iPad 3
Little else is known about this particular model, but MacRumors reports the processor appears to be based on the ARMv7 architecture supporting the A6 System-on-Chip (SoC) inside the newly launched iPhone 5. On the face of it, this means the iPad 3,6 will feature either the same A6 as the iPhone 5 or an upgraded version of it.
However, most reports agree that while Apple will introduce a new iPad, the modifications are likely only to extend as far as introducing the lightning dock connector rather than something as major as a chip upgrade. Yet the idea the next iPad could feature a new chip is not totally improbable. The iPad 2 was introduced with the A5 chip featuring a dual-core processor, which was modified as the A5X chip featuring quad-core graphics for the present top-end iPad.
source:
http://www.ibtimes.co.uk/articles/3...d36-armv7-a6processor-2013release-iphone5.htm
Yep, kad sam pisao post povezao sam priče koje sam pročitao iz više izvora... ne netu je zabeleženo postojanje iPada 3,6 koji navodno ima A6 procesor. Oznaka govori da se radi o varijaciji iPada 3, da li će se ovaj uređaj pojaviti ili ne - videćemo.
Možda se radi i o nekom budućem uređaju, mada bi bilo rano da se takav uređaj pojavi, jer ima još 6 meseci do standardnog termina za izlazak novog iPada, a to je mart.
S druge strane, iPad Mini bi trebao da bude zasnovan na A5 arhitekturi i mislim da je njegova oznaka 2,6, tako da nije ni on u piitanju
Moje licno misljenje A5X na nizem clocku na iPad mini + novi konektor koji je postao standard, iPad 4 ce verovatno doci sa novijim konektorom, HD front kamerica, eventualno jaca back kamera i A6, stvarno ne vidim sta bi jos mogli da dodaju, jedino neki cover tipa kod Surface-a.
Moje misljenje se malko razlikuje... Sa ipad 4 bi, ako imaju zdravog razuma,trebali da izmene: usb slot, slot za memorisku karticu,bluetooth treba da radi sa svim uredjajima,manje grejanje,GPS...IOS: da bude vise "user friendly",npr: ne moras da cekas jail b. da bi ubacio torent client i sl.Ali sumnjam da ce Apple da se toga "SETI"
Ma od toga nema nista..mislim na mem. karticu, usb slot itd....da su hteli ubacili bi to i na prethodne uredjaje...to im je politika
Po meni najveci minus je GPS na Wi Fi verziji, ovo ostalo sto si pomenuo tesko da ce da se seti i kroz 45 godina, jedino sto mogu da urade je da izbace 16GB verziju i krenu out of the box sa 32 GB.
Gps je najmanja mana po meni.Ios je najveca.Ali jako je ohrabrujuce da ga stalno unapredjuju.Izlazi za par meseci Microsoft office.Lepa vest.
    95.7 KB · Pregleda: 94
iOS je bolji na tabletu nego Android, tako da meni jedino što fali na iOSu na iPadu je homescreen i widgeti... Ostalo je, čini mi se, sve pokriveno.
Ja imam android tf700 i ipad 3..Mislim da gresis...Ako nema JB na IOS mogu da se slikam sa mnogim opcijama koje imam na androidu default.Sebe sam hvatao da ipad uzimam u ruke samo kada pretrazujem na google a za sve ostalo android.Moraju jos dosta da rade na otvaranju tog OSa.Bluetooth je zatvoren samo za Apple uredjaje,sto je teska glupost..Torrent ne mogu da koristim opet dok ne izadje JB za IOS 6...Ma smor je zaista..Ali je mic. office lepa vest za prolece...
Naravno, pričam sa JB. Bez JB je i meni neupotrebljiv.
BT kod Apple ne sluzi za transfer podataka vec prvenstveno za povezivanje dodataka kao sto je tastatura, slusalica sa mikrofonom ili audio slusalice i radi sa dosta uredjaja a ne samo sa Apple.
A objasni mi sta ce ti torrent klijent? Pa nije tablet za to namenjen, skidaj na PC :)
Svako usnimavanje fajla na uredjaj, bez kontrole aplikacije, nije logika rada Apple uredjaja i to je ta "religija" za to znaju i vrapci na grani i nikada se nece promeniti.
Ma kakav crni torrent na tabletu uopste, a da ne pricam sto bi Apple ikada podrzao pirateriju to odmah zaboravite.
A jedino ti widgeti mu fale. Al i to je subjektivno. Mene npr to ne interesuje al dosta ljudi bi voleli dimaju.
Shto se torrenta tiche, kome to treba ima lepo iTransmission kad odradi JB, kada se koristi sa Quasar multitaskingom skida u pozadini bez problema (bez Quasara skida samo kad je u fokusu).
Kao shto rekoh ranije, JB ipad je vrh uredjaj sa ogromnim potencijalom za zabavu.
Sto sta ce torrent, bolje je da ga ima, nego da ga nema uopste, ako ti ne treba ne moras ga koristiti, ali nekad ces morati da skines nesto preko torrenta, uostalom cak i Installous ima magnet linkove ;).
Quasar sam koristio tipa 5 minuta i batalio, licno mi se app ne svidja uopste, ovaj nativni nacin je ok.
Nego je uspeo neko da nabaci neki weather widget u Notification center, ja sam instalirao nesto preko NC settings ali nece, nudi takodje i Accu Weather app da se pojavi temp u notification center-u, ali on se refreshuje onda kada se pokrene app,...
iOS jeste najveca mana iPad-a zbog xyz stavki, koje u vecini slucajeva resi JB, ali u hw pogledu GPS na Wi Fi verziji je ogromna mana, Nexus 7 ga poseduje koliko znam.
Opet stiglo ovo njesra i debelo me iznervirao..mialim na ipad 3...supruga je registeovala svoj id i zaglavila kada je pokusala da ode na store i skine aplikaciju..Prvo, glupost je da moras da se registeujes.Na androidu to ne treba.Drugo: ne moze da skidas free aplikacije dok ne ukucas podatke o svojoj kreditnoj kartici.Izgubila se opcija "none"...obzirom da nemamo kreditnu karticu,, ne mozemo da kosristim app store...bacio sam njesra-pad i eno ga kao cigla stoji na podu..Bacen novac na smaranja...Uzeo sam tf 7000 i ne planiram do sutra da trazim resenje jer izgubih sat vremena sa glupim Apple..:banghead:
Sto se tice opcije none za karticu,prije nego li napravis ID, ides kao da hoces da skines free app i onda tek pravis id. Cini mi se da se jedino tada prikazuje opcije None kod izbora nacina placanja.
Ja sam pre mesec dana radio update iOS-a i jailbreak na sestrinom 3GS-u, to je bio moj prvi ozbiljniji kontakt sa tim sistemom, registrovao sam se posle toga na app store bez kreditne kartice i instalirao joj par aplikacija bez problema.
Neka neko ko se malo vise razume u ovo objasni coveku da li moze da zaobidje ovaj korak, da se ne muci.
Inace, uvek postoji opcija da ga prodas, kupis Nexus 7 i za razliku u ceni uplatis vikend za tebe i suprugu u nekoj evropskoj metropoli :)
Upravo tako, znaci da bi se aktivirao nalog bez kreditne karice, prvo odes na itunes odaberes free app, i onda kada ti trazi aktivaciju naloga pojavice se "none" opcija!
hvala što si mi pojasnio čemu služi BT na apple.. ;) Ja jadnik, hteo da prebacim neke slike sa telefona i sl.. ;)
Inače, torrent treba mojoj supruzi...Ja ga imam na androidu i skidam app za njega samo tako..Za očas posla skinem i isntaliram...
Inače, pokušavao sam da registrujem app store i nije uspevalo dok nisam uradio update na ios 6..tada sam krenuo ponovo i gle čuda..pojavio se "none" kao opcija za kreditne kartice.. :wall: Kada sam imao ipad 2 to me nije zezalo a na ovom čudu mi sinoć pojede 2 sata maltretiranja... Nema veze..Instalirao sam joj željeni Skype i FB....Za ostalo neka se snađe--- Hvala na sugestijama i pomoći... Predajem muku supruzi ja odoh na tf700, koji od kako je stigao ipad3, još više cenim.
Inače, kupio sam joj i neku futrolu, koja je jako tanka i lepa...Možda se nekome svidi..Ima na kupujem prodajem sajtu...
(Powered by frubar.net)
@dark side brate ti ga pretera. Ti si se zezao dan sa none, ja 3 dana, nisma znao ni ko pije ni ko placa. Aplikacija za taj iPad u pogledu produktivnosti ima jako dobrih, to sto bluetooth zeza ***, ja to licno nisam koristio barem godinu do dve - nemam potrebu. Ko danas skida torrent putem tableta, ja licno to ne bih nikada uradio, jer mi je PC ukljucen u toku dana, ali licno bih voleo da imam izbor, ako ti treba treba, ako ti ne treba ne treba ti, mozda ti nekad zatreba. Google nudi taj izbor, Apple ga ne nudi out of the box, dobije se vecina (ne sve) kroz JB.
Za potrebe tableta iPad trenutno super vrsi funkciju, pdf-ovi izgledaju savrseno (najbitnija stavka za mene) kao i browsing, output na slusalicama je perfektan, postoji brdo aplikacija od kojih 99% nije potrebno ali dobro. Android tableti su po meni ipak u low end segmentu (Nexus 7), u top segmentu licno mislim da nemaju sta da traze pored Surface-a koji samo sto nije ;), jednostavno Win 8 >>> iOS > Android u tablet pogledu ako se posmatra celina, od app-ova preko uredjaja, pricing-a i na kraju produktivnosti.
Ja sam covek koji je sa androida na kratko presao na ios i smucio mi se...Ja bar mogu da vidim razliku jer imam oba tableta...mnogO je upotrebniji android i ios mi je ogranicen..KomPjuter nije pored mene cesto jer sam na terenu vise nego doma..Zato me manite sa tim predlozima zasto ne koristim nesto na kompu..Ne koristim na kompu jer to imam na androidu..Tako da sve je receno...
To o cemu DARK SIDE prica, ima svoje ime i zove se navika. Meni je npr. koriscenje Android tableta posle iPad-a bilo uzasno iskustvo.
@dark side brate ti ga pretera. Ti si se zezao dan sa none, ja 3 dana, nisma znao ni ko pije ni ko placa. \jednostavno Win 8 >>> iOS > Android u tablet pogledu ako se posmatra celina, od app-ova preko uredjaja, pricing-a i na kraju produktivnosti.
Izvinjavam se zbog offtopica ali pocinje malo da mi ide na zivce ovo tvoje uporno ponavljanje kako Win8 donosi nesto novo u svet tableta. Jos malo pa ces ko kovacm da se ponavljas.
Da pocnemo:
- win 8 tableti ce dolaziti u dve verzije, arm i x86
- arm ce biti koliko toliko pristupacni (u rangu ios/android pandana), od cene x86 ce usi otpadati kao i do sada
- arm tableti ce voziti iskljucivo metro aplikacije
- dosadasnje metro aplikacije su mnogo losije od najboljih android/ios tablicnih aplikacija
- metro kao okruzenje je potpuni promasaj ako mene pitas
+ office ce verovatno biti dobro uradjen, sto jeste veliki plus ali ako uzmemo u obzir da je tablet koristan za pregled i lagani edit dokumenata, ta prednost ms tablet office-a se gubi donekle. Surface RT dolazi sa tastaturom doduse ali ce ona biti znatno losijeg kvaliteta nego ona na transformeru, na primer, a ni to nije najsrecnije resenje za ozbiljan office rad.
Da pocnemo:
ARM ce nuditi vecu produktivnost - Office i jos ako na to dodas keyboard cover dobijas dobitnu kombinaciju, koja je najmobilnija do sada :). X86 gadja ultrabook, ali tu ces moci sve da radis, ako treba neko ozbiljnije kucanje vadi se dock, TF Infinity tesko da moze da se takmici sa ovakvim resenjem, sta nudi Android od ozbiljnijeg software-a?
Sto se tice aplikacija, to ne znam, ali ne sumnjam da ce zaostajati za kvalitetom ako se Surface "primi", uostalom one najbitnije aplikacije skoro uvek imas, WP 7 je presisao 100 000 app-ova.
Metro okruzenje je barem po meni najbolje nesto sto sam do sada video, dinamike koliko hoces, touch friendly, neke opcije koje nemas out of the box ni na Android-u (doduse ima na Note 2) ni na iOS-u - screen split, povezanost sa win-om i verovatno teznja vecih softverskih kompanija da izbace neko light resenje za te tablete.
U pocetku ce se videti problemi nedostatka i kvaliteta aplikacija, ali da bi to MS ublazio sasvim logicno je resio da izadje sa agresivnim pricing-om Surface RT-a :), ali ono sto vecina koristi ce sigurno biti dostupno since day 1.
Odmah me smorilo što nisam mogao screenshot( na jedan taster na androidu se odradi screenshot) da vam uradim u čemu je problem jer tupavi IOS nema screenshot (ili grešim?).
Nije to stvar navike...Imao sam ja ipad2 ali me smorio i prodao sam ga..Nije user friendly u meri koja meni treba..ograničen..i to je to..Namestio sam joj ovaj ipad3.. Grafika je do bola dobra i to je sve...
Screenshot - klik na home+lock taster. Razumem ja tebe, postujem svacije misljenje, ali moras shvatiti da za ogromnu vecinu osnovna svrha tablet uredjaja nije skidanje torrent-a i file sharing.
***. Ja ga izmedju ostalog koristim i za to.Inace ne radi screenshot..
Na iOS imas installous (koji ne postoji na androidu) i tu imas (narodne) programe i igrice lepo organizovano sve po kategorijama kao na appstore, skida sa raznih sajtova i sa torrenta, ali najbitnija stvar je sto ti je sve na jednom mestu, pa ne moras da juris po raznim forumima.
I vecina programa na iPad su napravljena za tablet a ne za telefon i to je jos jedna bitna prednost (poredi recimo Facebook, Skype...).
A screeshot na iOS postoji bas odavno i radi najnormalnije, probaj ponovo :)
I vecina programa na iPad su napravljena za tablet a ne za telefon i to je jos jedna bitna prednost.
Radi..on/off taster i centralni back taster..Dao sam supruzi da krene da se uci...ja sam na infinity tabletu..thx for the tip :)
Pa to ti je rekao @webster samo sto ti drugacije nazivas te tastere.
Back je Home i takvu funkciju ima.
