Sapphire 5830 i 5850 Xtreme official thread
pixell
Evo šta kažu za taj ultra jeftini Sapphire HD5850:
With the thermal solution off, you can see that this is indeed a Barts based board design, with the only difference being that Sapphire has slapped on a Cypress graphics processor. The Cypess GPU was AMD's flagship processing core before they launched their Northern Islands graphics cards in Q4 2010. There are varying specifications to the Cypress core, with each having a different amount of Shader clusters and clock speeds. However, they were all built on a 40nm process and have a 334 mm² die size. The board design of the Xtreme series also includes eight ELPID memory chips, a 4+1 phase design and even has additional cooling on the VRM.
To overclock the HD Xtreme series graphics cards we used Sapphire's TriXX overclocking utility and increased the GPU and memory clock speeds to their highest stable frequencies. While overclocking the HD 5850 Xtrme I was a bit surprised that the GPU could not achieve a higher clock speed than 798Mhz, but when looking back over the launch reviews of the HD 5850 it is not too far off from what most board were capable of. As for the memory we were able to increase the speed to 1190Mhz (4760MHz effective).
Sve je to lepo ali ovo je u njemackoj :d prijatelju.
U Zerbiji povoljnije od ove msi nema, Tj bolje kupovine. Daj Budo da bude kao u Nemackoj..
Kad li ce biti ovih karti kod nas, ovo ce biti odlicna kupovina i 5830 i 5850.
Ko zna.. Ali ce ovo biti odlicne CF opcije, ja kapiram da ce moja sledeca konf biti 5850CF ;)
Ako 5830 extreme bude ispod 100 evra ili oko 100 evra, to ce da bude vrh kupovina za crossfire.
Biće Crossfire test ovih Sapphire HD 5850 Extreme za vikend sa sve diazanjem voltaže ;)
"I ja sam gladan" :), tj. i ja bih vrlo rado jos jednu po toj ceni .
Kolega će pokušati da donese dve iz Beča prekosutra ;)
Ako kolega resi da proda ednu, ja sam mozda tu :).
Obe idu meni za CF setup. Moja referentna ide u oglase ;)
znaci ova safirka ima voltera chip i sve je ok sa njom iako je tako jeftina posto imam mogucnost da mi je tetka donese iz austrije sad za uskrs?
jel zna neko kad ce se pojaviti kod nas?
sapphire extreme izgleda stigao u e...i :)
ako ne laze onaj review,klokuje se na 1000/1200mhz,plus ako ne piste zavojnice,onda je ipak bolja od msi-a. (s' obzirom da je ista cena)
Pa dobro, to jeste, ali mislio sam da neće biti preko 120-125e.
I ja sam,al' sa obzirom da je ovo Srbija :p,ne bi me cudilo i da su 150e :D
Mada opet cena je primamljiva,da se ne lazemo,ukoliko se izjlalove trenutni pregovori oko jedne graf,bez razmishljanja narucujem ovu u ponedeljak ;)
ok drugari, ova grafa definitivno zasluzuje svoj zvanican thread tako da sam prebacio postove iz MSI 5850 threada u ovaj :)
jedva cekam da je neko kupi i da prenese utiske iz prve ruke :D da nisam uzeo ovu Sapphire 5850 Toxic licno se ne bih dvoumio ni sekunde cime da se pocastim :)
have fun :wave:
Samo, ova Safir mi je ruzna bre :D
+ima 1 god manje garancije od MSI.
Ma neka se nose, kako ja sad da prodam moju 5770 kada je ova 5830 tako pristupachna. Anyway, bash je super shto ova 5850 ima kontrolu voltaze, samo nisam siguran koliko ce efikasno kuleri 68xx kartica ohladiti 5850.
hoce bez problema jer 5850 mozda trosi svega 20-30W vise :)
