Novi telekom ruter HG520 C
I have noticed a few threads lately along the lines of "XYZ ISP is throttling torrents now!", and in a lot of cases most of the people with this problem have upgraded to µTorrent 2.0.1.
The following will help if:
1) You are using v2.0.1 of µTorrent
2) You have an upload speed limit set in µTorrent
Basically the new version of µTorrent calculates your bandwidth limits a little differently and by default includes protocol overheads in the calculation. So, if you set a low upload limit of something like 16kB/s you are effectively limiting your download speed to somewhere between 150kB/s and 200kB/s.
Fortunately you can disable this calculation as follows:
1) Navigate to Options / Preferences / Advanced in µTorrent
2) Find the item net.calc_overhead and set it to 'false'.
Your speeds should return to normal.
To je valjda do nove verzije utorrenta, koliko sam procitao.
Da li ima neka skripta za reconnect (sto se tice jdownloader-a ili Cryptload-a)?
Izguglao sam ovo objašnjenje na jednom drugom forumu, isprobao u jdownloaderu i radi i na HG520c.
1) Udi u Jdownloader u configuration/reconnection
2) U Reconnect Method/CLR script unesi sledece parametre:
Login: admin
Password: ztonpk
Router IP: 192.168.1.1
3) Zatim copy/paste sledecu skriptu u "prazan" prostor
<CryptLoad>
<Router name="Echolife HG520i Home Gateway Telekom Srbija" />
<Command method="Auth" action="" />
<Command method="GET" action="menu_status.html" />
<Command method="GET" action="rpServiceStatus.html" />
<Command method="POST" action="Forms/rpServiceStatus_1">
<Parameter name="Connect_DialHidden" value="0" />
<Parameter name="Connect_DialFlag" value="1" />
<Parameter name="Connect_Flag" value="1" />
</Command>
<Command method="GET" action="rpDisConnecting.html" />
<Parameter name="Connect_Flag" value="2" />
</Command>
<Command method="GET" action="rpConnecting.html" />
</CryptLoad>
MODULI
4) U Advanced Settings izvrši sledeca podešavanja
First IP: 10
Max repeats: -1
Wait new IP: 30
Hvala, mada vidim da sad i jdownloader moze sam da snimi reconnect postupak, i sa tim radi.
Meni daje jaci signal nego S. Signal ide kroz dva zida, na udaljenosti od pet, sest metara, i daje pun signal.
Jel ima nekog nacina da saznam sifru za pristup netu? Iz tehnicke podrske mi rekose da posaljem zahtev na mail i ako Bog da do Nove godine cu dobiti na kucnu adresu sifru, jer ne mogu preko telefona da mi kazu... Moze li nekako da se izvuce od ispod onih zvezdica? :)
Standardno svi kukaju da je ruter ružan, da ima loš signal, itd... Meni se recimo sviđa što nema eksternu antenu, a signal mi je pun, ili fali 1 crta a daleko sam od rutera 10m i deli me 4 zida od njega. Šta je tu loše?
Ne može nikako sem da ti oni iz Telekoma opšalju. Možda je bolje da odeš u korisnički servis sa ličnom kartom i da im tražiš da ti daju na licu mesta.
Sta sve treba da uradim da bi preko moje ip adrese pristupio kompjuteru (pc server). Imam hg520c modem, pokusavao sam sa port forwarding i dmz ali kad god ukucam svoju ip adresu on me usmerava na stranicu za podesavanje rutera.
Da li kucas kucas adresu koju ti je dao ruter (ona je iz privatnog opsega i ne rutira se na internetu)? Ako je tako onda idi na stranicu http://www.whatsmyip.org/ pa vidi koja je tvoja javna adresa pa probaj preko nje . Mada je mozda najbolja solucija Hamachi i da ne brines :) .
Kako, prosvetli me sveti čoveče...znači bukvalno na 3m od njega u istoj sobi na toshibi signal na pola, wtf? Garantovano ni na jednom kineskom đubretu nije ista elektronika, kako gde šta ubace.
Taman za ova 3 meseca frei, da kupim ljudski wifi router, tražim pass i ovo đubre ide u svoju kutiju.
U kutiju verovatno nece, trebace ti kao modem ;) .
Inace slazem se, ovo je chabar. Kada me je peti zaredom covek iz Telekoma pitao sta ce mi moj ruter, 5 sekundi sam cutao da mu ne iznakrsim majke. Da me ne shvatite pogresno, drugi daju jednoportni ruter, ili kako se vec zove, ili neko USB djubre, tako da je ovo kao premija. Ali zaista nije ok sto skoro pa da ogranicavaju koriscenje nekih drugih rutera.
Kod mene je kompjuter udaljen 3 metra vazdusnom linijom od modema, komp na spratu, modem u prizemlju. Povezan sam sa ovakvom antenom i signal mi je savrsen.
Ma garantovano je ono šta sam rekao, od primerka do primerka...zapalo mi scheise i to je.
Ja sam dobio user u pass pre nedelju dana. Molbu sam im poslao pre 4 nedelje. Šalji mail na [email protected] i zahtevaj user i pass.
Uradio sam to jos juce. Rekli su mi da je to jedini nacin. Koje si sve podatke stavio u molbi?
PROBUDI ME ČOVEK U 4:00...
Drugar je danas preuzeo ovaj HG520C.
Kaže da je sve kablove povezao kako treba (u to ne sumnjam).
Uzalud...
Problem je u tome što mu DEVICE MANAGER ne pokazuje NETWORK ADAPTERS, to je otkrio Telekomovim telefonskim navođenjem...
Danas mu rekli ovi sa 0800100100 da mu valjda trebaju drajveri za matičnu ploču (kaže da je u pitanju Asus P5LD2/X-1333).
Moje skromno poznavanje materije mi ne dozvoljava da vam problem predstavim detaljnije.
Dakle;
- Zašto mu DEVICE MANAGER ne pokazuje NETWORK ADAPTERS?
- Ima li to veze sa drajverima za mat. ploču?
- Gde skinuti sporne drajvere?
Znalci, pomozite čoveku da se konektuje:,,:
Pozdrav!
1. Nije sigurno instaliran drajver za mrežnu karticu.
2. Da. Povezano sa pitanjem 1.
3. Najbolje sa sajta proizvođača matične ploče.
Ako ne zna koja je matična ploča može da mu pomogne program Everest.
Udji u bios-advanced-onboard devices configuration i nadji onboard PCIEX 10/100mb LAN i prebaci ga na ENABLE sto verovatno nije.
LAN option ROM neka ostane na DISABLED.
Ima itekako veze sa drajverima ali je problem sto nisi napisao koji je operativni na kompu.
Na koji od portova je prikljucen lan kabel?
http://www.asus.com/product.aspx?P_ID=qRAhHrSPh43XlWBL idi na download, izaberi operativni i idi na lan.
Izvinjavam se zbog drugog posta ali... da li je uspeo neko da otkljuca drugi i treci port? Imam kod druga ovaj ruter koji deli net na 3 kompa a nije mu potreban IPTV, pa da ne ide preko dodatnog svich-a.
Idi u podesavanja rutera, uloguj se kao admin (un: admin, sifra bese ztonpk, pise negde po forumu :) ), Basic > DHCP podesavanja i stikliraj Ethernet portove 2 i 3, po defaultu su stiklirani 1 i 4. Trebalo bi da je to to :) .
Ok, probacu kasnije cim ga nahvatam kuci, nadam se da je to sve sto treba...
hvala :)
Hvala vam na trudu.
U toku dana idem do njega, pa ću znati više.
-OS WinXP
-Lampica nikada ne svetli ('gurao' u Lan1 i Lan4)
Još jednom, hvala svima!
Telefonskim navođenjem od jutros, rečeno mu je da pronađe ETHERNET CONTROLLER DRIVER za mat. ploču Asus P5LD2/X-1333.
Ako mu skinem sa Asusovog sajta drajvere u sekciji LAN (ima tri verzije),
problem je rešen ili ne?
Proradio!
Sa sajta proizvođača skinuo drajvere iz LAN sekcije, instalirao i sve radi kako valja i potrebuje!
Hvala svima na korisnim savetima!
Seka dobila ovaj ruter, pa bi samo da napravim sifru za wireless. Udjem sa: admin/ztonpk i gde je onda tacno opcija za sifru za wireless i sta treba preciznije uraditi? Hvala.
Sve lepo piše, bukvalno nacrtano:
Basic
Wireless Lan
Acess Point: Enable
SSID: Sekina Mreža
Authentication Type: WPA2-PSK
Encryption: TKIP
Pre-Shared Key: Sekina šifra
Submit
Čestitamo, hik, postali ste majka
I da, uz modem dolazi uputstvo, isto kao nacrtano
Znam, brate, ali bolje i pitati, pa budem 100% siguran. Hvala ti.
nema na čemu. nemoj molim te da staviš ovaj pre-shared key koji sam ja stavio i naziv mreže, to odaberi sam, šalio sam se samo naravno. javi dal radi. i promeni pass za admin, ako ti neko obije mrežu ne može da ti brčka po podešavanjima modema, pošto svi znaju taj default pass ztonpk. to i ne moraš da uradiš, al što je sigurno sigurno. poz
