NVIDIA ForceWare - diskusija, pitanja, linkovi
Podizu brzinu fana zato sto se povecavaju klokovi karte. Nisi jedini kome se to desava. Vrati se na neku stariju verziju posto od ovih novih nema nekog napretka
Vratiostare drv i nema podizanja klokova ?!
Još uvek koristim drajvere iz familije 260 (rade bez greške) jer sam primetio sa novijim drajverima kod podizanja sistema da se zatrese znak win pre nego što nastavi sa podizanjem sistema tako da sam odustao od familije 275 i 280
GeForce 285.27 Beta Driver
Win7 64bit
New in Release 285.27
Performance
Increases performance for GeForce 400 and 500-series GPUs in several PC games vs. v280.26 WHQL drivers. The following are some examples of improvements measured on Windows 7. Results will vary depending on your GPU and system configuration:
GeForce GTX 580:
Up to 5% in Call of Duty: Black Ops
Up to 7% in Civilization V with SLI
Up to 5% in Crysis 2 DX11 with SLI
Up to 7% in F1 2010 with SLI
Up to 5% in Lost Planet 2 with SLI
Up to 5% in Mafia 2 with SLI
Up to 13% in Metro 2033 with SLI
Up to 8% in STALKER: Call of Pripyat with SLI
Up to 5% in StarCraft II (Check out the finals of the GeForce StarCraft II Pro/Am Tournament)
GeForce GTX 560:
Up to 4% in Bulletstorm
Up to 5% in Battlefield: Bad Company 2 with SLI
Up to 6% in Call of Duty: Black Ops
Up to 7% in Dragon Age 2 with SLI
Up to 5% in Just Cause 2 with SLI
Up to 4% in Mafia 2 with SLI
Up to 7% in Metro 2033 with SLI
Up to 11% in STALKER: Call of Pripyat with SLI
Up to 7% in StarCraft II
NVIDIA PhysX
Updates PhysX System Software to version 9.11.06.21.
HD Audio
Updates HD Audio driver to version 1.2.24.0.
OpenGL
Adds support for OpenGL 4.2 for GeForce 400 series and 500 series GPUs.
Pozitivni komentari na ove zadnje beta drivere.... nisam video neke znacajnije oprituzbe a vecina problema izgleda su reseni
jesu resili ona ubrzavanja ventilatora kada kartica ne radi nista pametno?
kako onda sa 280.26 menja brzinu venta kako joj padne na pamet, a sa 275.5 to ne radi 🙂
... izgleda 🙂 iritantno je 🙂
edit: installing, pa javljam da li je isto
jel jos nisi instal?
Meni isti djavo ko i prethodni. Opet dize klokove na bezvezno otvaranje neke internet stranice. U principu mi je nebitna stvar...
instalirao sam, ali otisao prvo u Deus Ex, pa u WoT 🙂
za sada lepo rade, nisam video da dize klokove (dok sam van igara)
Evo kod mene, isto najnoviji driveri, ne beta(280.26) Ovo je u toku normalnog surfovanja sa Firefox.
Pa ugasite hardversku akceleraciju u firefoxu u Options > Advanced, ionako nicemu ne sluzi.
Ja sam na Operi, al svejedno mi je ugasena hw akceleracija u flashu. U svakom slucaju mi je nebitno, valjda ce da srede u nekoj daljoj verziji drajvera.
Ne pricam o flash-u, nego Firefox ima posebno neku svoju akceleraciju, nevezano za flash, sa kojom i meni dize klokove i zauzima nekih 100MB GPU ram-a vise.
I sa ugasenom Hardware Akceleracijom drzi klokove na full kod surfovanja netom na Firefox.
Edit: Jel se isplati instalirati ove nove beta drivere?
ja ne vidim poboljsanje u preformansama 🙂 doduse ne gledam fps :d
ali vise ne drnda u fan bez potrebe
Pogledaj kako se ponasa kad ti je msn, skype, JDownloader upaljen, da li tada dize klokove i brzinu fana?
D2D HW akcelracija u firefox-u ili u drugim browserima uzrokuje ove stvari. Trenutno, ne znam koliko sajtova ima neke koristi od toga - vrlo malo. Par primera možete videti na Internet Explorer Test Drive. Ali definitvno je da je NV odlučila da promeni profil za fan u drajverima...
koritsim Operu nisam primetio nista (sto sam primetio kada sam stavio one poslednje whql), msn ne koristim (pidgin, non stop je aktivan nisam primetio nista), skype cu videti cim dodjem kuci, a jDownloader ne koristim vec dosta dugo.
Meni sa 280.26 kada imam Firefox otvoren, drzi klokove na low power 3D ja mislim (Core je 405mhz, Shader 810mhz i Memory 324mhz). Doduse fan je na 1400 RPM a temperatura graficke je 38c.
280.26 nije resio problem sa fan speed-om cuo ga jutros oko 4h 🙁
Ljudi instalirao sam ove zadnje beta drajvere 285:27 i dok blejim po netu drajver puca iz chista mira, prvo sam mislio da je do klokova pa sam onda vratio na default i opet drajver puca, shta se to deshava zna li neko?
mislim da ti, nazalost, ne gine reinstalacija operativnog sistema...makar bih ja to uradio
meni ne pravi nikakve probleme
onda ostavi stare, ionako nema neke razlike
