Serious Sam 3: BFE
Jovyland
VIP član
CPU & Cooler
Ryzen 5 5600
Matična ploča
MS B350M Mortar Arctic
RAM
16GB DDR4 HyperX 3200Mhz
GPU
XFX Qick RX 6700 XT
Storage
1 TB SSDa + 3TB HDDa
Zvuk
WiiM Amp Pro + Dali Kupid
PSU
Seasonic MII EVO 520W
Monitor
DELL G2724D
Laptop
HP Pavilion Aero 13
Mobilni telefon
Pixel 9a
Pametni uređaji
Meta Quest 3S
Steam
jovyland
Pristup internetu
  1. Optički internet
  2. Mobilni internet
Novi Sam stize 2010. 🙂
Serious Sam 3 should be done in 2010
Croteam has said that Serious Sam 3 will be finished sometime next year.
"Serious Sam 3 is happening for sure," CEO Roman Ribaric told Destructoid. "It is currently planned to be finished in 2010."
Only a few scraps of information have been released for Serious Sam 3 so far. Ribaric told Eurogamer in July that the game will drop the trademark cartoon visuals, although the hectic gameplay will return.
Croteam sprung into life this autumn with the PC release of Serious Sam HD: The First Encounter, which refit the original chaotic shooter with today's technology - primarily the Serious Engine 3.
The Xbox Live Arcade version will be released in January 2010, followed by Serious Sam HD: The Second Encounter sometime during the "early" part of the year.
Mislis jos tri? 😀
(poslednja recenica citata)
kec i dvojka su bili do jaja
Kad se setim koliko sam ganjao tu igricu..aaaaaaaaaaa
Ako se ne potrude podosta i ne izmene radikalno gameplay, teško da ovo više nekome mogu da prodaju.
mislim da imaju oni sasvim solidnu bazu fanova. ne brinem ja za njih.
kako sam ja cepao dvojku kad sam provalio da sam tu igricu dobio uz komp
Znači, da ni oni još nisu sasvim sigurni, obično kod izdavanja novih igara probiju predviđene rokove ...
digresija : sećam se da je bio oktobar 2001 godine, oko 3-4 sata popodne kupio sam disk prvog dela u jednoj od pančevačkih prodavnica gde su se tada prodavali diskovi i odmah sam otišao za Beograd kod mog rođaka da je instaliram jer tada nisam imao kompjuter. Posebno mi je ostao u uspomeni napad onih bezglavih kamikaza, na izlazu iz pećine pri početku igre i njihovi zastrašujući krici. Čudovišta su bila vrlo maštovito "dizajnirana" za to vreme i atmosfera u igri je bila dobra :type:
mnogo leta je prošlo od tada, a diskova odavno nema u prodavnicama...
meni je najinteresantnije bilo da trazim skrivene prostorije
na dvojci su cak bila i 2 skrivena nivoa
koja 2 skrivena nivoa?
Znam za onaj jedan u poslednjoj misiji gde se nalazi zadnji boss iz prvog dela u nekom frizideru
Ima, samo ne onih koji tebi trebaju. 😀
Ko da ih nema, kad mi nisu u "prajs rejndžu". Meni su jedino nelegalni dostupni, zato su mi sinonim za diskove :bottle:
Sećam se da je u igri bio i jedan *******i deo u nekom lavirintu gde su put pregrađivali stubovi koji su se dizali i podizali, naizmenično. Mala nespretnost i stub te spršti...
to su bila 2 cela nivoa, ako se secas one mape koja je bila na ekranu dok se ucitavao svaki nivo i tu su kao bile slicice nivoa koj si presao pa iscrtana linija do narednog nivoa na koji ides..e tako kada nadjes ulaz u secret level onda ti se na mapi iscrtaju i ta dva nivoa..
Bas sada googlam da nadjem slicicu da okacim ali ne uspevam...
"PC release of Serious Sam HD: The First Encounter, which refit the original chaotic shooter with today's technology - primarily the Serious Engine 3."
Ko hoce da igra prvi deo, neka uzme ovaj remake. Jel probao neko?
Ah Sima... 🙂 Presao sam ga davno u igraoni, jer tad nisam imao komp. Jedna od retkih igara koja je uspela da bude interesantna samo na principu Kill Em All, i sto ih je vise to bolje... Nepresusne horde neprijatelja, neprestano pucanje... Ne znam da li bi i jedna tako mindless igra prosla danas... Leros smo bili povezali kompove i igrali Simu u multiplayeru... 😀 Scena - ulazimo u piramidu, pucamo u sve zivo, krenemo nekim uskim hodnikom - samo odjednom padne ogromna kugla ispred nas i pocinje da ide ka nama, a ja panicno pocinjem da vise - Nazad, nazas, bezi nazad! Svi pocinjemo da bezimo dok nas kugla juri... Taj osecaj je do jaja... Kao da sam u nekom filmu 😛 Gunisi npr... 😀
ipak je to kultna igrica i ne baš tako mindless,
pre će biti da su protivnici u igri mindless 🙂
svakako radujem se nastavku,
fali i malo ozbiljno opuštene zabave :type:
sad mi pade na pamet el igrao neko armed and dangerous
opšta ludorija od igre sa beskrajno smešnim likovima
i atmosferom
Posmatrao sam sa strane kako neki klinci rokaju one kreature (nova verzija). Mogu reci da mi izgleda kao nasminkana ali jeftina kopija prvog dela. Ili im je bila slaba konfiguracija. Drugi deo mi se, prema secanju, mnogo vise dopadao.
Pa to i jeste prvi deo samo sa boljom grafikom i ragdol fizikom. Isti takav ce da bude i drugi encounter. Steta je samo sto da bi igrao u lanu coop moras da imas steam nalog.
Pa ne, to je Serious Sam HD: The First Encounter i Serious Sam HD: The Second Encounter. Treci deo tek treba da se pojavi mozda ove, mozda iduce godine.
Igra stize na leto, a prvi shotovi izgledaju odlicno!
http://www.rockpapershotgun.com/2011/02/28/serious-sam-3-announced/
TIME AND PLACE ARE SUBJECTIVE – BOOM! That was the sound of Serious Sam 3: BFE news dropping. Croteam’s Serious Sam 3: BFE is a glorious throwback to the golden age of first-person shooters where men were men, cover was for amateurs and pulling the trigger made things go boom. Serving as a prequel to the original indie sensation, Serious Sam: The First Encounter, Serious Sam 3: BFE takes place during the Earth’s final struggle against Mental’s invading legions of beasts and mercenaries. Set against the collapsing temples of an ancient civilization and the crumbling cities of 22nd century Egypt, Serious Sam 3: BFE is an exhilarating fusion of classic twitch shooters and modern gameplay features.
“Serious Sam 3 is about pure fun and unfiltered action,” said Davor Hunski, chief creative officer of developer Croteam. “We wanted to expand on everything gamers love about the series while adding some genuinely unique new features to really enhance the mayhem Serious Sam is known for.”
Trademark features such as relentless hordes of spectacular enemies and expansive outdoor battlefields return in Serious Sam 3: BFE at full force. Other features include:
Frantic Arcade-Style Action – The calling card of the Serious Sam series, hold down the trigger and lay waste to a never-ending onslaught of attackers or face being overrun by Mental’s savage beasts. No cover systems, no camping – it’s just you and them. All of them.
Mental’s Fearsome Legions – A new battalion of unforgettable minions including the rumbling Scrapjack and towering Khnum join the legendary Headless Kamikaze, Gnaar and Sirian Werebull. Your days of mowing down zombie Nazi space pirates are over.
Serious Melee Attacks – When an enemy slips by your wall of lead and pain, use one of the all-new innovative melee moves to drop an enemy right where they stand in the most violent way possible.
Pure Multiplayer Mayhem – Play through the full campaign mode with up to 16 players or drop the gauntlet and let the heavy ordinance fly in versus modes like Deathmatch and Beast Hunt. This is the next level of Serious Sam multiplayer and all hell is about to break loose.
“Holy crap, I am going to make a boatload of cash of this game,” said Fork Parker, chief financial officer at Devolver Digital, the Serious Sam 3: BFE publisher. “I mean that’s what this is all about, right? If this thing comes out in the summer my wife is totally getting the tit job she’s been asking for.”
Serious Sam 3 will bring the boom to PC and game consoles this summer.
When asked for further comment, Fork replied, “Bam. Tit job.”
Reveal In-game Screenshots and game art image
http://www.box.net/shared/pfepdp5n96
About Croteam
Croteam are the creative force behind the massively successful Serious Sam series, which is recognized across the globe for its action-packed and entertaining game design and its powerful Serious Engine technology. Founded in Zagreb, Croatia in 1993, Croteam has grown to become one of the most successful and respected developers in Eastern Europe. More information about Croteam can be found online at www.croteam.com and twitter.com/croteam.
About Devolver Digital
Devolver Digital is a small, laser-focused production and publishing company based in Austin, Texas, (also with one very lonely desperado in London) from an unnamed group of industry veterans/outlaw refugees. Our Twitter handle is @DevolverDigital so hook it up.
Lepo izgleda, svidja mi se narocito sto nije vise cartoon izgled
Citao sam jos u decembru da se Sima skorije, ali citajuci ovaj intervju ovo upada najvise u oci:
Nov engine je perfekcija. Onaj SS HD leti na 3650 Pro maxed out, primetio sam da je Quad core must have za ovaj engine :-devil-:
fotke deluju neverovatno, i poprilicno osvezavajuce... mada opet to su fotke samo
Nisu samo fotke ako budes igrao SS HD videces koliko svaki model ima detalja, steta sto su na ostatak prelepili samo nove teksture.
Malopre sam video e3 intervju sa dosta gejmpleja http://www.gametrailers.com/video/e3-2011-serious-sam/715941 S obzirom da igra prvo izlazi za PC da se zakljuciti da je SS 3 PC based igra, a da ce za konzole da odrade port. Igra ce da bude, cini mi se, odlicna razbibriga, kao i prethodnici 🙂 Izgleda sjajno, puno krvi, izivljavanja, sve ono sto je potrebno za pravi nastavak.
http://www.youtube.com/watch?v=tb39C4clCzo - Jos jedan intervju sa novim gejmplejom
Meni ovaj prvi trejler izgleda lose. Mogu da spomenem nekoliko reci i da kazem na sta me podseca (pustinja, uske ulice, konzolna igra = call of duty). Zasto danas sve igre moraju da budu ukalupljene u konzolne verzije igre call of duty. Izgleda da se to jos uvek dobro prodaje. Medjutim, bilo kako bilo, ovo mi bas ni malo ne lici na prvi deo koji je imao neku posebnu atmosferu.
Malo mi odudara od ostalih SS narocito sa tim COD red sight nisanima na puskama😉 I neprijatelji su mi nekako suvise pasivni, stoje u mestu
