Sony Playstation 3 hack tema
Navodno, moze da se skine sve sa PSN-a i da se potera na JB :)
Nisam stigao josh da testiram, ali chim uradim napisacu rezultate :D
Kanda hakeri priznaju poraz?
No 3.42+ Games for Hacked PS3s
…Yet. That’s unless hackers can figure out the new encryption keys introduced in firmware 3.42. New games, like Medal of Honor for one, require PS3 firmware 3.42 (or later) and trying to run that on your hacked console will only produce error 0×80010019. Now before you think, “well I’ll just modify the PARAM.SFO, big whoop.” Think again. That won’t get you anywhere, and Mathieulh explains that in this tweet:
But really, if anything, this is just another reason to buy a second PS3 — one for hacks & homebrew and one for PSN & games that will always require a later firmware version. You know it’s going to happen (read: PSP scene). Anyway, support the game developers — don’t pirate everything.
By the way, new game keys were added in the 3.42 appldr, if you get a 0x80010019 error that means the self/sprx can't decrypt.
5:39 PM Oct 12th via web
Mathieu Hervais
Nishta od ovoga :(
U najbolju ruku moze da se skine poneki patch (par je potvrdjeno da radi, medju njima i patch za Eye i Move), ali ne rade svi (lichno sam probao za PES - ne shljaka)
Placene stvari sa PSN-a ne mogu, jedino shto je potvrdjeno jesu free stvari (demoi i sl.)
Prodacu vam ja jaetino orginale koji traze novoji FW. :p
dzabe marli, hvala na ponudi..
opet, nece moci da se igraju bez update-a, a posle toga nece moci ni pirati :)
Znaci patka od piraterije za PS3 za nove igre ? :d
Pa sta ste ocekivali tako lako i jednostavno pa nisu ni oni glupi?
Cekaj, a sta sprecava npr M$ da ubaci isto u nove igre da traze noviji Dashboard ? Ne kapiram kako tamo ne mogu ili nece da zastite konzolu od pirata.
Znaci sad konzola sa 3.41 FW ce kostati 500e ? :D
@Nikola
Ne zanimaju mene pirati, PS3 imam iskljucivo zbog online igranja.
Čitao sam dobar deo teme, ali sad stvarno ne mogu da pohvatam, a drugar mi dolazi da mu hakujem ps3 jer se ja "razumem u te stvari". Dakle treba mi neki tutorial, ali baš ***** friendly, sa linkovima i uputstvima. Koristićemo hd2, na njega ću staviti 2.2 android (froyo stone nešto) ako taj odgovara, ako ne, treba mi i link za odgovarajući android.
Molim vas ako nekome nije teško, ili već ima sačuvanu sličnu poruku da je prosledi i meni, može i na pm, a moglao bi da se napravi neki tutorial ovde.
Svakome ko mi pomogne biću duboko zahvalan, a može tu da se desi i neka milka od 300g sa celim lešnicima ili druga odgovarajuća zahvalnica.
EDIT: Sad mi kaže drugar da mu ne radi optika, može li da se hakuje? Koliko sam pročitao, mora da ima neki original disk ubačen da bi moglo da se igra?
sa novijom verzijom Hermesa ne treba ti orginal u PS3, pa samim time radice hack i sa tom konzolom bez lasera... treba ti samo USB sa hackom ili neki od podrzanih uredjaja
Otprilike da sam pohvatao šta i kako do sa androidom, hermesom, ali šta dalje? Neki open manager pa neke igre...?
Ma jok, ja prodajem moju samo za 200e, cijena prava sitnica :d :d :d
za hd2 ti je najlakse da odes na cuveni sajt xda developers (primarno winmo portal/forum, ali bave se i androidom (tu i tamo))... postoji posebni modifikovani android za hd2 sa vec ubacenih usb driverima koji su preradjeni tako da "zeznu" ps3... ja sam taj koristio dok nisam kupio home-made usb koji pravi covek iz Novog Sada (vec smo pominjali ko su ti ljudi i gde ih mozete naci, mada mi se cini da se jedan od njih reklamira i ovde na oglasima)... prica se svodi da skines taj android sa xda-developers.. i onda u nekom hex editoru zamenis par bajtova u odgovarajucem fajlu (zaboravio sam mu ime, i tako pise tamo na forumu) zato sto po defaultu psgroove ne podrzava startovanje backup-ova tj. podrzava ali je namerno preusmeravanje br-drajva na hdd/usb iskljuceno... tih par bajtova promene vraca funkcionalnost.....)
najnoviji payload omogucava startovanje igara bez obaveznog BILO KOJEG originalnog diska u drajvu, ali ne radi savrseno tj. postoji izvestan broj igara koje i dalje zahtevaju BILO KOJI originalni disk tj. ne rade u diskless modu... jedna od njih, naprimer - moje licno iskustvo, je 'mortal kombat vs. dc universe'...
sto se tice sonijeve borbe protiv piraterije i nadmudrivanja preko firmware-a.. to ce potrajati neko vreme ili nece potrajati.. slicne tehnike su koristili i na PSP, pa su hakeri uvek iznova izlazili na kraj sa sonijem i razbijali jedan po jedan firmware.. ne vidim nijedan razlog da isto ne bude ni kod ps3.. vreme ce pokazati.. uglavnom, problem ce nastati kad svi novi ps3 budu stizali u prodavnice sa fw>3.41... cak i kada se to desi, moci ce se naci polovni ps3 sa fw <=3.41 (velika vecina ljudi ne izlazi online).. nove igre se mogu naterati da rade i na 3.41 , samo je potrebno crackovati iste (kao sto poznate grupe crackuju igre za PC).. trenutno nema nijedne poznate koja zna da se izbori sa ps3, ali se secam, naprimer, da su to radili sa igrama za PS1, negde na kraju njegove karijere pocele su da se pojavljuju igre koje su otporne na chipove, pa su hakeri izbacivali posebne modifikovane verzije gde su te napredne metode zastite bile ugasene.
elem nije mi jasno zasto neki ljudi likuju sto je sony "zahebao' hakere i pirate.. kao da se to licno njih tice ko ce sta da placa ili kupuje... maltene kao da su zaposlenici sonyja odnosno clanovi programerskih timova.. daj ljudi opustite se..
Sad ce se ovo jos Soniju isplatiti, neki ce morati da imaju 2 PS3. :)
Po mome ljudi likuju samo iz jednog razloga......
Navikli su na odredjen komfor, ubacis igru, ne razmisljas, igras nema cheatera.....
Posto su se pojavili prvi hack/cheat/etc za ps3 igre, ljudi su jednostavno protiv toga i ne zele da imaju iste gluposti koje imaju na PC...
PS3 NIJE ISTO STO i PC, i ljudi koji imaju PS3 bi u velikoj vecini voleli da tako ostane....
Anyway, pokazatelj koliko je ljudima koji se javljaju u PS3 hack temi stalo do PS3 igara se moze proveriti na osnovu broja postova u ostalim temama o PS3 igrama.....
Taj broj nekako blago tezi nuli......
Imali smo zaista vise nego dobar PS3 community ovde na benchu, ali to je iz nekog razloga baceno u zapecak.....
BaneRu, vrati se, tvoj podforum te zove :D :d :d
pojavila se glasina da je procureo:
Kod:
ps3 master key ahs
copy/paste/serach u Googlu za vise info... ;)
Kod:
ps3 master key ahs
Nedostaje mi ona emisija "Od traca do istine" ;)
Ajmo sad bez zezanja.....
Ako je ta glasina tacna sta dobijamo?
Od PS3 dobijamo PC , gde nemamo nikakvu zastitu od cheatera.....
Hocu da igram online i da znam da sam pobedio trku u GT5 zato sto umem da vozim, a ne zato sto sam stisnuo nitro/nuke/boost/charge.....
Oni koji ne shvataju to, neka ostanu u PC sobi... tamo imaju koliko god hoces takvih tema......
ako se zaista pojavio..
sony moze da ga popu*i :)
uz pomoc master keya i poznatog algoritma za enkripciju/dekripciju (a poznat je, manje vise - samo fale kljucevi)... uz pomoc master kljuca moguce je potpisati svaki izvrsni fajl i to tako da radi i na NEHAKOVANOJ konzoli (u osnovi se radi u enkripciji)... i isto tako je moguce DEKRIPTOVATI bilo koji izvrsni fajl, sto naravno ukljucuje i ove nove sto traze 3.42 fw...
sony ce tesko pobediti (ako je uopste tacno) to sto je procureo njihov master key za security.. ako se radi o kljucu koji je hardwerski ugradjen u cell CPU, jedini nacin je da novi kontigent cell procesora ima drugaciji kljuc, a to povlaci nekompatibilnost sa bilo kojim vec postojecim cell CPU/PS3.. to mozda moze novi firmware da nadomesti... ali opet... bas me zanima sta ce biti
Dok god ovo ne pocne da se mesa bilo kako u Online igranje, nece mi smetati..
Nego mi je stvarno impresivno koliko je ustvari ovo dobra zastita, ne bi jos uvek nista bilo od ovoga da im nisu otvorena vrata greskom nekog iz Sony-ja (ne znam tacno sta se tu izdesavalo, ali kapiram da je nesto bitno procurelo, inace bi sve ostalo na onom Geohotovom pokusaju).
Zbog ovakvih likova moram da navijam za sony u ovom ratu...
A sto se tice zastite, stvarno je vrhunski osmisljena, procitajte malo onu cell dokumentaciju (mislim da je Colt postovao, ako ne, lako cete naci). Vidi se da je strogo vodjeno racuna o zastiti od samog starta dizajniranja sistema...
Pa pazi, ja sam batalio PC igranje bas zbog toga....
Sony mi je ponudio nesto sto nisam mogao da nadjem...
A to je normalno igranje....
I ako mnogo ginem, znam da je to zato sto ne znam igram :d
No, videcemo....
mozda cu da prodam oba PS3 ako se pokaze da je ovaj trac istinit
Cekaj, vi stvarno ocekujete da bilo sta moze da poremeti online igranje na bilo koji nacin? Na to slobodno zaboravite, najbolje sto moze da se desi iz svega ovoga je besplatno offline igranje piratskih igara i to je kraj.
kako da ne bude dobra zastita, kad su napravili cellCPU u saradnji sa IBM i to namerno i planski tako da bude najbolje zasticen CPU ikad..
cell CPU ima hardwerski integrisan security koji se bazira na enkripciji i dekripciji izvrsnog koda (u realnom vremenu, hardwerski ili softwerski - po zelji programera).. u sam cell CPU je fabricki ugradjen key, koji je nedostupan spoljnom svetu, niti se ikada pojavljuje u memoriji/bilo gde.. na hardwerskom low-level nivou cellCPU koristi isti za svoje potrebe, zatim ima 1+8 jezgra, od cega je jedno glavno/za opste potrebe a ostalih 8 jezgara se mogu opisati kao nezavisni koprocesori za matematicke operacije (koje se izvrsavaju ultra-fast)... e sad, posebna poslastica: cell CPU ima osobinu da "izoluje" bilo koji od tih 8 jezgara za posebne potrebe, uglavnom security related. PS3 OS uveliko koristi ovu osobinu za svoje security potrebe, a koska je da kad jednom pokazes koprocesoru adresu programa koji treba da izvrsi i prebacis ga u 'isolated' mode, taj koprocesor se ponasa kao black box.. u njega podaci mogu da udju na obradu i da izadju rezultati.. totalno je nemoguce spijunirati sta se desava unutra jer se sve izvrsava paralelno sa glavnim jezgrom ali i potpuno nezavisno.. izlorirani komprocesor ima svoje registre, svoja stanja, i mogucnost da deo memorije koji okupira u potpunosti zatvori za pristup spolja... tu nista ne pomaze.. jer je resenje hardwersko...
ma ludaci.... zamislite kako bi izgledao PC racunar da je CPU koji mi koristimo (intel/amd) baziran na toj filozofiji... ko zna, jednog dana mozda i bude?
ja ne znam cemu tolika paranoja oko online igranja.. pa i u PC svetu ima online igranja, ima i cheatera, ali uglavnom brzo izlete ili uopste ne udju.. prevaranata ima na underground game serverima i tako tim po zemljama treceg sveta.. ovi ostali brzo dobiju nogu.. a koliko znam, postoje i sistemi poput "punkbuster" koji upravo sluze da blokiraju cheatere???
Pa da... ali to ne radi bas tako kako je zamisljeno... uvek ima onih koji su ispred PB-a...
A do sada na PS3 nam nije bio potreban PB niti nesto drugo.....
