Battlefield 3
AMD Catalyst 11.10
http://support.amd.com/us/Pages/AMDCatalyst1110Previewdriver.aspx
· Improves performance in Battlefield 3 Open Beta release for both non-Anti-Aliasing, and application enabled Anti-Aliasing cases on the AMD Radeon™ HD 6000 and AMD Radeon™ HD 5000 Series for single GPU configurations
Improves performance in Battlefield 3 Open Beta release for both non-Anti-Aliasing, and application enabled Anti-Aliasing cases on CrossFire configurations using the AMD Radeon™ HD 6000 and AMD Radeon™ HD 5000 Series
Enables support for Eyefinity 5x1 display (portrait and landscape) configurations using the AMD Radeon™ HD 6000 and AMD Radeon™ HD 5000 Series
· Vision Engine Control Center: User Interface enhancements have been implemented for the CrossfireX, GPU Overdrive, and Information Center pages.
Neće da se instaliraju -.-
Ja nestrpljivo čekam svoj ključ 😀
nešto zanimljivo
I would like to inform you that the beta is sent on random basis to the qualifying cu for playing the Early access to beta and if you qualify the criteria and have not received a mail regarding early access to beta then please do not panic as you should receive the email for it soon, for any further information you can also watch http://www.battlefield.com/battlefield3 for more details as they become available.
ZAsto nece da mi prihvati registraciju tj login na Origin-u? Jel treba da dobijem neki confirm. mail na moj mail ili sta?
Jedno pitanje 😀
Posto izlazi beta sada, koji je minimum fps koji bi treba da mi bude da igra radi tecno, bez seckanja i to, da bi uskladio sa podesavanjima 😀
1920x1080 🙂
Jedno pitanje 😀
1920x1080 🙂
To je individualno. Nekome odgovara i 30 fps, a neki ispod 60 ne priznaju. Naravno zavisi i od same igre. Recimo Crysis 1 je bio sasvim igriv sa 35-45FPS. Tu je dosta pomogao motion blur pa igra deluje tecnije. BF3 mislim da ce biti ok sa 40 fps pa nadalje, uz povremene padove kad bude mnogo eksplozija, dima itd...
EDIT: Jedva cekam neki cross platform fps:
[YOUTUBE]oR1z9ds1S8s[/YOUTUBE]
auh ala ovo naporno deluje 🙂
Neznam sta je u pitanju ali ovaj recoil ili sta vec...ili je ovaj igrac noob ili je toliko tesko igrati na ps3...
Imali ko problema sa Originom ? Meni pise da mi je Chat Disableda a ja to nigde nisam odabrao tacnije meni pise Online ispod imena a ispod toga Chat Disabled...gde da ga ukljucim ?
download ne krece...
krenuo 😀
xexex pa onaj radar se na alphi nije oktretao,samo je stajao u mestu :-devil-:
Hahaha, možda skinete do desetog oktobra? :d
Hm.... još uvek nisam dobio ključ....
Ne radi ni jedan ključ jer i da su poslati, nemoguće ih je aktivirati jer nisu u bazi, imam 2 ključa i stalno izbacuje da je invalid, ne da je used, ipak čekam svoj ključ, rekli su mi da treba danas popodne da se pošalje na mail.
Nema kljuceva. Treba ti samo Origin panel i to je to. Danas u 2, za nekih sat vremena, pocinje open beta za one koji su vec narucili igru. 29-tog imaju pristup svi.
Meni na Origin panelu nema Battlefild Open Beta panel,da li je i kod vas tako?
Ma kupio sam ja igru,da li nako moze da mi pokaze kako izgleda origin panel?
ovako:
Nije tako los torent, ide 600-650, vise ne. Ali zato RS daje maksimalnu brzinu!
