Killzone 3
Moze li konacno promena naziva teme ?
Menjajte preorder na shopto. 😛
http://www.killzone.com/kz3/en_US/preorder.html
Evo ga i novi intervju sa clanom GG.
http://n4g.com/user/blogpost/catastrophe/516173
Killzone 3 Multiplayer Classes
The following will look at the abilities of the ENGINEER, MARKSMAN, TACTICIAN, INFILTRATOR and FIELD MEDIC classes, as well as their primary and secondary weapons. This information has been obtained from the KILLZONE 3 BETA.
ENGINEER
PRIMARY ABILITIES
Repair Tool
Repair damaged or destroyed ammunition dispensers, mounted guns and automated turrets.
Repair Tool+
Increases repair speed.
Repair Tool++
Hack enemy placed turrets, transferring ownership until the Engineer is killed or the turret is re-hacked. Stacks with previous abilities.
SECONDARY ABILITIES
Sentry Turret
Deploy a machine gun turret that will automatically target and fire at enemies in range.
Sentry Turret+
Turret’s firing rate is increased and can be deployed twice as fast as before.
Sentry Turret++
Deployed turrets can now track targets faster and are augmented with auto-fire rockets that fire every few seconds.
PRIMARY WEAPONS
M224-1A LMG
Friend to bunkered soldiers everywhere, the LMG’s iron sights and large clip size will make the enemy think twice before storming any position.
STA11 SMG
No other automatic weapon is better suited to close-range, in-your-face encounters than the StA11.
STA3 LMG
Accuracy is overrated. The StA3’s high rate of fire and large clip size will clear out a room in seconds. A formidable close-range weapon.
SECONDARY WEAPONS
STA18 Pistol
Standard issue semi-automatic pistol.
VC8 Shotgun Pistol
The best weapon for a close-quarters fight, nothing says ‘up close and personal’ like the VC8.
STA2 Battle Pistol
Increases grenade storage capacity and fires grenades farther than a soldier could ever throw.
MARSKMAN
PRIMARY ABILITIES
Cloak Suit
Stay cloaked for a limited time. Firing any weapon will disable the cloak and moving around will reduce its effect.
Cloak Suit+
Stay cloaked indefinitely. Firing any weapon will disable the cloak and moving around will reduce its effect.
Cloak Suit++
Stay cloaked indefinitely while firing weapon. Damaging an enemy player or moving around will cause the cloak to ripple for a short time. Mortally wounding or killing an enemy will disable the cloak unless using a silenced weapon.
SECONDARY ABILITIES
Scramble
The Marksman and any allies within 15 meters will not show up on the enemy’s radar, even when firing weapons.
Scramble+
Marksman will not be revealed when an enemy Tactician uses their Recon ability. Stacks with previous ability.
Scramble++
Enemies within 15 metres of the Marksman will have their radars disabled. Stacks with previous ability.
PRIMARY WEAPONS
STA14 Rifle
A scoped semi-automatic rifle capable of felling most targets before they can get near you.
STA11 SMG
VC32 Sniper Rifle
With a long-range zoom (UP on D-Pad) and high accuracy, this rifle is capable of felling most foes in a single shot.
SECONDARY WEAPONS
STA18 Pistol
VC8 Shotgun Pistol
M66 Machine Pistol
Equipped with a reflex scope and a silencer, the machine pistol is an ideal weapon for close-range, surprise encounters.
TACTICIAN
PRIMARY ABILITIES
Tactics
Can capture Tactical Spawn Areas in the level which, once captured, allow all faction members to spawn there. Some Tactical Spawn Areas may unlock special level-specific objects, like jetpacks or mortar beacons.
Tactics+
Reduces the time it takes to capture a Tactical Spawn Area by half.
Tactics++
Capture and Hold mission areas can be captured at twice the normal speed. Stacks with previous abilities.
SECONDARY ABILITIES
Recon
Temporarily mark enemy positions on the mini-map by pressing left on the D-PAD. Any enemies within 30 metres of you will be revealed.
Recon+
Activate [RIGHT on the D-PAD] and throw a beacon to call in a flying Sentry Drone to attack enemies. If no enemies are present the drone will patrol the vicinity for threats.
Recon++
Upgrades the Tactician’s Sentry Drone, allowing it to track and fire faster.
PRIMARY WEAPONS
STA11 SMG
M224-1A LMG
STA14 Rifle
SECONDARY WEAPONS
STA18 Pistol
M4 Revolver
One shot will severely cripple an enemy, or kill a wounded one.
VC9 Missile Launcher
Capable of destroying turrets and drones in a single shot, the VC9 missile launcher is the very definition of an anti-armor weapon.
INFILTRATOR
PRIMARY ABILITIES
Disguise
Infiltrators can disguise themselves as a member of the opposing faction.
Disguise+
In addition to being disguised, Infiltrators are undetectable by Engineer Turrets, Sentry Drones and Medi-Droids.
Disguise++
Perform melee attacks without breaking disguise. Stacks with previous abilities.
SECONDARY ABILITIES
Survivalist
Increase stamina by 50% and sprint faster than normal.
Survivalist+
Unlimited stamina.
Survivalist++
‘Use’ actions, such as placing and disarming explosives, are completed 50% faster.
PRIMARY WEAPONS
LS13 Shotgun
The LS13 is a powerful semi-automatic shotgun equipped with a reflex scope. Whatever this hits stays dead.
STA11 SMG
STA52 Assault Rifle
Standard Helghast issued assault rifle equipped with reflex scope. Sturdy, easy to use and ideal for just about any combat situation.
SECONDARY WEAPONS
STA18 Pistol
STA2 Battle Pistol
FIELD MEDIC
PRIMARY ABILITIES
Revive
Mortally wounded players are revived with full health and a clip of ammo.
Revive+
Mortally wounded players are revived with higher maximum health, 2 clips of ammo and 1 explosive.
Revive++
Mortally wounded players are revived with higher maximum health and maximum ammunition and grenades.
SECONDARY ABILITIES
Triage
An aura of health is emitted from the Field Medic, regenerating himself and nearby faction members.
Triage+
Deploys [Right on the D-PAD] a hovering Medi-Droid that will accompany the Field Medic until death.
Triage++
If still mortally wounded at the end of the respawn timer, the Field Medic will be given the option to respawn where he fell with full health and ammunition.
PRIMARY WEAPONS
STA11 SMG
LS13 Shotgun
M82 Assault Rifle
Standard issue to all ISA combatants, the assault rifle is well-suited to most combat situations. Equipped with a reflex scope, this weapon is deadly in the hands of an experienced soldier.
SECONDARY WEAPONS
STA18 Pistol
M4 Revolver
M66 Machine Pistol
All primary and secondary abilities can be upgraded to ‘+’ and ‘++’ versions, which may provide different abilities entirely, mapped to a separate button, example; Recon (LEFT on D-Pad), Recon+/++ (RIGHT on D-Pad) or an upgraded version which stacks with previous abilities.
The ‘Career Selection’ screen has the following options:
CAREER (Class, example: Engineer, Field Medic, etc)
PRIMARY (Primary weapon)
SECONDARY (Secondary Weapon)
EXPLOSIVES (Explosive equipment type, example: Frags or Mines)
SKILL (Passive abilities, example: Extra Health, Extra Ammo)
All classes also have separate, passive abilities (skills) made available through the use of unlock points. They are the following:
Armor
Begin with armour that absorbs damage that would normally reduce your health.
Extra Health
Increases maximum health.
Extra Ammo
Weapons start with more ammunition.
Extra Primary Weapon
Substitutes a secondary weapon with a previously unlocked primary weapon.
There are also two types of explosives available to the player, which are:
M194 Frag Grenade
Equip and use Fragmentation Grenades.
Proximity Mine
Equip and use Proximity Mines.
Sentry Turret
Sentry Turret+
Sentry Turret++
Nisu normalni, jedna od stvari koja je najvise nervirala u KZ2, oni su samo unapredili u jos gore.
Bice ovo polu automatski FPS mp, "War of the turrets".
Ako budem igrao KZ3 mp svakako cu opet biti "medic" i pozdravljam ponudu naoruzhanja i sposobnosti za njega🙂.
[youtube]KgHtYZpuPD8[/youtube]
[youtube]vT5Zid7yOq4[/youtube]
[youtube]w1mbaGAL4lo[/youtube]
malo se zabagovalo na 0:25. i dobro klanje na 5:13 🙂
Koji ružan braon kolorit :wc:
Bice ovo war of the machines 🙂 Valjda nece biti totalni krkljanjac, Mech-ovi, vazdusni botovi, tureti, jet packovi.. vr', jos tenkovi samo 🙂 Dobro, citam da lika u Mechu mozes lako ubiti kroz staklo..
I smesno kako te industrija bukvalno primorava da kopiras neke stvari, ove "double kill" i "triplle kill" poruke i ostalo 🙂
Jesi li ti pogledao ova tri videa ili samo tek da nešto napišeš?
Komentarisao sam pre svega ovaj braon level. Mada i na ostalim mapama smeta što je sve na ekranu u različitim nijansama jedne te iste boje. Mora da imaju zaposlenog nekog ko radi CSI, pa je Majami žut, Vegas plav. Razumeš? 🙂
Mislim, zbog dobrog osećaja napucavanja ne mora se obraćati pažnja na to, ali bolje da su smislili neko drugo rešenje...
mene isto nervira to braon-ilo i gvozdjurija 😛
dobro je sto ce konacno srediti kontrole, pa nece biti retardirane kao u kz2.
Koje kontrole, sad moze mishem ? :d:d
Braon boja, retardirane kontrole...ne mirise na dobro 😀
Get into Killzone 3 Beta via IGN
IGN poklanja ulaznice za kz3 betu.
Nije bitan kolorit vec stabilan FPS ovaj put. Ako igra opet bude radila na 15 FPS bice ledilo je igrati u MP-u.
Stanisinjo daj code za betu !! 🙂
Nadam se da se varam, ali meni fizika vishe ne lichi na KZ, sve je ubrzano i kartonsko kao svi ostali FPSovi. Ili su to mozda uradili samo za MP, jer mi se cini da je SP demo bio "normalan"...
Nije ubrzano, samo je potrebno malo manje metaka za frag. Nisanjenje je ubrzano uz smanjenje input laga. Podseca na BC2, ali i dalje ima KZ osecaj.
Ni na kimijevim klipovima nisam mogao da skontam, a sada vidim da je i ovde ta pojava isto zastupljena... kako u jednom trenutku, iznad igrača pišu zelena slova (tvoj tim, je l' te), i odjednom se promene u crvena (ako zapuca na njih, ili se jednostavno promene). Taj deo baš i ne kapiram :/
Hm, zamerki ima još... Vidim da neka oružja uopšte ne trzaju prilikom rafala, to me malo zabrinjava :/
to ti je ova klasa iz marlijevog posta:
INFILTRATOR
PRIMARY ABILITIES
Disguise
bilo je toga i u kz2, tamo se klasa zvala saboteur.
ovo i mene zabrinjava, ali vidis i sam da ljudi traze deb*l-friendly mw2 kontrole..
Ne znam, meni ovo vishe lichi na one neke druge fpsove nego na KZ, nadam se da nisam u pravu, ili da je bar u SP fizika, tezina oruzja i inercija zastupljena kao u dvojci. MP ionako vidim da nece promeniti, i dalje u svakom trenutku iz 6 pravaca neprijatelj moze da ti dodje sa ledja :d
ovo ce biti pesma sa MOVE kontrolerom, can't wait! 😀 😀 😀
ADS je znacajno ubrzan, dok je trzaj u ADS-u eliminisan. Videcemo da li ce tako ostaviti stvar i za gold.
Kako svi seruckaju, a pogotovo ovaj drajver, sa citavih 5 minuta u Multiplayeru :d Skinite malo samo fanboy naocare, ili sta god je razlog da tako ostro branite KZ-ov sistem kretanja i nisanjenja. PRETERALI SU, niko ne kaze da treba da bude 'karton' kao u MW/MW2, ali mora malo da se utegne, prenaglasili su taj efekat tezine i inercije, ko god tvrdi drugacije stvarno mi nije jasan.. Nije ti smetalo drajveru jer si samo KZ2 i presao od pucacina na PS3 🙂
