Da li se desilo nekom da ga kikuju u toku partije ?
Posebno kada počneš da dobijaš. Ne mislim na "drop hack" , več ti piše da si kikovan ?!?!?!?!
We have received the all clear from the Quality Assurance team to release the next patch for Company of Heroes, which will update the game version to 2.602. We will be releasing the patch on Tuesday, May 24, after a brief maintenance window. The maintenance window is scheduled to last from 09:00 – 10:00 PST, which is 12 noon – 13:00 EST and 16:00 – 17:00 GMT, after which players will be prompted to update to the new patch when they log in to the game.
In addition, we will be performing a reset of our leaderboard that will affect all players that are rank 11 and higher. These players will have their ranks reset to 10. Players that are rank 10 or lower will not be affected by this reset. We will be performing the rank reset on Tuesday as part of the patch release.
Thank you for your patience and support in the creation of the patch, especially to those players that played in our beta. Your feedback has been invaluable.
Company of Heroes
v2.602 – Operation Torch 07/08/2011
Maps
3 new maps have been added to the game:
o 2p Carpiquet
o 6p Refinery
o 6p Steel Pact
3 new community map have been added to the game:
o 2p Duclair
o 2p Egletons
o 4p Alsace Moselle
The following maps have received significant balance changes:
o 2p Beaux Lowlands
o 2p Flooded Plains
o 2p Ruins of Rouen
o 2p Sturzdorf
o 2p Wrecked Train
o 4p Duclair
o 4p Lorraine
o 4p McGechaen's War
o 4p Point Du Hoc
o 4p Rails and Metal
Bug Fixes:
Units no longer continue to crawl after recovering from Suppression
Chance for a kill critical on vehicles is now properly being updated when they've received other non-kill criticals (5% bug)
Unbuilt Tank Traps cannot be repeatedly spawned around enemy vehicles
All vehicles now properly have vehicle cover
Registered Artillery can no longer target field defenses
Registered Artillery can no longer be refunded after use
M18 Hellcat can now be detected
Goliath can now be detected
Recon Squads can now detect camouflage while moving
Teller Mines no longer have a chance to miss vehicles in vehicle cover
The Hotchkiss now properly shares experience with other PE units
ATHT's using Focus Fire now have intended accuracy vs moving British infantry
Hetzer Veterancy requirements reduced to standard
M10 Veterancy requirements increased to standard
Panzer IV Stubby now prioritizes light vehicles over infantry
StuH now prioritizes infantry over vehicles
PE Panzerschrecks no longer convert to Wehrmacht Panzerschrecks when dropped
Geschutzwagen wrecks can now be salvaged for Munitions
Luftwaffe reinforce time reduced to standard
Paks and Nebelwerfers can now use Medkits
AT Grenades now collide with enemy vehicles
Hetzer and Jagdpanther CP reward increased to standard
Panther Battlegroups are much less likely to fail to spawn the second Panther
Medics no longer detect camouflage
Snipers and weapon teams can now pick up Supply Drops
Tank Traps can no longer be placed so close together that they block infantry
105mm Howitzers are now re-crewed with 3 squad members
Removed the chance for the Pak38 support members to one-hit kill infantry
Bombing Run no longer does double damage to Vet 3 StuGs
M10 no longer has increased accuracy vs skirted PanzerIVs
Wehr Officer 81mm Mortar Bombardment can no longer be interrupted to produce false smoke
Panther Battle Groups and OMCGs will not refund their cost if partially called in on an unfinished building
AT Guns no longer avoid their reload time by resetting the gun after a shot
Panthers now properly benefit from Tank Destroyer's APCR upgrade
Nebelwerfer rockets no longer have a chance to instantly kill all occupants of a building
Sappers with the Demolitions & Disposal upgrade are no longer negatively affected by the Lieutenants movement aura
Pioneer Call-in now has proper requirements after the HQ is destroyed
PE Armored Cars are no longer resistant to engine damage from mines
Ranger Bazookas no longer drop with greater frequency than other slot items
Propaganda War’s chance to not trigger on targets has been removed in most instances
Snipers are now able to re-enter camouflage after a reasonable duration after exiting a building
“Burst Fire” effects have been reduced on the Ostwind, Puma, and PE Armored Car
Kettenkrad’s can now repair resource points that have had Scorched Earth used on them
American Medics are now selectable (to see unit health)
Demolition Charges can now be targeted by weapons
Stickybombs can now be interrupted by retreat commands
Panzerfaust can now be interrupted by retreat commands
General
Speech
Some speech files missing from Wehrmacht and Panzer Elite upgrades have been restored
Medics
Health reduced from 120 to 60
Snipers
Accuracy vs garrisoned units increased from 75% to 100%
Will no longer automatically seek cover before firing
Flamethrowers
Damage vs units in open cover reduced from 1.0x to 0.85x
Damage vs units in negative cover reduced from 1.0x to 0.75x
Damage vs Soldier Armour reduced from 1.0x to 0.95x
Damage vs buildings increased from 0.5x to 0.6x
Infantry Flamethrower max damage reduced from 40 to 30, min damage increased from 15 to 25
Sherman and Churchill Flamethrower max damage reduced from 40 to 35, min damage increased from 20 to 30
Halftrack Flamethrower max damage increased from 30 to 35, min damage increased from 10 to 30
Grenades
No longer have a chance to miss the targeted location
Abilities
Weapon using Abilities can no longer be used while Pinned
Base Buildings
All base buildings can now reinforce
American
Engineers
Suppression threshold increased to match other infantry
Suppression recovery threshold increased to match other infantry
Upgrading with flamethrowers now increases your suppression modifier by 1.5x
Mortar
Barrage scatter angle reduced from 15 to 10
Set-up time reduced from 2.4s to 1.5s
Pack-up time reduced from 2.8s to 1.9s
.30 Cal HMG
Pack-up time reduced from 2.5s to 2.1s
Ready aim time decreased from 0.3 to 0.1 (it will aim faster)
Anti-Tank Gun
Reinforcement cost reduced from 71 to 26
Accuracy vs Anti-Tank guns reduced from 0.5x to 0.1x
Accuracy vs Infantry reduced from 0.15x to 0.05x
Accuracy vs Snipers reduced from 0.15x to 0.02x
Targeting priority vs Snipers reduced from 10 to 5
Weapon health increased from 300 to 390
Sherman Crocodile
Range increased from 20 to 25
Vet 2 1.5x Penetration bonus replaced with a 0.8x Cooldown bonus
M18 Hellcat
Speed increased from 6.0 to 7.2
Acceleration increased from 1.5 to 2.0, Deceleration increased from 3.8 to 4.4
Vet 2 bonus is now 1.5x Penetration rather than +1.25 Range
Hellcat penetration at short range increased from .65x to .75x, medium range from 0.55x to 0.69x, and long range from 0.4x to 0.63x
Target table now identical to the M10's
Damage bonus from camouflage reduced from 2.0x to 1.5x
Penetration bonus from camouflage reduced from 5.0x to 1.5x
M26 Pershing
Cost reduced from 900 Manpower to 800 Manpower
Off-Map Combat Group
M8s and Hellcats now spawn with their upgrades
Population requirement increased from 12 to 15
Off Map Artillery
Damage modifier vs Pak38s reduced from 2.0x to 1.33x
Jeep
Received Accuracy from the Pak reduced from 1.0x to 0.75x
Received Accuracy modifier from the Pak while moving reduced from 0.75x to 0.5x
Received Damage from the 57mm ATG reduced from 1.0x to 0.5x
Strafing Run
Significant changes to make Strafe more effective against groups of units and less effective against single units
Sticky Bombs
Deflection Damage enabled, set to 50%
Accuracy increased to prevent thrown Stickies from missing their intended target
Riflemen
Received XP bonus from BARs and Stickies reduced from 5% to 0%
Received XP bonus from Supply Yard 2 increased from 20% to 30%
T17
Cooldown lowered from 2-2.5 to 0
Reload increased from 1 to 3.5
Health increased from 175 to 265
Vet 1 Health bonus reduced from +175 to +50
Fixed an issue where the T17 had a harder time penetrating the rear armour of some vehicles
Fixed an issue where the T17 would fail to penetrate Snipers
Wehrmacht
Kampfkraft Center
Now requires a built base structure or a FHQ
Pak 38
Number of camouflage shots reduced from 3 to 1
Cost reduced from 310 Manpower to 290 Manpower
Reinforcement cost reduced from 57 to 23
Accuracy vs Anti-Tank Guns reduced from 0.5x to 0.1x
Accuracy vs Shermans increased from 1.0x to 1.1x
Accuracy vs Cromwells increased from 0.8x to 1.0x
Accuracy vs Pershings increased from 1.08 to 1.15
Panzerschreck
Accuracy vs M8 Greyhound Armour increased from 0.73x to 0.85x
Accuracy vs M3 Halftrack Armour reduced from 1.0x to 0.85x
Accuracy vs Stuart Armour reduced from 1.0x to 0.85x
Damage vs Stuart Armour reduced from 1.0x to 0.7x
88mm Flak 36
Accuracy vs Infantry reduced from 0.5x to 0.15x
Accuracy vs Snipers reduced from 0.25x to 0.05x
Puma
Received Accuracy bonuses while moving from Vet removed
Level 2 Veterancy sight bonus increased from 4 to 10
Officer
Build Time reduced from 45s to 25s
StuG
Acceleration increased from 1.7 to 2.5, Deceleration increased from 2.0 to 3.0
G-Wagon
Damage lowered from 250 to 185
MG Gunner now requires Vet 2
Vet 3 bonus reduced from 0.5x Reload to 0.75x Reload
Accuracy vs Anti-Tank Guns reduced from 0.65x to 0.2x
Nebelwerfer
Suppression radius reduced from 18 to 13.5
StuH
CP cost lowered from 3 to 2
Cost lowered from 600 Manpower to 500 Manpower
Tiger
CP cost increased from 4 to 5
Cost lowered from 900 Manpower to 800 Manpower
Assault Grenades
Maximum damage lowered from 35 to 25, minimum damage lowered from 25 to 10
Low health kill critical chance increased from 0% to 30%
Knights Cross Holders
Now passively regenerate 21.12 Health per Minute
Received Damage from BARs, Brens, and Thompsons reduced from 0.85x to 0.78x
Firestorm
Damage vs 105mm Howitzers reduced from 1.0x to 0.35x
Medkits
Cost reduced from 35 Munitions to 30 Munitions
Goliaths
Goliaths can no longer be Buttoned
Goliath rotation speed increased from 45 to 65
Rocket Barrage
Long AoE increment damage increased from 0.1x to 0.2x
AoE accuracy increased to 100%
Panzerfaust
Damage vs Bren Carriers increased from 1.3x to 1.45x
Accuracy increased from 100% to 200% at all ranges
Accuracy vs infantry halved
Blitzkrieg
Cost reduced from 150 Munitions to 125 Munitions
Manpower Blitz
Cost reduced from 200 Munitions to 175 Munitions
MG42
Cost reduced from 260 Manpower to 250 Manpower
Build time reduced from 40s to 35s
Halftrack
Motorcycle
Schwimmwagen
Cost reduced from 240 Manpower to 225 Manpower
Build time reduced from 45s to 40s
Volksgrenadiers
Reinforce percentage reduced from 0.5x to 0.4x
Capture speed increased from 1.0x to 1.25x upon reaching Skirmish Phase
Light MG42
Drop chance reduced from 60% to 30%
Long Range Accuracy increased from 0.1x to 0.13x
Commonwealth
Kangaroo
Cost increased from 240/10 to 300/45
Health reduced from 650 to 550
Speed reduced from 6.5 to 5.85
Build time increased from 35s to 45s
Staghound
Damage vs Infantry Armour reduced from 1.75x to 1.5x
Damage vs Airborne Armour reduced from 1.0x to 0.75x
Damage vs Heroic Armour reduced from 0.85x to 0.75x
Damage vs Sniper Armour reduced from 1.5x to 1.0x
Damage vs Soldier Armour reduced from 1.5x to 1.0x
Accuracy vs Elite Armour reduced from 1.0x to 0.75x
Accuracy vs Soldier Armour reduced from 1.0x to 0.75x
Sappers
Now have the Wirecutters ability
17 Pounder
Health increased from 400 to 450
Lieutenants
Now receive a 0.85x Received Damage modifier at Vet 1
Vet 2 Received Accuracy modifier increased from 0.9x to 0.75x
Now receive a 0.75x Received Accuracy modifier at Vet 3
Lieutenants' aura's stackable damage modifier at veterancy level 1 has been reduced from 1.125 to 1.04
Lieutenants' aura's non-stackable damage modifier at veterancy level 1 has been increased from 1.025 to 1.11
Lieutenants' aura's stackable damage modifier at veterancy level 2 has been increased from 1.025 to 1.065
Lieutenant's aura radius increased from 25 to 30
PIATs
Penetration modifier at short and medium range reduced from 2.0x to 1.0x
Reload modifier at long range reduced from 1.6x to 1.2x
Projectile speed increased from 10 to 15
Penetration vs skirted Panthers reduced from .15 to .112
Penetration vs skirted PIV reduced from .449 to .337
Penetration vs skirted StuG reduced from .332 to .249
Damage vs Infantry Armour reduced from 0.5x to 0.33x
Damage vs Heroic Armour reduced from 0.5x to 0.33x
Damage vs Elite Armour reduced from 0.5x to 0.2x
Damage vs Sniper Armour reduced from 1.0x to 0.2x
Damage vs Soldier Armour reduced from 1.0x to 0.33x
Mortar Pit
Build Time reduced from 90s to 60s
While under construction received damage modifier increased from 0.5x to 0.75x
Damage reduced from 20 to 18
Supercharged range decreased from 100 to 90
Recon Section
Recon Sections can no longer build Trenches
Churchills
Churchill and AVRE Population lowered from 14 to 8
Churchill Crocodile Population lowered from 16 to 10
Churchill 6 Pounder gun AoE distance increased from 0.1/0.25/0.5 to 0.15/0.5/1.0
Bofors
Build time reduced from 90 seconds to 60 seconds
Bren Carrier
Self-Repair ability is disabled while the Carrier is garrisoned
Garrison disabled while Self-Repair is active
Panzer Elite
Halftracks
All Panzer Elite halftracks have received an update to their pathfinding
Panzer-Jaeger Kommand
Build time increased from 115 to 135
Gewehr 43
Maximum cooldown reduced from 1.8 to 1.65, minimum cooldown reduced from 1.25 to 1.15
Suppressive Volley Fire now Suppresses the target
Suppressive Volley Fire slow duration reduced from 20s to 5s
Incendiary Grenade
Hotkey changed from “Y” to “N”
Kettenkrad
Sight Range increased from 35 to 55
No longer autotamically moves out of the way of other vehicles
Schwimmwagen
Mark Target cooldown increased from 10 seconds to 45 seconds
Mark Target Munitions cost increased from 0 to 15
Incendiary Trap trigger radius increase from 0.5 to 2
Incendiary Trap’s damage-over-time modifier vs British infantry increased from 1.0 to 1.25
Infantry Halftrack
Accuracy vs Light Cover increased from 0.75x to 0.8x
Panzerschreck
Scout Car
Detection radius increased from 9 to 18
Vampire Halftrack
Divert Supplies now camouflages the Vampire while active
Population reduced from 4 to 2
Munitions Halftrack
Cost reduced from 200/15 to 200
Armoured Car
Detection radius lowered from 9 to 0
Accuracy vs garrisoned units increased from 0.4x to 0.45x
Vet 2 and Vet 3 increase Health by 20 each
Build time increased from 45 to 55
Overdrive ability hotkey changed from “O” to “V”
Marder III
Sight Main Gun LoS bonus increased from +5 to +10
Tracking speed increased from 10 to 20
Population reduced from 8 to 5
Anti-Tank Halftrack
Accuracy vs M8 Greyhound Armour increased from 1.0x to 1.05x
Treadbreaker cost increased from 40 Munitions to 50 Munitions
Population reduced from 6 to 4
Hotchkiss
Accuracy vs Infantry increased from 0.5x to 0.6x
Stuka upgrade cost reduced from 150 Munitions to 100 Munitions
Stuka Barrage cooldown reduced by 10 seconds per Vet level
Bergetiger
Population reduced from 10 to 8
Hummel
Population reduced from 12 to 10
Base-Sector Flakvierlings
Population reduced from 3 to 0
Skin'o! Evo i ovde da kopiramo tekst izmena koje donosi nova zakrpa, čisto da se može baciti pogled bez dosadnog čekiranja starosne granice na nesrećnom COH sajtu.
Nekako mi izgleda da su Ameri i Britanci dobili više. Odnos snaga izmeđi saveznika i wehrmacht a nije izbalansiran. Nekako više forsiraju saveznike.
Stekao sam takav utisak.
I meni se tako cini, mada sam mozda subjektivan jer "navijam" za Werhmacht.
Elem, moderatori bi mogli da prekrste temu, ipak je COHO "mrtav jos od kraja marta...
zato sto me "delje" ko stigne :-(
ja Automatching igram samo sa jenkijima. Dokle god nemam negativan odnos pobeda i poraza - ja zadovoljan
Elem, a sta kazete da se popisemo? Lista "prijatelja" u igri mi je ogromna, a vise nemam pojma koga sam gde pohvatao
Bilo bi lepo kada bi to stajalo na vrhu strane, nesto kao potsetnik (sticky) i vremenom se azuriralo...a jos bi lepse bilo kada bi neko od MOD-ova podrzao ovo.
Dakle:
ZeeGerman - Vlayko
vladat1 - vladat1
W3Industry - Shmajser
Waylander - Rooliemann (jesam li ja sa tobom pricao na engleskom, pod pretpostavkom da sam ti nick "pokupio" na gamereplays.org!? :wall
Drvodelja - KAMARAZ
G!!! - mocnijogurt za tebe mi stoji "pending request" vec mesec dana :laugh:
Commanderr33 - Commanderr33
svarog84 - svarog84
znam da nisam popisao sve...pa...nastavite
P.S. MOD-oviiiiiiii.....potrebna "popravka" teme![]()
Šta super ideja. Ja o spisku pričam zadnje 3 strane
Nema udarca bez Pancer Elite.
Ako u grupi nemam PE, gotovo je nemoguće da dobijem Britance
Inače pored nadimka nije loše da se napiše i šta ko preferira. Ja lično gotivim Wehrmacht.
Kako se beše dodaje priatelj ?
/addfriend u chatu. Bas nemam vremena za COH u zadnje vreme a zanima me sta je novo doneo patch. Ja mogu da igram sa svima osim sa PE, njih jos nisam prostudirao
