Microsoft Skype
Moguce da je ubacen IE engine za home stranicu, FB i add contacts (tako meni izgleda).
Sto ce reci da neka podesavanja za IE mogu da zeznu Skype :D
Ja nemam poslednji IE i radi mi sasvim ok 5.5.
Imam IE 9 ali isti ipak ne koristim i sve je u njemu na default.:p Reinstalacija IE nije pomogla.
E vidis tu moze biti problem :D Meni prva instalacija IE9 nije htela da radi za e-banking. Vratio na IE8, pa opet instalirao IE9 i sada radi.
Za to kratko vreme nisam dirao Skype->Add a contect, ali moze biti da je do toga.
Sta radi kod tebe kad probas da dodas?
Ja imam najnoviji Skype i radi mi sve, bez i najmanjih problema!
ovo sam nasao negde na net-u i kod mene radi (nema home foldera na startu):
1. First you have to uninstall Skype 5.5.0.xxx (if it is already installed).
2. Download and install Skype 5.3.0.120 from this link: http://download.skype.com/msi/SkypeSetup_5.3.0.120.msi
3. Quit Skype if running, wait for a few seconds.
4. Navigate to %AppData%\Skype in Explorer, for Windows 7 the path is C:\Users\your user name\AppData\Roaming\Skype, the AppData folder is hidden by default, you can make it display by checking show all files and folders in the menu bar, tools -> folder options.
5. Delete subfolders shared_dynco and shared_httpfe? completely.
6. Create new empty files shared_dynco and shared_httpfe?? here (no extension), yes, it is files not folders. I unload my empty files: noSkypeHome.zip, just put these files here.
7. Restart Skype, the Skype Home should disappear from now on.
YES! To, care!
Ja imam jedno pitanje :)
Da li je potrebno (neophodno?) da se povezu skype i fb da bi radio videocall na fb-uku?
A ja imam pitanje kako da povezem Skype i Facebook? :)
Otvoris Skype prozor, pritisnes Alt + 3 (ili otvoris Facebook tab na vrhu, pored Contacts) i "Connect to Facebook".
Aha, to je fora. :) Bas cu da probam kad dodjem kuci. Hvala na pomoci. :)
E fak :( Danas se opet reinkarnisao SKype home :(
Nije ih repopulisao i dalje su zero-sized, ali ocigledno ne radi :(
Negde sam imao Skype.exe dok je Skype jos bio single instalacija - treba ga naci :D
neznam, kod mene i dalje radi bez home foldera na startu......
Nema Home na startu ali ako ti stoji masina upaljena 24h pojavi se opet tokom rada :(
Nisam u Compact View ako je to bitno jer mi ne odgovara.
Nasao sam staru verziju 3.0 ali ona ne prepoznaje postojece kontakte :D
skini sa linka koji sam okacio ver. 4.2.0.187. radi, mislim da je to poslednja zvanicna bez home f.
^ jeste , provereno :d
Nesto sto mi nikako nije jasno da nisu uveli je: da nemam kao na MSN-u da se pre logovanja odlucim da li cu da budem online ili offline, zatim da kada posaljem offline korisniku poruku ona mu nece stici sve dok se on ne uloguje a onda moram i ja da budem logovan, znaci nije kao na MSN-u. Ove 2 stvari, malo jos neka sminka i bice mi odlicno.
Smrc... bez pitanja mi se 4.x updatovao na 5.x juce! Aman...
