Targo Telekom
To je vrlo loše. Jedno je da ne kreću sa uslugom u celom kraju, a sasvim drugo da ti četiri dana stoje razvučeni kablovi po kući. Krajnje neozbiljno i neprofesionalno.
Ne verujem da se radi o kablovima u kuci. Pre ce biti da covek misli da su mu ispred stana kablovi (vertikala), ali da njega nisu jos prikljucili.
Pojavio se Targo Telekom server na Speedtestu
Da, ip 130.180.224.194 koriste za speedtest.net, nalazi u Srbiji, peering sa sbb-om i telekomom
Ping malo bolji nego 28.07 (http://forum.benchmark.rs/showthread.php?278799-Targo-Telekom&p=2964042&viewfull=1#post2964042)
Hetzner - Nemacka :
Ping Hetzner-SBB
[root@CentOS-57-64-minimal ~]# ping www.sbb.rs
PING www.sbb.rs (82.117.194.4) 56(84) bytes of data.
64 bytes from www.sbb.rs (82.117.194.4): icmp_seq=1 ttl=56 time=33.8 ms
64 bytes from www.sbb.rs (82.117.194.4): icmp_seq=2 ttl=56 time=34.6 ms
64 bytes from www.sbb.rs (82.117.194.4): icmp_seq=3 ttl=56 time=34.2 ms
Ping Hetzner-Telekom:
[root@CentOS-57-64-minimal ~]# ping 212.200.240.1
PING 212.200.240.1 (212.200.240.1) 56(84) bytes of data.
64 bytes from 212.200.240.1: icmp_seq=1 ttl=248 time=30.4 ms
64 bytes from 212.200.240.1: icmp_seq=2 ttl=248 time=30.5 ms
64 bytes from 212.200.240.1: icmp_seq=3 ttl=248 time=30.5 ms
Ping Hetzner - TARGO :
[root@CentOS-57-64-minimal ftp]# ping 130.180.224.194
PING 130.180.224.194 (130.180.224.194) 56(84) bytes of data.
64 bytes from 130.180.224.194: icmp_seq=1 ttl=52 time=37.2 ms
64 bytes from 130.180.224.194: icmp_seq=2 ttl=52 time=37.3 ms
64 bytes from 130.180.224.194: icmp_seq=3 ttl=52 time=37.3 ms
WESERVIT - NETHERLANDS
Ping WESERVIT - SBB
[root@dedi-srv105 ~]# ping www.sbb.rs
64 bytes from www.sbb.rs (82.117.194.4): icmp_seq=1 ttl=57 time=37.9 ms
64 bytes from www.sbb.rs (82.117.194.4): icmp_seq=2 ttl=57 time=37.6 ms
64 bytes from www.sbb.rs (82.117.194.4): icmp_seq=3 ttl=57 time=37.6 ms
Ping WESERVIT - Telekom
[root@dedi-srv105 ~]# ping 212.200.240.1
64 bytes from 212.200.240.1: icmp_seq=1 ttl=245 time=35.9 ms
64 bytes from 212.200.240.1: icmp_seq=2 ttl=245 time=35.9 ms
64 bytes from 212.200.240.1: icmp_seq=3 ttl=245 time=36.0 ms
Ping WESERVIT - TARGO
[root@dedi-srv105 httpd]# ping 130.180.224.194
64 bytes from 130.180.224.194: icmp_seq=1 ttl=49 time=67.7 ms
64 bytes from 130.180.224.194: icmp_seq=2 ttl=49 time=67.7 ms
64 bytes from 130.180.224.194: icmp_seq=3 ttl=49 time=67.7 ms
OVH - FRANCUSKA
Ping OVH - SBB
Pinging www.sbb.rs [82.117.194.4] with 32 bytes of data:
Reply from 82.117.194.4: bytes=32 time=41ms TTL=57
Ping OVH - Telekom
Pinging 212.200.240.1 with 32 bytes of data:
Reply from 212.200.240.1: bytes=32 time=35ms TTL=248
Pinging 130.180.224.194 with 32 bytes of data:
Reply from 130.180.224.194: bytes=32 time=48ms TTL=51
Reply from 130.180.224.194: bytes=32 time=51ms TTL=51
CEUSERVERS - CESKA REPUBLIKA
Ping CEU - SBB
Reply from 82.117.194.4: bytes=32 time=28ms TTL=53
Ping CEU - Telekom
Reply from 212.200.240.1: bytes=32 time=28ms TTL=249
Ping CEU - TARGO
Reply from 130.180.224.194: bytes=32 time=44ms TTL=52
Posto zivim u kuci...Razvukli su mi kabal do potkrovlja i tako stoji....
Aha, OK, onda si ekvivalnet nama u zgradi kojima je urađena vertikala. ali nisu došli do stana.
Mada opet nije profesionalno ponašanje uopšte. A ja ne otkazujem ništa dok ne vidim kako rade, tek posle, ionako tome služi probni period.
@miro: Da ping je sada bolji, ali ima tu još mesta napretku.
Ma ja sam potpisao ugovor pre 20 dana a rekli mi od 5-7 dana sve gotovo :)
Tacno tako, za razliku od nas u zgradama, kuća je samo tvoja pa nemaš skupštinu stanara i slično.
hahahaha ... pa tako su kod mene (blok 21), jos u februaru razvukli kablove po vertikali i rekli, za jedno mesec dana najkasnije pustamo signal :d... a evo tacno godinu dana, kako su kopali, razvukli i postavlili kablove po bloku ...ovakvim tempom i ovako "dobrim marketingom", verujem da ce tamo negde oko nove godine, da izbace zvanicnu ponudu na site-u
Pa to sam i mislio, realno bi im veći bio cim da skidaju kablove s kuće nego da završe instalaciju + gube pare ako izgube korisnika.
Kad su već oni bezobrazni, budi i ti.
Odeš u poslovnicu i kažeš ili završavajte ili skidajte mi kablove s kuće i raskidamo ugovor :)
*** njemu je situacija da bira adsl ili TT, drugo nema...tako da mu se vise isplati cekati targo nego uzimati adsl.
Inace za ping je i direktor rekao da mora da bude ispod 20 ms, da vidimo da li ce popraviti.
Nisu jos, ali video sam ih blizu moje ulice da idu od kuce do kuce da se dogovore sa ljudima. A sa kopanjem nisu nastavili, moju ulicu nisu do kraja isli, i jos stoje ove okolne ulice sto su pistavljene cevi pre jedno 2 nedelje.
Mog druga su prikacili on je prezadovoljan pogotovo sa TV...
Eto jos jedne potvrde, da nebuda ja bio kod njih pa ih zato hvalim.
***, ne znam zbog cega su to uradili.Meni su bas rekli da nece nista potpisivati samnom dok ne bude sve spremno za prikljucak.
Je li to tokom nekog promotivnog perioda ili tokom celog ugovora? Ako je ovo drugo, svakako prelazim sa mučenog KDS-a, ionako mi samo za neki sport služi kablovska.
Evo prvih ozbiljnijih stvari gde pokazuju kakvi su...Ovo mi se sada vec ne svidja...Veceras su bili kod druga i prikljucili ga....Kada smo sklapali ugovore receno nam je da imamo pravo na 4 TV i 3 kopma...Drugu veceras prikacili jedan tv i jedan komp i kao to je to...Rekli su mu da nije tacno da moze toliko....Eh sada ko je tu upravu :S
Ne razumem, oni ti daju internet koji dobiješ preko ONT-a i signal kablovske - coax kabl na račvu pa na sve TV-e u kući, a kompjutere ili na switch na ontu, ili staviš drugi switch pa do svih računara.
Ko može da te ograniči na jedan računar - to mi nije baš jasno? Bilo koji internet da ti dođe u kuću, nevezano za Targo, na link nakačiš svoj ruter, pa imaš uređaja koliko hoćeš. Koga bre to oni tamo zapošljavaju da radi instalaciju?
Jedino ako su radili instalaciju (kablove) do jednog TV-a i 1 PC-a, a da ostalo možeš da platiš ili sam da radiš.
Ma verovatno moze sve to na vise samo sto oni nece nista da urade...Prikace po jedan a ti se posle snalazi i kupuj kablove i razvlaci...Verovatno je ta prica...Nisam siguran drugar mi je objasnjavao preko fona
Da li se negde pominje koji su im delovi Beograda sledeći u planu?
Bilo bi lepo da dođu u moj komšiluk :) (Banovo Brdo)
A zašto ih nema u Novom Sadu? ;)
Ni jedan distributer bilo da se radi o vodi, kanalizaciji, struji, gasu, telefonu ili internetu, ne radi unutrašnje instalacije, već dovedu priključak do kuće ili stana pa posle vlasnik o svom trošku radi unutrašnju instalaciju. Zamisli slučaj hoće čovek da uvede struju i kaže: vidi ove postavili neki orman u hodnik i otišli a da mi spoje bojler, frižider, tv ništa pa kako oni misle da to radi ako ne spoje..... Znači poenta dovedu ti optički kabl do rutera i ti si time dobio internet, posle ti sa njega možeš da spojiš koliko hoćeš kompjutera. Očigledno je lik mislio da mu targo uradi celu kućnu mrežu za džabe. Kad čujem takve ljude dođe mi da pomislim da su u pravu distributeri gasa, prvo moraš da vijaš papire mesec dana pa da platiš soma evra priključak pa da ih vijaš da dođu da ti samo dovedu gas do kuće a posle se slikaj da će oni da rade unutrašnju instalaciju osim ako opet ne pukneš soma evra. A ovo čim je džabe odmah bi ljudi sve. Lepo piše na Targovom sajtu da rade samo do 3 metra u kući i samo do rutera. Ne znam šta je lik očekivao. Verovatno je pitao jel može 4 tv-a i tri kompa. Pa naravno da može, možeš da nakačiš 150 ako hoćeš ali kablove po kući ćeš sam da razvlačiš.
