Key features include:
- Automatic LNB installation.
- Dynamic Channel Update which enables the receiver to automatically find new channels.
- Also with the ability to turn Dynamic Channel Update on or off easily.
- NZ Freeview Channel Mapping. With this feature, the receiver will maintain the same channel numbers as Freeview.
- Small in Size.
Tuner & Channel
Input Connector F-Type, IEC 169-24, Female
Signal Level -25 to -65dBm
LNB Power & Vertical: +13.5V
Polarization Horizontal: +18V
Current Max 500ma
Overload Protection
22KHz Tone Frequency: 22±1KHz
DiSEqC Control Version 1.2 USALS™
Demodulation QPSK
Input Symbol Rate 2-45 Ms/s Convolutional Code Rate
1/2, 2/3, 3/4, 5/6, 7/8 and Auto
MPEG TS A/V Decoding
Transport Stream MPEG-2 ISO/IEC 13818
Transport stream Specification
Profile Level MPEG-2 MP@ML
Input Rate Max. 81 Mbit/s
Aspect Ratio 4:3, 16:9
Video Resolution 720*576
Audio Decoding MPEG-2 Layer I & II
Audio Mode Mono / Left / Right / Stereo
Sampling Rate 32,44.1 and 48KHz
Main Processor STi 5518
Flash Memory 2 MByte (Optional expand)
Program DRAM 16 MByte (Optional expand)
E²PROM 256 Byte
A/V & Data In/Out
Video RCA/Cinch, Video Output (CVBS) SCART (RGB,CVBS)
Audio L/R RCA/Cinch Volume & Mute Control
(Resolution: 20 bits DAC, Max 2Vrms)
S/PDIF of Dolby Digital Bitstream Out
RS-232C Transfer rate 115Kbps, 9 pin D-Sub Type
RF-Modulator
PLL type CH 21~69 for the Demodulation
TV Standard PAL B/G/I/D/K selectable
RF Connector 75 Ohms, 169-2, Male-Female
Frequency Range UHF: 470~860MHz
Power Supply
Input Voltage AC 90-240V ~ 50/60Hz
Power Consumption Max. 25W
Protection Separate Internal Fuse
Type SMPS
Physical Specification
Size (W*H*D) 180 * 45 * 250(mm)
Net Weight 1.8kg
Operating Temperature 0°C~40°C
Storage Temperature -20°C~60°C
