OpenCL benchmark
Ne moze se skinuti bez premium rapida :)
9800GT - 172
Q6600@3Ghz - 42
HD4870 - 81
CPU - 65
Sad jedva čekam da probam i na originalnoj grafici (2600XT). Mnogo nešto sporo ovo :d
A i sa 4xxx serijom moze biti problema...
"This is entirely dependent on how you coded the kernel and what OpenCL features you are using. There are known performance issues for HD4XXX series of cards on OpenCL and there is currently no plan to focus exclusively on improving performance for that family. The HD4XXX series was not designed for OpenCL whereas the HD5XXX series was. There will be performance improvements on this series because of improvements in the HD5XXX series, so it will get better, but it is not our focus."
http://techreport.com/discussions.x/18201
pa koji su onda djavo uopste trpali ATI 48xx kartice u najnovije iMacove... :?
jel radi, i da li uopste ima smisla, OpenCL na nvidia 9400M ?
Testiraj:) 8400GS koji trenutno koristim daje oko 17Gflops, 9600 i 9800 imaju oko 170 sto je u poredjenju sa 285GTX koji daje oko 400 skroz ok rezultat.
Jel neko koristi CUDA pod OSX?
Inace ATI ima problema sa implementacijom OpenCL-a kolko sam ja uspeo do sada da ispitam, cak i sa 48xx serijom, a kao sto vidite nVidia funkcionise ok.
250GTS, OC verzija: 299 Gflops
Evo i ja da se pofalim :)
8800gt 220 Gflops :)
CPU neka beda od 13 Gflops ne znam sto je tako mali valjda je to ok?
kod mene puca program? :smash:
GT 120 - 57
CPU - 44 (Quad-core Xeon na 2.66GHz)
aha, pa ja bas gledao ali skapirao sam da je i za lepoarda.
ok, hvala.
