arcibalde
- Test subject -
Za pocetak oficijalni sajt: http://fractalsoftworks.com/
What will you discover in the ongoing development of the world of Starfarer?
Single player, gritty, dystopian sci-fi setting
Classic top down gameplay style enhanced by modern technology
A procedurally generated sector of the galaxy, seeded with well-known core worlds and factions
Develop your character into a hot-shot pilot, a cagey admiral, an industrial magnate – or anything in between
Outfit ships with your weapons of choice and add hull modifications to create crushing tactical combinations
Explore hundreds of star systems to find habitable worlds, rich resource deposits, and lost technology
Assemble a large, powerful fleet or a finely-tuned task force with hand-picked officers and crew
Cripple core world supply lines to cause chaos and create easy prey for piracy or bolster the rule of law and try to reverse the sector’s descent into anarchy
Impact the fate of the sector with your decisions and leave a permanent mark in the world
Za one koje mrzi da citaju to mu dodje ko nekakav hibrid Space Rangers-a sa mnogo dubljom i kompleksnijom mehanikom, odnosno to mu dodje kao X3 sveden na jednostavni gameplay i interfejs. OK, ok, SADA NIJE kao x3 ali po onome sto pise bice.
Znaci ako zelite da istrazujete svemir brodom (ne fajterom vec pravim pravcatim brodom a kasnije i nekim debelim kapitalcem) da maltretirate il branite one slabije il ubedjenije da zavodite red il strah i trepet da idete solo ili sa omanjom flotom da ih opremite oruzjem boljim il losijim i ostalim dzidzabizdama izbor je vas. Ako zelite ovako nesto onda je ovo igra za vas.
VAZNA NAPOMENA! Igra je u alpha fazi ali za razliku od nekih drugih igara (jel neko vrisnuo SotS 2 :zgran🙂 potpuno je igriva ALI samo pojedinacne misije, kampanja jos uvek nije implementirana. Na pocetku misije dobijate vec namestene brodove i nista na njima ne mozete da menjate ni oruzje ni opremu. Ovo ce se promeniti naravno ali je trenutno tako. Igra moze da se moduje i vec postoje neki modovi za nju koji su naravno u vidu misija.
Sto se osecaja dok igrate tice on je jednostavno (moje skromno misljenje) fenomenalan. Iako imate pored broda kojim komandujete i druge brodove vecinu vremena ne vodite racuna o njima. Sistem komandovanja tim brodovima osmisljen je tako da se u osnovi oslanja na AI koji se u pojedinim trenutcima mora korigovati ali ne predstavlja nista obavezujuce. Jednostavno zadate im pocetne komande i pustite ih da ih izvrsavaju onda u zavisnosti od toga kako se situacija odvija izdate nove komande. U prvoj misiji izdao sam ukupno tri komande. Dve na pocetku, da se zauzmu dva objekta, i jednu pri kraju da traze i uniste neprijatelja.
Trenutna verzija je 0.35a a sledeca je 0.5 i u njoj ce da bude implementiran jedan zvezdani sistem u kome ce igrac moci da se bori, prodaje zarobljene brodove, leveluje kapetane, oprema brodove, trguje itd.
Kada izadje igra ce kostati ~20$ a ako je sada pre orderujete kosta 8,30e.
Eh, i za kraj video Cinicnog Britanca. Uzivajte
