- Laser-tuned drivers
You’ll enjoy high-quality audio with minimal distortion.
- Pure digital USB
You’ll experience clear, digital sound with the simplicity of a single USB plug-and-play connection.
- Super wideband audio*
You’ll enjoy conversations so clear it almost sounds like you’re in the same room as the people you call.
- SoundSwitch™ equalizer
You can instantly optimize EQ settings for Internet calls, music, or PC gaming using the convenient control switch on the headset.
- Plush headband and ear cups
The padded foam headband and cushioned ear cups provide luxurious comfort.
- Noise-canceling microphone
You won’t have to compete with background noise to be heard.
- On-ear audio controls
You can instantly adjust the volume and mute the microphone.
- Flexible, rotating boom
You can position the microphone right where you want it—and rotate it out of the way when you’re not using it.
- Full stereo sound
Why stop at Internet calls? Your stereo headset is ready for music, movies, and games too.
Trebam da ih kupim u cetvrtak. Utisci sto sam citao na internetu su ok. Da li ih mozda neko ima slucajno?
Privlaci me to sto su USB, sto znaci da cu moci da ih koristim i za ps3 takodje. Inace mi trebaju za Ventrilo, a moje stare Logitech su na kraju veka, mikrofon je poceo da me zeza i pocinju da zuje. Bitno mi je da cujem druge savrseno, i da oni cuju mene bez smetnji, ostalo me bas i ne zanima, necu ih koristiti za slusanje muzike i slicno.
Nasao sam ih za 4800 din, mislim da je to ok cena za ovakve slusalice. Mozda su ipak malo skuplje, ali ne vidim sta ima dobro u tom cenovnom rangu da je usb. Sta mislite?
edit:
Opa, greskom sam stavio u HiFi sekciju, ako moze neki moderator da premesti gde treba.
