Znam pouzdano da je ovu maticnu pazario user fingon82. Ja se dvoumim izmedju
M4A785TD-V EVO
http://www.asus.com/product.aspx?P_ID=fcsXWSxnhzZE9rnR
i
GA-MA785GT-UD3H
http://www.gigabyte.com.tw/Products...rd&ProductID=3154&ProductName=GA-MA785GT-UD3H[/QUOTE]
Evo sta se na sjatu tomshardware kaze o njima:
http://www.tomshardware.com/reviews/amd-785g-motherboard,2441-11.html
Asus M4A785TD-V EVO
The Asus M4A785TD-V EVO is a full-sized AM3 board targeted at the enthusiast with advertised DDR3-1800 overclocking
support and a 10-phase voltage regulator. While you won't find some legacy connectivity options on this board (no serial, parallel, or floppy option here) you will find a solid backbone with the ability of running at least 1,600 MT/s memory and potentially even more, which is a rare capability among 785G products. Even though the board lacks enthusiast-class features like BIOS profiles and a clear CMOS button, it does offer the capability of unlocking dormant CPU cores in conjunction with the ACC function. The M4A785TD-V EVO remains a solid choice for the Phenom II overclocker on a $100 budget.
Gigabyte GA-MA785GT-UD3H
Gigabyte's entry is the most fully-featured ATX AM3-based board in the 785G roundup. It is the only board that supports all legacy connectivity, such as floppy, serial, and parallel ports (although the serial and parallel ports require cables not included in the bundle). The enthusiast will appreciate the flexibility of eight BIOS profiles, good BIOS control, and the ability to choose ACC modes that will either unlock disabled CPU cores or just allow ACC to work normally. The board also sports the premium Realtek ALC889 codec. It's not the most memory overclocking-friendly option, but at $80 online, there is a lot of value here for folks who want a solid AM3 platform.[/QUOTE]
Kada sam pitao moda [
Mancha] o ovome, koga izuzetno cenim, dobio sam sledeci odgovor
[Mancha] je napisao(la):
Nisam siguran da mogu da budem objektivan, ali bih ja za sebe radije uzeo Gigabyte. Sa Gigabyte-om kada su AMD ploce u pitanju u principu nema greske ni iznenadjenja. Verujem doduse i da je taj asus dobar. Nisam probao ni jednu ni drugu, ali sam imao povoljna iskustva sa gomilom GB ploca sa 770 i 785 chipsetom, pa verujem da ne moze da omane.
Moja istrazivanja na ineternetu ....
u principu Asus ima bolju naponsku jedinicu, pa se valjda bolje i klokuje
8+2 Phase Power Design
To fully unleash the next-generation AM3 CPU´s potential, the ASUS M4 Series motherboards have adopted a brand new 8-phase VRM power design. It delivers high power efficiency and supreme overclocking ability. Furthermore, high quality power components can effectively lower system temperature to ensure longer component lifespan. This series also features an extra 2 (or 1) phase power dedicated to integrated memory/HT controller
@fingon82 mi rekao da mora da se flesuje novi bios da bi se ispravila neka greska kod Phenom II procesora. Najbooje da njega pitas. On moze da ti kaze iz prve ruke .
Tolko do mene
