Prostreet
pa koliko je 5850 u Nemackoj?
:d pa ovo stvarno smesno, kod nas 5850 ima da se nadje za 215 evra, jel' normalni ovi Svabovi??? 😀
As the name suggests, the HD 5830 is based on the same Cypress GPU that powers the HD 5850 and HD 5870. What the name does not suggest, though, is that at the heart of the HD 5830 that is so crippled it hardly resembles a Cypress. Only 14 of the Cypress' 20 SIMDs make it to HD 5830 - with a total of 1120 SP and 56 TMU.
ROPs have been chopped in half, to leave behind only 16 out of the 32 on the HD 5850 and the HD 5870. However, to compensate, ATI have moved the clock speed all the way up to 800 MHz, a full 75 MHz more than the 1440 SP HD 5850 and only 50 MHz down on the flagship HD 5870.
The memory stays at 1 GHz G5, with the memory bandwidth at 128 GB/s, same as the HD 5850. The final number that pops out is the TDP - which is inexplicably more than the HD 5850 - at 175W. The idle usage is a tad lower at 25W, however.
Možda bude otključavanja na 5850 😀 bilo bi lepo od atia 😀
Ili je stavljen veci napon da bi se izbegao GSOD 🙂
Auuuu, kolika je karta!!! :hair:
Celih 11in, pravi crnački model. :hump:
Izgleda da je ATI za referentnu kartu iskoristio falične 5870.
Idealna varijanta za one koji hoće da se hvale veličinom. :smoke:
