vladimirdowla
ja mislim da imax jedino koristi kvalitetnije projektore nego dolby, koji imaju 480 ili čak i 600Hz osvežavanje i naravno 4k rezoluciju.
Što se NS-a tiče, pošto je P$ych0 iz Subotice, koliko vidim, možeš gledati samo u Areni, drugog nema ali to nije uopšte loše. Btw u prošli četvrtak su puštali u sali 3 (150 mesta) i bilo je odlično a sinoć(da bio sam drugi put, freak
) je bilo u velikoj - 5-ici. platno je neuporedivo veće ali ona mala sala mi nekako više leži. kontam da je ovo prvi film posle montevidea koji u svim terminima puni arenu do daske.
NO Spaceships Headed for Earth
Has the SETI Institute discovered three objects en route to our world? Alien spacecraft that will arrive in 2012?
If you believe a widespread story now being circulated on the internet, and published by the ironically named “Pravda” [http://english.pravda.ru/science/mysteries/22-12-2010/116314-giant_spaceships-0/], you might think so. But it’s all nonsense – it’s a rumor, a hoax, and a fabrication that uncritical web sites have reprinted without checking.
A few aspects of the story that are obviously suspect:
1.The objects, now described as a few hundred kilometers in size, and “beyond the orbit of Pluto”, were apparently discovered by SETI using the HAARP radio array. To begin with, the HAARP (High Frequency Active Auroral Research Program) instrument is located in Alaska. The position of the three “incoming” objects is given as -90 degrees declination – or the south celestial pole. Anyone versed in even elementary geometry can recognize that you can’t see this part of the sky from Alaska! In addition, and of clear import, neither the SETI Institute nor any other SETI project makes use of HAARP.
2.In the original version of this article http://www.examiner.com/ufo-in-canada/3-very-large-objects-space-flying-to-earth, purported SETI astrophysicist Craig Kasnov is quoted as saying that the three objects are in-bound. No one named Craig Kasnov has ever worked at the SETI Institute. There is a media and conservation professional by name of Craig Kasnoff, who – with David Gedye – came up with the idea of the SETI@home screen saver many years ago. But he has explicitly noted that he has nothing to do with this story, and in fact the article itself points out that it is referencing “Kasnov” not “Kasnoff.” So the story rests on the testimony of a fictional character.
3.If the SETI Institute had, indeed, found three clearly artificial objects headed for Earth (or just about anywhere else), that news would be found here on its web site. It would also be in the mainstream media. It’s not.
The putative arrival in 2012 of objects from another world is no more believable than the Mayan calendar claim that the world will end in that same year, internet stories notwithstanding!
Dr. Seth Shostak
Senior Astronomer, SETI Institute
Pa tako mi razmišljamo. Da smo mi vanzemaljci i da idemo da posetimo drugu planetu naravno da bi krajnji cilj bio pljačka i porobljavanje onih koji žive tu. Ne bi sigurno išli sa ciljem da širimo bratstvo i jedinstvo.
Drame su najmanje gledani filmovi u bioskopima kod nas.Sta cemo kad smo glup narod....
Imbecilne komedije, filmici za decu i domaci katastrofa filmovi se gledaju.
a i zar ne bi bilo malo smešno da prevale čitav taj put samo da nas pobiju
izem ti ja takve elijene, gde si poso bajsom kroz svemir, glupi vanzemaljcu!
Možda hoće da nam pomognu da prestanu ovi besmisleni ratovi, da pomognu da se nahrane ljudi u Africi, i konačno da se ljudi izvedu na pravi put, put ka utopijskom društvu.
A izem ti ja brzinometar kad lose racuna svetlosne godine.![]()
tacno sam izracuno. e cek - u stvari nisam. dodas jos jednu nulu na sve ovo. jer je svetlosna godina 10 triliona, a ne trilion kilometara.
broj sekundi u godini -
31556926
broj kilometara u jednoj sekundi svetlosne brzine - 299796
pomnozeno = ~1.000.000.000.000.0
dakle elijeni mora da su krenuli pre 113.000 godina![]()
