MagicMaster
Mislim da sada možemo da pokrenemo novu temu ...
I kraća, uninterrupted verzija ....
Nabudzeni PC uz igre koje mozes naci samo na Sony konzolama.
Ne zvuci lose 🙂.
Eurogamer: One of the questions my readers really want an answer to is whether you're going to block the use of second-hand or 'used' games, because it's a huge concern for them.
Shuhei Yoshida Do you want us to do that?
Eurogamer: No. I think if you buy something on a disc that you have a kind of moral contract with the person you've bought it from that you retain some of that value and you can pass it on. Do you agree?
Shuhei Yoshida Yes. That's the general expectation by consumers. They purchase physical form, they want to use it everywhere, right? So that's my expectation.
Eurogamer: So if someone buys a PlayStation 4 game, you're not going to stop them reselling it?
Shuhei Yoshida Aaaah. [Asks PR adviser.] So what was our official answer to our internal question? [Consults adviser.] So, used games can play on PS4. How is that?
Ram nikad jeftiniji.. ciganisu se sa 8gb...
Boris Lozac je napisao(la):A sto svi ponavljaju sok sa 8gb? 🙂
Recimo, trenutno na PC-u ne mozes da nadjes vise od 6 GB (i to je ona GTX690 Titan koja kosta ~1000$).
Problem je sto ce tih 8gb rama za 2-3 godina postati usko grlo programerima a nece biti mogucnost nadogradnje memorije kao uvek. Mada mozda (u nekom loodilu) ce i moci. Ako zele da programeri nemaju muke narednih 5-6 godina morali su da kazu da ce biti 16gb.
Watchdogs mi deluje mlako. Nije nesto cemu se radujem. Uvek se iznerviram kako posteno ne mogu da odrade prirodno hodanje ljudi. Niko ne hoda onako kako su prikazali u demou.
S druge strane imam samo reci hvale za Killzone.
Zanimljivo da nije receno uopste dal ce biti igre na fizickim medijima. Ni rec o blu ray drajvu. Iako ce ga verovatno imati vilo bi lepo da su to i rekli.
Takodje remote play zvuci odlicno ali da li ce zaista biti tako u praksi.......
Pa nista, Kaz sada ima sistem na kome moze da razbaca svoje vizije 🙂Hvala na pojasnjenju za memoriju, a koja je fora sa Kazunorijem? 🙂
Ne pricaj gluposti...
Zato sto je u pitanju veoma brza unified GDDR5 memorija i zato sto je znacajno vise od ocekivanih 4GB. (bas me interesuje kako su smestili toliko cipova i da li je u pitanju vertical stacking)
To sto je memorija unified znaci da developeri mogu da biraju koliko ce video memorije posvetiti grafickom procesoru.
U prevodu, open world igre ce znacajno profitirati od ovoga.
Takodje:
Nije memorija unified tj. nisu posebni memorijski cipovi od onih koji se koriste na modernih grafickim nego je CPU/GPU unified i zove se APU kod AMDa. Arhitektura glavnog cipa je takva da moze da koristi memoriju za sta mu treba, nema veze sa samim memorijskim cipovima.
Ovo isto mora da zavrsi u MS konzoli jer AMD nema drugih cipova. Jedino ako bude vise/manje memorije, ne znam sta drugo moze biti drugacije.
Jeste memorija unified, znaci nije slucaj kao kod PS3 gde je memorija bila podeljena na 256MB video i 256MB main memorije...Nije memorija unified tj. nisu posebni memorijski cipovi od onih koji se koriste na modernih grafickim nego je CPU/GPU unified i zove se APU kod AMDa. Arhitektura glavnog cipa je takva da moze da koristi memoriju za sta mu treba, nema veze sa samim memorijskim cipovima.
DS4 cu morati, sve vise mi se svidja
