Samsung Galaxy S2 - NEAT ROM
To znači da nije našao kod. I meni sa tom aplikacijom nije moglo da nadje. Probaj sa Helrozovom aplikacijom
ok, tu sam. ko ima sta da pita, nemojte samo za otkljucavanje. to cemo sutra uvece, mrtav sam umoran
Sale, jel velika rabota da se u Lite verziji promeni status bar u sivu boju kao u Full?:) Baš mi se svidja
Ok Guys, you know what's coming...​
>>>>>> JB NeatROM Lite <<<<<<
XXLSJ NeatROM Lite v4.0
Hello Guys
If you like my work, please consider a small donation to help me continue developing​
EVERY DONATION IS MUCH APPRECIATED, NO MATTER THE AMOUNT​
Firmware: I9100XXLSJ (4.1.2)
Build date: Tue Nov 6
Modem: XXLS6
CSC: XXLS1
Change List: 462349
Kernel: XXLSJ-PhilZ_3.5
Available languages in Rom: Catala, Cestina, Dansk, Deutsch, English (Australia), English (United Kingdom), English (United States), Espanol, Estonian, Euskara, Francais, Galego, Hrvatski, Icelandic, Irish, Italiano, Kazakh, Latviesu, Lietuviu, Macedonian, Magyar, Nederlands, Norsk bokmal, Polski, Portugues, Romana, Slovencina, Slovenscina, Suomi, Svenska, Turkce, Uzbek, Greek, Bulgarian, Russian, Ukrainian, Serbian, Korean
Fully Deodexed
Zipaligned
Rooted
BusyBox
SuperSU
EFS auto backup
NO WIPE
Disabled boot sounds
Init.d support
JB Font
Black Status Bar
13 Toggles in Status Bar (Thanks to my friend Mirko ddd)
Multiwindow - Fully Worked (Big Thanks for master_droid)
Toggle for Multiwindow in Settings
Toggle for Multiwindow in Status Bar
Smart Stay
Toggle for Smart Stay In Status Bar
Increase Contacts adding for the message (1000 contacts instead of 10 contacts)
No Auto Converting messages to MMS
Disabled Home Button Lag
Enabled Camera Sound Menu
No Call Ring Delay
4 Way Reboot
4 Icons On Lockscreen
Enabled All Languages For Samsung Keyboard
Faster GPS Lock
Enabled Sensor Aiding For Fast GPS Lock
Enabled Media Widgets
Skip Song
Ripple Lockscreen
Toggle For Ripple Lockscreen In Settings
Enabled More Contacts (990)
Enabled Scrolling Cache
Flash Player
Large Apn List
Removed Bloatware (49 Apps)
Init.d Support
Init.d Tweaks
Build.prop Tweaks
Updated YouTube to v4.1.47
Updated Google Maps to v6.14.1
Updated Google Search to v2.1.12
Updated Google+ to v3.2.2
Updated Google Play Store v3.10.9...
and many more...
I probably forgot something
Download:
XXLSJ NeatRom Lite v4.0
XXLSJ NeatRom Lite v4.0 Mirror 1
XXLSJ NeatRom Lite v4.0 Mirror 2 Thanks to siberian tiger
XXLSJ NeatRom Lite v4.0 Mirror 3 Thanks to ApriliaM3
MD5 Sum: 12e9fe73d8604d500ad72f81d3ab09b5 XXLSJ_NeatROM_Lite_v4.0.zip
XXLSJ Removed Apps
4ecc16f370881bd6223fee2165b33323 XXLSJ_RemovedApps.zip
INSTALLATION:
BACKUP, BACKUP, BACKUP...
I strongly recommend NANDROID backup first
Installation without wipe:
-Download and place zip on internal sdcard
-Go to recovery
-Wipe cache
-Advanced
-Wipe dalvik cache
-Install Rom
Installation with Full wipe:
-Go to recovery
-Wipe data
-Wipe cache
-Wipe dalvik cache
-Mounts and storage
-Format system
-Install Rom
-First boot takes about 5-10 mins, so don't panic
-Reboot device
All the other mods will be available as soon, through Aroma Installer. I'm working on it​
Sale jel treba neki poseban kernel za novi Lite? I kojim to redosledom ide? Plus me zanima kako ide za zakljucavanje SIMa?
Nikom se na xda nije zakljucao tako da... a imam preko 6000 downloads-a za sada. ne treba poseban kernel, samo da imas cwm recovery
nije mi rutovan fon, moram li prvo da skinem negde odvojeno kernel philz 3.5 , flesujem preko odina pa onda ubacim ovaj novi lite rom? Svaka cast za rad!
flesovao siyah 5.0 i odin odradi kako treba i kad se telefon reeboot-uje , dodje od ikonice siuah kernela i ugasi se . Imao sam na njemu leak 4.1.2. sa sammobile pre flesa. nece da se upali ali hoce u recovery mod, da probam odmah onda da install from zip ovaj lite rom pa da vidim hoce li raditi?
ubacio prvo tvoj prethodni rom 3.6 lite i isto idem reboot posle flesa i umesto da digne sistem on se restartuje i vrati se u recovery mod. telefon mi je pre bio rutovan pa sam pomocu aplikacije triangle away koju si mi preporucio izbrisao root sve je bilo ok , onda sam ubacio leak 4.1.2. i to je to, samo da kazem ako nesto to pomaze.
Sale nema ikonica na lock screen-u. :p
Ja na telefonu imam Siyah. Jel mogu samo preko CWMa da fleshujem ili miram da menjqm kernel?
Napisa Sale post iznad da mora PhilZ kernel na 4.1.2.
Tako sam i skapirao, al mi rece pre toga da ne mora poseban kernel pa zato pitam. Skinem taj kernel i prvo flesnem njega, pa tek onda ROM? Jel pre fleshovanja kernelq ide full wipe i format ili nesto drugo? Ako moze beko da mi objasni
Flashuj ROM, pa Kernel i onda odradi Wipe Dalvik cache.
Restartujes telefon. Ali sacekaj da ti kaze ko vec ima Saletov ROM. Generalno je to postupak, ali mozda ima jos nesto sto treba da se uradi. Ja duze vreme nisam imao kontakta sa GSII.
Moze tako a moze i ovako
bekapuj sve aplikacije
flesuj philz-ov kernel
reboot
kopiraj rom na internu
wipe svega
format system
format preload
install rom
reboot
Ja sam trenutno na Neat UHLPZ, imao sam Siyah. Upravo sam kroz Aromu ubacio PhilZ. Hoću li morati wipe da radim ili samo novi rom da ubacujem?
Verovatno je već odgovoreno u prethodnih par postova ali ja sam se iskreno pogubio šta mora a šta ne
reboot
wipe svega
format system
format preload
install rom
reboot
Moze philzov kernel na stari Neat. Ili uopste ne palim telefon u obican boot posle flasha kernela?
Ako si na Neat-u vec onda imas CWM pa nije potreban nikakav kernel. Samo wipe cache i wipe dalvik cache, install rom
A da, bekap obavezno prvo
