Code:
xbmc@htpc:/etc$ bdremoteng
bdremoteng - Sony BD Remote helper daemon version 0.5
Usage:
bdremoteng [options]
Options:
-p <port> Set port number for incoming LIRCD connections.
-t <timeout> Set disconnect timeout for BD remote (in seconds).
The only thing I can think of, change the value of -t. (step 6) To be disconnected before the BD.
I took more than two years with the same batteries and no problem.
...pitam se samo, koliko mogu da smetaju jedan drugom ako su u istoj masini?
Ne razumem ko kome da smeta?
Konfuziju unosi koriscenje izraza NAS(otuda i nepotrebni raid), a koliko ja razumem trazi se htpc u kucistu koje prima vise od jednog diska i to je sve.
Well if your HTPC has videos on it and you're streaming them to other devices, then your HTPC kinda becomes a server. I like to keep them separate because they're designed for different things and thus have different hardware configurations and priorities:
File Server
- Use as little power as possible
- 24/7 use
- Cheap as possible
- Lots of SATA ports for loads of storage space
- Good cooling since it's in a cupboard and not tended to often
- Linux or Windows Server for stability
HTPC
- As quiet as possible
- Higher-end components
- Separate GPU for custom refresh rates and high quality hardware deinterlacing.
- 1 SATA port for OS SSD for fast wake/sleep/application launching/etc.
- 1 SATA port for a timeshifting/recording HDD
- BD-RE drive
- Should look nice
- Windows 7 for application support and DXVA2
I think you have to make more compromises if you combine the two, although it is certainly possible.
At some point in the future I plan to move my tuner card(s) to my server also and run MediaPortal TV-Server on it, then have several HTPC clients connecting to it. That way there'd be a central repository for timeshifts and recordings and multiple machines capable of watching TV without each one having a tuner card. They would all only require a 40 GB SSD with no HDD required.
	...jer nas ima posebnu funkcionalnost, zato se i pitam da li je moguce to ostvariti u istom kucistu. Ne prodaju se NAS resenja posebno samo iz mode, pretpostavljam da je vise zbog funkcionalnosti. ...
Nasao sam ovo za tvoj daljinski (neki lik se zalio da mu curi baterija)
Moraš da rešiš sa samim sobom šta je to što ti hoćeš od NAS-a. Ako je to samo, kao što si rekao "nesto za fotografije i za muziku" onda je to ovo što ja imam. HTPC mašina koja ima jedan šerovan folder i gde je podešen automatski download sa torrenta uz pomoć RSS feed-a.
@garson
Je l' to celo napajanje ili ima eksterni deo tzv. ciglu? Koja marka i koliko keša? Je l' kod nas kupljeno?
Ja sam se razmisljao da uzmem jednu za moj htpc,ali sam na kraju ipak odlucio da uzmem Logitech K400 tastaturu.Od tih Rii "tastatura" me je jedino odbilo to sto povremeno i surfujem sa tog htpc-a,a Rii je isuvise neprakticna za kuckanje.Jel neko probao ove Riitek tastature koje su se pojavile kod nas mislim da bi "legle" na HTPC konfiguraciju...
