ili ne, kratkorocno ili srednjorocno. Siguran sam da ih ne zanima 2075. godina, kada ce mozda kriptovalute uzeti primat nad papirnatim novcem (hipoteticki). U pravu si da im je u interesu da imaju sto bolji engine, ako nameravaju da se bave time. Ja samo postavljam pitanje da li su napumpali pricu, uzeli kes pa imaju nameru da prodaju biznis...A njihove akcije (ne mislim na izjave, nego na dela) mi govore da se polako izvlace iz cele price...
I meni se sve cini da je u pitanju polagano izvlacenje iz posla. Ubise ASIC mineri celu pricu, umrtvise, a njima treba obrt bez obzira koliko 1 BTC vredi, 10 ili 1000$, njima treba promet iskazan u $, sto veci. Bilo ej da miruje trziste, sve mrtvo i onda na 2h cisto iz mira nestane GOX... krece panika po forumima, i kad se vrati, jedni kupuju drugi prodaju u panici. Za naredna 3-4 sata naprave promet koliko za nedelju dana. DOsta je bilo da 2 coveka tamo (hipoteticki) u nedleju popodne u zhladno pivo izvuku mrezni kabel iz servera na 2h. Em dobiju instant zabavu em profit. I oni su ljudi, kao i svi mi. Ja bi to uradio, verujem i Student, zasto ne bi i oni? :D
Da trgovina sa kriptovalutama jenjava vrednost istih na berzi bi bila 0.0
Sve što se konstantno proizvodi, a nema ko da kupi uvek ima izvesnu vrednost, a to je NIŠTA. Nisam primetio da je btc, a ni ltc u konstantnom padu, a to što talasaju s vremena na vreme je normalno za berzu.
Gox će staviti na berzu sve što mu donosi profit, tako da ne kontam odakle te teorije zavere :)
@student
Sasvim iz drugog ugla gledamo, ti si cist skeptik po pitanju svega a i ja sam ali ti si za medalju :)
Normalno da vecina problema Gox-a nama izgledaju smesni, mi celu pozadinu neznamo, koliko ih banke sputavaju (ili bar njihova banka), koliko su lose procenili napad LUDACKIH hakera... mislim da ni drugi to ne bi predvideli... i ja ih ne krivim u celosti jer budala od lopovcina za kompom ima na hiljade i to treba satrati i potamaniti...... tek sad kontam kako njima primamljivo zvuce kripto valute da se preko noci obogate kradjom!
I ja nisam ocekivao LTC u jul-y znam da prvo dolazi nov engine i cim se on pokaze OK odma nakon toga anstupa LTC i u to sam 100% siguran, i ako se setis prve izjave moglo se zakljuciti da ne garantuju jul sto je i znacilo da 99% nece biti jul
Siguran sam zilion% da nista tacnije od ovoga nije napisano na ovom forumu, odavno,)
Iskreno, realnije su mi od cekanja LTC-a da osvane nekog lepog dana na Gox-u, delovale svojevremeno ocekivanja deviznih stedisa da ce se gazda Jezda vratiti u naredni cetvrtak sa sve parama.
Vama je srbistan iskrivio poglede, stahovito, ili gresim ako ste velike ribe koje trenutno dumpuju LTC da kupe jeftinije :p
i ja isto mislim da je samo pitanje vremena kada ce ltc na gox... Pa njima je u cilju da je sto veca trgovina i provizija.
Jes, Mtgox gladljiv na pare, kako da ne. Da sam to procitao u zutoj stampi pa i da mi bude jasno.
Najveca berza bitcoina koja drzi apsolutu vecinu gleda da se izvuce iz posla koji im donosi sigurnu lovu?! Sigurno ce prodavati automobilske gume ;)
Dali ste svesni koliko to nema veze s mozgom? Kao da imas autoput i mlatis pare na putarine i onda krenes kao da razmisljas da izadjes iz posla i zatvoris autoput.
Nije sporno da mtgox ima problema i nije sporno ni da ne zure za ltc-om ali mislim da je samo pitanje vremena. Sutra ili u februaru, svejedno.
