Posto se veliki broj ljudi zali da ne moze da konektuje svoj galaxy sa Kies softwerom koji je samsung obezbedio sa povezivanje telefona i PC-a, evo kratkog tutorijala kako da rese problem i kako ce Kies prepoznati vas telefon kada ga privezete USB kablom na vas PC (za mene je radilo iz provog i svaki put je funkcionisalo do sada):
Fix for Kies not connecting to Galaxy S
Many people are having trouble getting the Samsung application KIES to work with their Samsung Galaxy S (I9000) mobile phone. I discovered why this occurring and it’s actually very easy to get around the problem.
First off, there are two modes on the phone that you will be mainly interested in using. Kies Mode, and Mass Storage Mode. Below will explain how to get them both working.
KIES Mode
The Kies software is used for syncing applications, videos, photos, tethering amongst other things to your device. It’s also the primary way of upgrading the firmware for the phone. There is a possibility that the next operating system update called “Froyo”, which is version 2.2, will only become available via the Kies software, so in my opinion it’s very important to get it working. The main problem people seem to be experiencing is the dreaded “MTP USB Device Failed” error message when it’s loading the drivers. Consequently, Kies sits there endlessly on Connecting the Device as shown below, and doesn’t actually connect to the phone. The problem appears to be the external micro SD card. Kies will work, but it will only work with the internal SD card. If the external card is mounted, the drivers won’t install and you’ll run into this problem.
Here’s how to get around the problem.
1. On the phone, go to Settings and then SD card and phone storage
2. In the top section, which is for the External SD card, click on Unmount SD card
3. Then go to Settings, and then About Phone, and then USB Settings
4. Ensure your USB Cable is unplugged and click on Samsung Kies
Note: At this point, ensure you aren’t using any other Launcher eg. Launcher Pro Beta etc. You must be using the TouchWiz launcher to connect in Kies mode. If you don’t, you’ll get a message on the phone that says PC Connection only available in idle screen.
5. If you’re in the TouchWiz Launcher (This is the default stock launcher from when you first purchased the phone), you can now connect the USB Cable. Wait about one minute and the drivers should install successfully, and Kies should be able to connect to the phone after about another minute.
Note: To remount the external SD card (when you’re finished with Kies), simply reboot the phone. It will automatically remount the card.
Note: If the above doesn’t work, try doing the following first.
1. Plug in the phone and when it fails, go into Device Manager and uninstall the following:
Samsung Android USB modem (located in the Modems section)
Samsung Android USB composite device (located in the Universal Serial Bus Controllers section)
MTP USB device (located in the Portable Devices section)
2. Don’t rescan for new hardware. Unplug the USB Cable and follow the first part of the fix as above (steps 1-5)
Mass Storage Mode
Mass Storage Mode is used to drag and drop files, or do any file operation as if you plugged in an external hard disk, flash drive, etc. You do NOT need Kies for this mode.
If you get the Please insert a disk into Removable Disk x error when you click on the drive in My Computer (where x is the drive letter of the SD card) do the following.
1. On the phone, go to Settings, and then About Phone, and then USB Settings
2. Ensure your USB Cable is unplugged and click on Mass Storage
3. Plug in the USB Cable
4. After a few seconds, you will notice in the top notification bar a little usb symbol. Open the Notification window by dragging the notification bar down.
5. Click on where it says USB connected
6. Click on where it says Mount.
After a few seconds the internal and external sd cards should be mounted, and you should now be able to open the drives in My Computer.
Note: When you’re finished copying you’re files to/from the phone, don’t forget to unmount the phone by doing the following:
7. Open the Notification window by dragging the notification bar down.
8. Click on where it says Turn off USB Storage
9. Click on where it says Turn Off.
These fixes should work in all flavors of Windows. If they helped you, please let others know by re-tweeting or spreading the word any way you can. Perhaps leave a comment as well. I always like to hear from people I help.
Cheers
Javite utiske da li vam radi...
P.S. Kies je toliko spor da je to katastrofa
(Nokia PC Suite and OVI suite su za ovo kao Galaxy za Nokiu n97
