Nvidias kepler(gf6xx) comes in to focus.
Ala se vi zamlacujete sa tim specifikacijama iako znate da je 28nm i dalje problematican i da ce svaki nizi proizvodni proces u buducnosti biti sve tezi i tezi za savladavanje...
Nece biti nikakvih 512bit-a, barem ne u pocetnoj godini 28nm proizvoda...
Bice sigurno prilicno povecanje CUDA jezgara i sredjivanje istih i naravno popravljanje mem kontrolera da gura brzine kao kod AMD kartica.
ja bih samo rekao nesto sto sam primetio... 2x9600gt=260gtx 2x260gtx=460gtx 2x560gtx=660gtx? :p sto mu i dodje na neku logiku 580gtx=660gtx...
Mada iskreno sad kad pogledam svoj post pre bih rekao da tu nesto ne valja :p jer se secam da sam ja sa 2x285gtx imao priblizne performanse 470gtx :p Al bilo kako bilo, mozda sam se i nalupetao...
2x gtx260 su znacajno brze od gtx460, vise su u rangu gtx560 "vanila" koji jeste da nije razlicit od gtx460, ali je takt GPU 20% visi.
The roadmap starts with the GK107 GPU, a budget/mainstream GPU that Nvidia places between GTX 520 and the GTX 550Ti. The GK107 features 128-bit memory interface paired up with GDDR5 memory and has PCI-Express 2.0 interface support. This one is scheduled to launch sometime in Q2 2012. Shortly after the GK107 comes the mid-range/performance GK106 GPU that should replace the Geforce GTX 560 non-Ti version. This one packs a 256-bit memory interface paried up with GDDR5 memory and supports PCI-Express 3.0 interface.
The second half of 2012 will bring the GK104 GPU, a GPU that will feature 384-bit memory interface paired up with GDDR5 memory (most likely 1.5GB). This one should replace the GTX 570 and will be a part of dual-GPU solution that will be known as the GK110. The GK110 GPU will feature two GK104 GPUs. Surprisingly, the GK104 and dual-GPU GK110 will be the last GPUs in 2012, as Nvidia plans the flagship GK112 for late 2012, most probably 2013. The GK112 will feature a 512-bit memory interface.
All new GK GPUs are based on 28nm manufacturing process and, all except GK107, feature support for PCI-Express 3.0 interface. The roadmap is pretty much in line with what we heard before, including that Nvidia will be a bit late with GPUs this year. According to this roadmap, it looks even worse than we expected. We expect Nvidia to be ready with the mainstream part in time for Cebit, while it looks like the performance GPU will be ready for Computex in June 2012.
Unfortunately for Nvidia, AMD's Southern Islands GPUs are going to start to roll out in early 2012. According to what we know so far, high-end Tahiti GPU comes first, while Barts replacement, Pitcairn, should be ready by the end of February and most probably launched sometimes during Cebit in March.
    139.7 KB · Pregleda: 79
Znaci nije rebrand i bice 28nm i PCBeast je lepo rekao da ce prvo izbacivati slabije modele i ici polako, krajem godine ka GTX680, interesantno.
GTX260 SLI je identican kao fabricki klokovana GTX460 i to igrama gde SLI dobro skejluje. Licno testirao/imao tu sli kombinaciju :) Ali ono sto mene interesuje, najvise je, koliko ce recimo GK110 (2x GK104) biti bolji od ove moje i da li ce se opet isplatiti ici na SLI.
Zestoko, ali zestoko kasnjenje. Flagship cak za 2013 i to prema oficijelnom, sto ce reci, optimisticnom roadmap-u.
Ako ista izvuce AMD iz blata, to ce biti-nVidia sa svojim tajmingom.
Ne znam odakle da krenem sa nerealnim stvarima na ovom 'roadmapu' ;)
Lepo je rekao kao da je znao.
Ovo jednostavno ne moze da bude tacno. 2x260 SLI je za nijansu sporija od 295, koja je od 6850/5850/gtx 460 brza u proseku 30%.
Edit: pade mi na pamet da si mozda poredio maksimalno klokovanu 460 (tipa sa 675mhz na 900-950mhz GPU) sa 2x260 na defaultu. Onda jeste tu negde
Ne znam ja sta si ti probao...kod mene gtx 295 (u sustini GTX275 sli) radi kao GTX 560ti...pa i bolje, ali ajde necu da "nabijam" komplekse ovima sto imaju gtx 560ti. Zmaj NS ovde sa foruma je imao 2 kom gtx295, pa posle 1 kom (drugu je prodao)...sada ima gtx 560Ti MSI Twin Frozr II i kaze da je vidno sporija karta od jedne gtx295, a posebno u 2560x1600. Cisto sumnjam da jedan GTX 460 ima ista da trazi protiv 2x gtx260, no dobro...svako ima svoje misljenje.
Nove spekulacije:
http://vr-zone.com/articles/nvidia-kepler-on-track-28nm-samples-in-house/14221.html
Cak i specifikacije za GK104:
http://vr-zone.com/articles/rumour-nvidia-gk104-specifications-release-in-q1-2012/14222.html
GK104 is reported features between 640 and 768 SP, 80-96 TMU and either 256-bit or 384-bit memory interface. The performance is likely to be a bit faster than GeForce GTX 580.
I jos po nesto:
http://translate.google.com/transla...f=1&u=http://www.3dcenter.org/news/2011-12-13
Nije mi jasan nVidijin pristup sa jos jednim OGROMNIM cipom... 1024 shadera:zgran: pa iako je nizi proizvodni proces, samo dupliranje svega nece smanjiti povrsinu cipa... A najzanimljivije je da idu na 512bit magistralu za DDR5 memoriju a poznato je da im mem kontroler na Fermi generaciji i nakon peglanja nije bio dobar kao sto je bio kod AMD kartica...
Na seriji 5xx im je bio dobar mem. kontroler, samo je serija 4xx imala problema
Nisam rekao da je bio los, vec da nije bio dobar kao kod AMDa.. A ako idu na 512bitnu magistralu mozda ni sad nece biti, pa izvlace protok sa sirom magistralom.
Pa dobro, jeste bolji na Atiju. Prvi su presli na ddr5, i zato su imali prednost jer je nV u seriji 4xx prvi put implementirala ddr5. Sad i nema neke vece razlike, a da je vredna pomena.
Verovatno fake ( Metro Last Night? ), al ajd' da ostane ubelezeno ...
Izvor: http://we.pcinlife.com/thread-1802355-1-1.html
Cim je na tabeli GTX780 sve je jasno :D :D
E onda mozda i ne bude fake kroz dve generacije. :D
Pa nigde ni nemamo zvanicno kako ce se ta kartica zvati (a recimo posle GTX280 je dosao GTX480). Znamo samo nazive chipova...kartice mozda budu i GTX10005643...
Ako su vec imenovali mobilnu seriju cipova sa GT6xx onda ce i desktop dobiti taj epitet.
Moze biti -a i ne mora.
Ako je 6xx mobilna serija zasnovana na Fermi arhitekturi ali u novom proizvodnom procesu, na primer. A kartice sa kepler arhitekturom koje ce izaci dosta kasnije, cisto sumnjam da ce zadrzati isti prefiks.
Realno opet kasne... GTX590 ili GTX570 SLi nisu bash udobni ako zelish da se igrash u 2560x1600 (za druge rezolucije ti i ne trebaju takve kombinacije). Hteo sam da sachekam kepler, medjutim josh nishta od njega, tako da sam uzeo josh jednu GTX570 dok se ne pojavi single chip zamena.
