Mafia II
Aaaaaa kako je dobro... jedva cekam.
Mafia II Gameplay
Ne znam da li je bas ovo bilo. Znam da je bilo delova, ali evo jos malo da se zacini sledecih nedelju dana. :d
12 minuta na maximalnim podeshavanjima, znachi fizika-apex kako god, sve je na high. Igra prelepo izgleda, pogotovo deo kad ulazi u kanalizaciju. :D
http://tvgry.pl/?ID=1131
Josh 7 dana i stizhe demo. \o/
Ne znam sta je istrabunjao ovaj lik, ali je rekao "GTA" u jednom momentu. Kakav bre GTA?!
Inace, po mapi iz ovog klipa ne vidim da je duplo veca od one u prvom delu. Pre ce biti da je duplo manja.. :(
Posto nisam pratio desavanja, najave itd. da li moze neko da mi kaze da li ce biti snega? Ali bas sneg da ostane par dana, da se zadrzi, i da li ce biti godisnjih doba?
Bice snega , sad koliko ce se zadrzavati to ce ono verovatno biti skriptovano kako se misije budu odvijale., mislim da nece biti godisnjih doba.
1/3 u odnosu na mapu iz GTA IV, to se odavno zna.
http://www.computerandvideogames.com/article.php?id=243490
Mafia II:
Mafia:
Bilo bi dobro da nekad i van misija pada sneg... zaledi se voda i tako to, brutalno bi bilo. Jedino sto im uzasno zameram su ove stvari:
- lights in the car will be lit automatically
- you can't wear hats alone, they are a piece of a set (you can only wear them with a tuxedo/suit)
- cars with no roofs (cabrios) won't be driving around when it's raining
- you can get drunk and drive while being drunk
- you can't work as a taxi driver
- demo will be available on all platforms
- the whole city will be available from the start
- there are over 120 licensed music tracks from the era
- in the districts you will be able to hear different accents (for example- in Little Italy you may hear English with Italian accent, etc)
- You have over 20 weapons to choose from
- the ability to travel by public transport was cut from the game
- You will be able to drag bodies whenever you want, but you won't be able to hide them in a trunk
- pedestrians will stop and talk to each other
- you can pause and skip cutscenes
- Vito's story is narrated by himself, just like it was in the first Mafia.
- Vito can't swim, when he reaches the water he will tell you he has "something else to do"
- You will be able to free roam after the end, but Jack Scalii wouldn't tell how this would work (I think it will be something like Red Dead Redemption)
- There will be no children in the game, but the dogs will appear
- there's no airport in the game
Osim ako u medjuvremenu nije dolazilo do nekakvih promena?
Pa, ono sa mapom je katastrofa! Prvo veliko razocarenje.. :smackbum:
@El Barto
Da ima bas puno sitnica koje nece uvesti a znacile bi da su tu. Pa sta su ti ljudi radili celo vreme, grad uzasno mali, pa ove stvari sto nece ubaciti mogli su se vise potruditi;)
Aha, ovo mi je super:
Tako da vecina stvari je ok, ali ima nekih koje su mogli da ubace... a posto nisam igrao Red Dead Redemption, sta je bilo posle kraja? To jest' koliko je sloboda i to?
4 dana i 4 sata i moci ces da skines demo verziju ;-) imas timer na svim mafia II sajtovima ;-) dok na zvanicnom sajtu pise 10 ti avgyst :)
Čim bude online, skinuću na moj server i okačiti ovde ftp podatke pa da možete da svučete :)
Na zavnicnom sajtu pise da demo izlazi 10og avgusta...
Inace ono sto sam primetio je da kada vozi auto po snegu auto (za razliku od ostalih automobila) ne postaje belji tj sneg ne ostaje na njemu... steta. Nadam se da ce moci da se prlja ako se vozi po prasini ili tako nesto.
nakon duze voznje pocne da beli 100% kao sto se i prlja moja zamerka je to sto nisu aktivni brisaci :) bilo bi smekerica :)
To sto je grad mali ne mora da znaci da ce biti neki nedostatak, jer mozda nisu hteli da prave nesto ogromno a pola toga da bude neiskorisceno i da se ponavlja nego se usresredili da sto bolje odrade taj manji grad.
A mozda nesto vece nije moglo da stane na DL DVD ;) Bice dopuna kroz dlc, verovatno.. Ne volim igre u ovom fazonu ali fantasticno izgleda.
Sad sam tek video zahtevnosti i nije mi dovoljno jak procesor... ua! :D Imam Intel Core 2 Duo 2.4 Ghz, a treba za minimum Intel Core 2 Duo 3.0 Ghz...
I GTA4 ima manji grad od San Andreas ali je zato 3x detaljniji.Ne vidm problem,isto i za trajanje igre.Bolje 10 kvalitetetnih sati nego 30 razvodnjenih.:)
Da, ali bi bilo jako lepo da mozes da se vozas po ogromnom gradu... Ne znam ni da li ce moci da se vozika, onako neobavezno... :bottle:
Mocice, a posle zavrsetka igra kao u Red Dead Redemptionu... a kako je bilo u RDRu? :D
OK, ali bas zato mislim da treba da bude malo veci grad. :)
grad je veci nego u M1 i mnogo napucaniji detaljima igra je teska 10 gb gta 4 15 a mapa je 3x veca... sta reci sem savrsenstvo ;-)
Brate mafia 2 radi na 2.1 Dual core na high podesavanjima ;-)
We have forgiven less úryvek electronic music records and suggestions that surely will delight any PC Parana:
DualCore 2 GHz with a 9800 GTX handle the highest settings at 30 fps, only in minimum scenes framerane fell below, but the city was virtually continuous thirties, almost looking prestrihové movie scenes run at a higher framerate. Moreover, thanks to the authors nicely consoles optimize streaming textures, a memory from 1.5 to 2 gigabytes with an overview suffice. Maybe even a few places could remove the small mostly zatrhanie in tunnels or bridges, where they record a new part of town, but it's nothing significant.
Totalno bezveze sto neces moci da se vozis javnim prevozom. Nedostatak dece medju pesacima je takodje fail mada kapiram zasto ih nece biti (brm, brm...). Opet nema aerodroma? Smor...
Ovo na stranu, ne verujem da ce igra biti losa samo steta sto su neke stvari izbacili.
I steta sto nema gepekovanja mrtvaca. :D
Jes' vala... ne bih da skrecem u offtopic, ali neko ko je igrao RDR bi mogao da odgovori...
dece nema iz vise razloga.. a gepekovanje mi je van logiki sto ga nema jer je dovoljno da odrade sami pokrete a mi samo na primer slovo G kod auta stisenmo :) No update a ce biti tako da mozemo ocekivati Svasta pa mozda i aerodrom :)
Sumnjam da ce bas toliko stvari moci da dodaju nekim zakrpama.. ;)
Six days to go...
Six days to go...
Igra izlazi 27.08.2010 , to je malo vise od '' six days-a " :d .
Inace , Barte , postoji izum koji se zove google , pa samo ukucaj "RDR ENDING" ili " RDR FREE ROAM " , nije toliko komplikovano ...
^ Verovatno je mislio na demo. :)
