Floumaster
Cenjen
Hteo bih da kada kliknem (u Word iz paketa Office 2007) na ikonu shtampacha u palaeti shtampacha dobijem i pdf. Shta je potrebno da instaliram.
Hvala unapred
Hvala unapred
Key Features:
- Create PDFs from any program that is able to print
- Security: Encrypt PDFs and protect them from being opened, printed etc
- New: Digitally sign your PDFs to ensure that you are the author and the file has not been modified
- New: Create PDF/A files for long term archives
- Send generated files via eMail
- Create more than just PDFs: PNG, JPG, TIFF, BMP, PCX, PS, EPS
- AutoSave files to folders and filenames based on Tags like Username, Computername, Date, Time etc.
- Merge multiple files into one PDF
- Easy Install: Just say what you want and everything is installed
- Terminal Server: PDFCreator also runs on Terminal Servers without problems
- And the best: PDFCreator is free, even for commercial use! It is Open Source and released under the Terms of the GNU General Public License.
- Supports Windows Vista and Windows 7
Konza 🙂
Kada se instalira service pack 2 pojavi se opcija save as pdf.
PDF štampač je univerzalno rešenje (tj. "all-2-pdf") 🙂2011. godina, a vi i dalje jurite te stampace za PDF. Za Office 2007 samo instalirate SP2 ili add-in, 2010 po defaultu ima "save as pdf"
@RazbojNick @kupuz
Pokretac teme je pitao za, citiram, "Word iz paketa Office 2007". Ok je podrska tih programa za sve moguce i nemoguce formate, ali za Office odnosno Word uopste nije potreban dodatni program.
