Diablo 3
Opa! Cestitam, odlicni su, svi potrebni statsi i jos pickup... njam njam! 🙂
ma nema sanse, ni promil.
Recimo da najave expanziju na Blizzconu koji je u novembru, pa uvek mlate pola godine (najmanje, a nekad i vise) dok ne puste betu.
Pa beta testiranje 3-4 meseca..
Ovo nije novi naslov, nego ekspanzija. Bete za takve stvari njima mnogo krace traju. Ali ni sam ne verujem da ce Q1/Q2 2014., verovatno kraj godine.
Ako budemo imali sreće, ekspanziju dobijamo krajem 2014-te, pre toga, nema šanse... 🙂
znas i sam koliko je trajala HotS beta 🙂
-On April 30, 2012, Blizzard announced that the latest multiplayer build of Heart of the Swarm would be playable at the MLG Spring Championship (June 8–10) ahead of a planned beta release. No actual release dates were specified.[16]
-As of June 15, 2012, the game was primarily complete. The only unfinished thing is "tuning and polishing".[17]
-On August 15, 2012, Blizzard announced that the multiplayer beta would be beginning soon.[18] As of September 4, 2012, Blizzard began closed beta testing of the multiplayer beta, releasing it to select Pro-gamers, members of the press, Arcade contest winners, and shoutcasters. The beta testers were not under a non-disclosure agreement, so they were free to stream their games, release pictures, etc.[19] The Heart of the Swarm beta closed on March 1, 2013.[20]
-Blizzard officially released Heart of the Swarm for PC and Mac systems in multiple countries on March 12, 2013.
HotS beta je imala itekako jak razlog da traje i do godinu dana ako treba. Diablo 3 nema nikakve veze sa balansiranjem PvP (posto ga jos nisu ni ubacili). Sve ostale ekspanzije su imale relativno kratke beta faze, neke cak i nisu ni stigle do bete nego su ostale alpha/closed internal family beta stuff.
mislim da bi trebalo da nam vrate pare arenu su obecali jos pre izlaska igre
obecali za kada?
Iz ciste dosade odlucim da pokusam solo ubere na mp8. Sve islo glatko (cak i Maghda & King, o Ghomu i Rakanothu da ne govorim) dok nisu dosli Siege & Zoltun. Jednostavno nema sanse. Pokusao preko 20 puta i corsokak. Bilo kojeg da idem prvo da roknem s.ebe me onaj drugi i tako u krug. BTW zabavno je do bola,taman da me malo okupira posto me je sve ostalo malo smorilo 😀. Mislim da samo moram malo da poradim na buildu.
PS. isao sa monkom 🙂
sa monkom je neverovatno tesko solo ubiti kula+siege.
Cak i najbolji monkovi imaju problem tu na mp10.
Jednostavno , imaju previse cc efekata.
Ne znam kakvi su ti statsi ali mp8 bi trebalo da mozes. probaj da nabacis neki soj sa 30%, moze se naci za par miliona
Ajde neko da mi pomogne veceras da ubijem ubere i dobijem matse za prsten, da mi brze ide farmanje : )
Izvinjavam se sto ovde to pitam al' di cu ako ovde necu 🙂 Elem, jako mi se igra D3 ali mi se ne daje bas puna cena 😀 Je l' ima neko da prodaje kljuc?
ili probaj da nadjes polovan accaunt, samo je bitno da je pouzdana osoba, verovatno bi jeftinije prosao.
Ne znam dali sam poblesavio od toliko sati igranja ili mi se cini da ima neke veze koje ti ja main hand oruzije tj. vaznost njegovih stats-a!Sva je ista oprema samo sam zamenio mesta oruzija i kao da sad brze ubijam tj dolazi vise do izrazaja CHD na main oruziju!Mozda sam to sve umislio,ali to sam primetio koliko sam pre skidao health kod "Savage Beast" i koliko sada!
naravno da ima veze, ako mislis za monka. main hand treba da ima sto veci dps
ja znam za barba, da tornadoi od sprinta gledaju dmg samo od main-handa, a njihova brzina se menja izmedju main i offhand. Zato se ide na jace oruzije i sto brzi dagger sa dobrim statsima. Tu skoro da nije bitno da li dagger ima 250, 600 ili 800 dmg...
To je za onaj ww build koji se igrao ranije na manjim mp.
Sad za hota treba sto jace oruzije u offhandu.
Za monka ja nisam znao da mora jaci dps u main, mislio sam da je svejedno... koliko znam sweeping wind gleda dmg od oba oruzija pa nema nikakve veze..
Moguce da ono zvono gleda samo main, slabo to koristim pa ne znam.
U svakom slucaju, rare ili EF u main, WKL u offhand i nema greske 🙂
edit:
a to za CHD, to nema bas nikakve veze na kom delu opreme se nalazi, oruzija, amuleti itd...
Kad udaris crit samo se pomnozi sa ukupnim chd i to je to. Isto kao i za life steal.
Jedino sto moze da pravi razliku je base dmg 2 oruzija
Najzad
cestitam
bravo !
jel se sad bacas na WD ili ostajes na monku?
Hvala na cestitkama!Sada cu polako WD-a!Ne odgovara mi bas stil igre,ali kad drugo nema sta da se igra,a da meni odgovara!Poceo sam da igram na MP8,ali cesto ginem,tako da mi je trenutno MP7 plafon sto se tice prezivljavanja!Ni oprema mi nije nizasta tako da je to za sada to,ako mi u medjuvremenu ne dosadi!
Sto se tice Diabla,ja sam moj cilj ispunio!Doterao sam jednog lika do 100-ke,a ostalo mi nije toliko ni bitno!
DiabloFans Interview With the Devs: Highlights
DiabloFans had the opportunity to speak to Josh Mosqueira, Travis Day and Wyatt Cheng and while we work on the full transcript we wanted to summarize the major points in an easy to read form.
The Game
There will be announcements about new features before BlizzCon
Even though he loves PvP, Travis hopes Diablo 3 doesn't go down the eSport road, because when you focus on that type of PvP content you’ll have diminished results in the PvE part. Diablo 3 is meant to be a PvE game
Archon and Wrath of the Berserker changes won't come in a “vacuum”. They'll be part of a bigger change to class skills. This way skill power can be redistributed more effectively
Blizzard are working on including the Mystic back into the game, but it’s still not clear what unique feature she might offer
There are talks about making Paragon levels account-wide, so that you don't feel like you're losing experience while playing your Paragon 100 character. Also potentially adding customization like stat allocation to it
If additions to the Paragon system are made, people that already have the required Paragon level will get the rewards on patch day
The Process
The different Blizzard teams not only give feedback to each other, but sometimes even help each other with development
The Diablo team draws a lot of inspiration and even “some direct ideas” from the community and even mentioned specifically some of our “Suggestion” articles that have gained some good popularity
The Console Version
The Diablo 3 team has actually just received the new console generation development kits so the translation to those platforms is yet to be done. They really like the features on the PS4 controller and want to try and do something cool with the trackpad and share button
Diablo 3 will not be a launch date title for the next generation consoles. It will come in 2014. The developers prefer to try and get the most out of the different features that platforms have, instead of just porting the game to each of them
There aren't any plans for Diablo 3 on portable devices
When an expansion comes the main concern will not be to ship it simultaneously on all platforms, but instead try to make the expansion features as relevant to each platform as possible
The Game Director
Jay Wilson approached Josh for the position of Lead Console Developer, because of their long past of working on other projects together
Josh tries to play a variety of games besides Diablo 3, like other ARPGs and even some Call of Duty in his spare time. Currently he's looking to try The Last of Us
Travis explains that Josh is the type of person that really thinks about the grand scheme of things and how the different features may pan out in the long run and their exact purpose in the game
ima li ko da jos igra ova 😛 ?
ako ima dodajte me trazim ozbiljne igrace za item farm/paragon exp farm runove dojadili mi public mnogo nobova ima :d
ShoMi#6203
napisite u poruci da ste sa foruma da znam 😀
