ok, nista od ovoga nije pomoglo, suvise je nepredvidljivo. ili radi sa zadrskom ili proradi svaki treci put... ima li neko neku app koju je zapravo probao i moze da je preporuci?
meni Calling Flip radi, cim okrenem telefon mutira se zvuk
i preporucio sam je zato sto je koristim
ne znam da li ima veze sa aplikacijama, ali da li postoji nacin da se instalira srpski t9 na android? video sam da ima neka cirilicna/latinicna tastatura (app) da li mozda ona ima srpski t9?
Adobe Reader for Android
Adobe Reader for Android offers multi-touch gestures, like pinch-and-zoom, as well as double-tap-zoom, flick-scrolling and panning. We've also added a "reflow" mode, which will take text-heavy documents with wide margins, and automatically wrap the content for easy viewing on smaller screens.
System Requirements:
  • Android v 2.1 and above
  • 550 MHz processor
  • 256 MB of RAM
  • 4.3 MB of available disk space
Currently Supported Devices: Motorola Droid, Motorola Milestone & Google Nexus One (While we have not yet tested against other Android devices, we expect they may also run the application just fine.)
Ima li neko Swype za WVGA rezoluciju sa podrskom za srpski?
With Froyo, Google's latest dessert-themed update to its Android mobile OS, they added even more features users were clamoring for, like wireless syncing and hotspot support. But what about future updates? We think we've got it figured out.
Android 2.3 (Gingerbread)
Release Date: Fall 2011
Features:
-WebM video playback support
-Full UI refresh
-Bluetooth voice commands
-Broader video codec support
Android 2.4 (Häagen-Dazs)
Release Date: Summer 2012
Features:
-Auto-tuned voice calls
-Built-in Twitter client automatically follows Drunk Hulk
-Fart ringtones standard
-Runs iPhone apps
Android 2.5 (Ice Cream)
Release Date: Winter 2013
Features:
-Automatic privacy screen when browsing pornography
-Valid form of ID in continental US and parts of EU
-Native CueCat support
-Calls your mother on her birthday
Android 2.6 (Jellybean)
Release Date: Spring 2014
Features:
-Phone numbers replaced by targeted ads
-Automatically screens calls based on other party's attractiveness
-Emits powerful Nordic pheromones
-Vibration mode causes spontaneous conception
Android 2.7 (Krispy Kreme)
Release Date: Summer/Fall 2015
Features:
-Charges via self-righteousness from not owning an iPhone
-Speaker automatically blasts Sade when in vicinity of love-making
-Transforms into an actual android
-Divides by zero
Android 3.0 (Lollipops)
Release Date: Spring/Summer 2016
Feature:
-BLOW JOBS
:D
Divides by zero, neprocenjivo :D
LauncherPro Beta v0.3.0 available now!
It’s here! LauncherPro Beta v0.3.0 has arrived and it brings the much anticipated dock shortcut customization. It’s still very much a work in progress, I’m taking a lot of the suggestions I’ve received for this feature and implementing them incrementally.
There’s also a couple of enhancements and bug fixes. Here’s what’s new:
Performance, stability, and memory usage improvements.
Fixed the bug where the Search option on the menu didn’t do anything.
Dock shortcuts now stay in their place when rotating the phone (leftmost shortcut stays at the bottom instead of moving to the top, etc.)
Custom dock shortcuts – Long-press any of the four shortcuts and you’ll be able to choose a new shortcut to replace it. You can add any type of shortcut; applications, contacts, direct dials, music playlists, and more!
Option to restore default settings in the Preferences screen (useful if you want to revert to the default dock shortcuts.)
Some users have pointed out some problems with Android Froyo 2.2, mainly that LauncherPro can’t be restarted from the Preferences screen, and that some apps installed to the SD card don’t show up on the app drawer.
The restart issue happens because Google removed an API call that lets apps restart/kill running processes (in the case of LauncherPro, itself). I need to look into finding another API call that will restart LauncherPro. In the meantime you can use Android’s new native task manager to kill LauncherPro and then start it again.
I haven’t had time to look into the SD apps issue yet, and as I don’t have a Nexus One I’m unable to test it on a device. It’s likely that I won’t be able to fix this until Google releases the source code for 2.2.
Here’s some new things coming soon to LauncherPro:
Ability to uninstall apps by dragging them and holding over the trash can.
Option to remove the “Home” icon from the app drawer
Option to use LauncherPro-style (translucent) icons for custom shortcut docks. I will need to create icons for the most-used applications — Please tell me which apps you’d like to see icons for in the comments.
Option to hide status bar for a cleaner look
Option to hide icon labels
And this is only the beginning, there’s SO much more stuff coming to LauncherPro that will hopefully make it the ultimate Android launcher. And don’t worry, most new features will be optional and performance will always be taken in consideration when adding new stuff. The idea is to make it more feature rich while maintaining the same level of performance.
Da li ima neki program koji bi integrisao opciju u imenik koja bi omogucila pretragu npr. Facebooka i ako taj korisnik ima facebook nalog, da ubaci njegovu sliku u imenik? Nasao sam neki SynvMyPix koji radi nesto slicno, ali nije to to. Jednostavno ne funkcionise kako treba.
Ja na 2.1 imam običnu Facebook aplikaciju koja sinhronizuje slike sa FB za ljude koji mi se zovu isto na FB i u imeniku.
Koji bese ti imas phone? Posto na htc-u ti je integrisano to vec.
pa jel imas u settings > social networks da biras facebook?
Pa pitam zato sto tako radi na Hero kod mene, aktivaras tu face i on sam odradi povezivanje sa imenikom,povuce slike, radi update . . . .
E ****ga, to kod mene nema. Bilo bi dobro da ima opcija za svakog u imeniku da kao sto moze da s izabere slika sa kartice, da tako moze da se izabere sa npr. Facebooka.
I meni nedostaje ova opcija. Za sada se snalazim tako što sam sredio imena u imeniku da budu prava, pa mi vuče automatski Face podatke.
ne postoji ta opcija jer ona postoji samo kod HTC Sense romova... inace primetio sam da u novoj facebook aplikaciji (onoj koju mozete naci na marketu) postoji nesto slicno, samo nisam oprobao jer imam Sense...
evo jedna zanimljivost, bolje reci bug
Ako imate nekog prijatelja na Facebook da je u podacima popunio polja za Phone i Mobile i da je upisao neki slobodan tekst (ne broj telefona) pri logovanju na Facebook kreira se account i on syncuje sve podatke sa Facebook, pri tome ako se ostavi na default syncuje i contacts, tj kreira u contacts sve iz friends liste, problem je sto se ti podaci ne mogu menjati (nema Edit u opcijama) i sta mi se desilo. u slucaju da zovem nekoga ko je nedostupan, cim bude dostupan, njegov provajder mi posalje poruku taj i taj korisnik je ponovo dostupan, medjutim ta poruka se prikazuje u messages kao da mi je posalo taj contact koji je na facebook imao tako unete podatke (kod mene je to bio slucaj sa gx-x_om), a ne Telenor, Vip ili MTS (kako inace pise). reseno je tako sto sam uklonio Facebook account, ponovo ga kreirao (sign in) i iskljucio da ne syncuje contacts
